Grant Gunderson
Now I realized I have a bit of a problem on my hands.
There is supposed to be a threaded hole under the spindle mount for a setscrew to secure the switch assembly. Apparently the silicone paint plug had gotten pushed in to far and it got bonded over. No sign of it at all. Pressing with my finger (revealed the other hidden plugs) was to no avail. The bore is completely lost. Thinking I may have to re-drill it, I used a depth mic, to measure where the bore enters the shaft bore for the switch. I then translated that to the front.
FYI, thats not a scratch. Its the reflection of the pin in the paint! I then went to mark the location using a pick with the intent of having to center punch it for drilling next. Luck was apparently on my side and the pick went directly though the Bondo and right into the silicone plug.
I was able to remove the silicone plug. Turns out the setscrew I had left in there to keep the plug from going too deep, was intact too deep.
There is a detent for the lock plate as well. It also got a new spring and bunch of super lube.
The lock plate is quite worn. If I ever find a replacement I will switch it out, or when I have more time I will make a new one, but it does work still. Once it was secured with the 4 countersunk screws I installed the plunger for the detent and lubed the plate with super lube as well.
The handle assembly then gets slid in, and mates with the with in the rear. I then tightened down the Stainless set screw in the bed side of the head stock casting that secures it, followed by giving the rear switch plate its finally torque now that its aligned. Finally there is a dog point setscrew, followed by a Stainless hollow set screw that goes into the bottom of the switch plate assembly to keep it from over traveling. Man does it feel good to get some parts back together.
