Hi,
I have a sub panel outside the house on the exterior outside the garage, house is a modern stucco exterior in Cali. I want to punch through the back of the panel and run some wires for an EV charger to the garage inside which has drywall interior.
- When I pop out the cover in the panel what do i need to use behind the panel to seal it since it is flush against the wall? I can't use a water tight conduit fitting it won't fit.
- Depends on your response to question 1. Let's assume I find some fitting that sits flush, between the wall I assume I need to run flex conduit and can't have exposed wires obviously as these will be thicker gauge wires correct?
