Sawmill
R
RivennHewn
PNW
Cutting up that last floater I pulled in.
Looks/smells like Cedar.
Going to go board and batten on the backside of the kiln.
Cut these 1” x 10”. Should have enough to complete it.
Finishing up the kiln was on my summer to-do list. Now that summer is pretty much over, I guess I’ll get started ☹️
R
RivennHewn
PNW
Made a new contact with a cabinet maker/finisher/boat builder today.
Had just taken down a Holly tree. Brought it home, and I’m excited to see what’s inside🤑
Also spent some time trueing up some dried cants that would have made Chubby Checker blush
PugetDude
Superstition Mountains, AZ
That holly could be worth some serious money.
Wooden boat and custom furniture builders use it for stringing and inlays. It's about the whitest wood there is and it doesn't darken under most finished.
Might check with the Northwest School of Wooden Boat building over in Port Hadlock or the boatbuilding cooperative in Port Townsend.
R
RivennHewn
PNW
Holly is great to work with, and turns beautifully on a lathe. Not sure how it is to dry, but I’m about to find out 😜
R
RivennHewn
PNW
Told myself I wouldn’t cut anymore treated Material.
Now, I’m telling myself that again. Oh well🤔
Nice little gift from the channel gods, wrapped up in nastiness.
Should make for an interesting project, somehow/somewhere.
Time for a thorough cleaning of the mill and site😵‍💫
LXCam
That’s one cool chunk of nastiness that’ll sure make for something unique. How big is that piece?
LXCam
R
RivennHewn
PNW
10” x 10”x 4’
I’m trying to decide what kind of finish to put on it, that will cure over the coating that’s left on/in it.
If used as a bench, maybe use that as the base, or bases by cutting it, and put a pants friendly top board on it. Rumor is you have a few options.
R
RivennHewn
PNW
Kick’d some **** on siding the the backside of the kiln today. The only challenge was getting the vents centered between the battens.
Only a few more battens to install.
R
RivennHewn
PNW
Forecast looked favorable, but forecasters lie.
Still, I got my siding stained this afternoon, fighting the rain and wind.
On another note, I took the temp/RH sensors into the garage while I was siding. Been in there a couple days.
While the temps read the same, the RH is 20+ percent off. I guess I know I can’t trust these units. Time to research for better quality sensors 😕
R
RivennHewn
PNW
Step one: obtain free marine biology lab tables.
Step two: clean, prep, level tables.
Step three: secure tables together.
R
RivennHewn
PNW
Got my new temp sensors for the kiln.
The display unit stays in the garage, and remote sensors inside and outside the kiln.
R
RivennHewn
PNW
More toys from the mailman.
After assessing the tables a bit more, they needed some work. A few failing joints, a bit out of square, and signs that the biology students do know how to table dance😜
Nothing some clamps and screws can’t fix.
glennm
I like the look of those rails. I have been thinking about a router sled for a while now. I have been getting by with my planer and drum sander for most tasks. Btw, thermoworks rocks!
This is a small table I made from a downed ash that we milled. I like using the rough stuff
Toolfool
Tallahassee, FL
Might need to buy a bigger router🤔
Look on ebay for one of these US Made #75182 Porter Cables. 3-1/4HP, 5 speed, 1/2" chuck beast. It's what I use in my router table. I had a NIB backup unit which I, unfortunately , sold when I was leaving WA. I got double what I paid for it.
I also sold a set of extruded rails with a router sled mounted on ball bearing guides. :dunno:
R
RivennHewn
PNW
Great looking table!
I pilfered some unistrut. 3/4” EMT drops nicely into it, yet stays high enough for the rollers to run. I’ll do threaded inserts to hold the strut down, and just lay the conduit in.
This will make for easy removal, for using the table for other task.
Next task is the carriage for the router/dust collection.
R
RivennHewn
PNW
I’m going to drag my 3-1/4 horse Bosch out of retirement.
R
RivennHewn
PNW
Lee Valley makes a router gantry setup, uses conduit for the rails, a low budget entry into the game.
I love Lee Valley/Veritas stuff, and considered it.
But I’m cheap, and trying to use extra materials off job sites.
So far I’m into it just over $200 for the rails, rollers, and 3” carbide insert bit.
Those linear slide things are usually stupid expensive, nice get if $200 includes them.
R
RivennHewn
PNW
Still figuring it out.
Looking for that sweet spot for bit height.
Router only has about 3” of trave vertically, so setting the carriage at the right height to maximize versatility it crucial.
Toolfool
Tallahassee, FL
You'll most likely be shimming the 'wobble' out of your first side, so you can shim the whole slab up as needed.
