Sawmill
R
RivennHewn
PNW
As my new temp sensors are temp only(hit buy it now on the wrong item) I picked up a handheld RH meter. Now I can check the kiln, and the sheds, as well as the garage. Maybe next time I’ll get everything in one system 😕
R
RivennHewn
PNW
YouTube is definitely on the list of things I don’t understand.
I post vids to YouTube so I can post a link on GJ. Not to gain views on YT.
Usually with no title or description, like the last one with the linear slides.
Where I might get a dozen views off GJ, I usually get considerably more on YT.
If I do post it with a title/description. I get like 12 views.
PCustoms
VT
I’ll be wearing mine the first time this thing hits 21,000 RPM
Thinking I might use some loctite on those screws holding the carbide on.
Nope.
I can't imagine running that in a handheld router.
Years ago I had a need for a custom bit, with very unique geometry. I also had connections in the machine tool industry and the ability to braze and grind carbides.
Life gets interesting at 20k+ RPM. I chickened out
R
RivennHewn
PNW
Nope.
Hand held, no way.
This will be mounted. I’m considering adding weight to help with any uplift.
Maybe one of ya smart people could Calc the speed of shrapnel coming off a bit turning 21,000 RPM
PCustoms
VT
Diameter?
Edit: 187mph for a 3" bit, 125mph for a 2".
Rounded to the nearest mph. For reference a .45 ACP bullet is going around 550mph
R
RivennHewn
PNW
Diameter?
Mine’s a 3” bit.
I remember years ago when I was a young finish carpenter, a little brass insert came out of an expansion slot and hit a coworker on the inside of his elbow. Right next to his artery. Required surgery to remove it.
Not sure if anyone still makes blades with inserts.
Jayman17
Seattle, Wa
Aren't you supposed to run those bigger bits at slower speeds? That one at 20K rpm scares me and I will stay inside on the day you fire that up and I'm 60 miles away from you. :lol2:
JimH74
South Central Texas
My SIL flattened a big piece of sapelle-African mahogany (thinking 36"x84") with a rig like you're setting up. He didn't have any problems. Just don't try to hog off too much at once.
R
RivennHewn
PNW
Bingo.
I’ll be starting off at low speed, removing very little material. Then find the sweet spot for depth of cut/RPMs/feed-rate.
I’m familiar with full sized shapers, and these big router bits concern me more than the big shaper cutters.
R
RivennHewn
PNW
We got all the big tools at work.
I love the cordless rivet gun I bought awhile back($950 on the company CC)
R
RivennHewn
PNW
Made the subconscious decision to meander through Rockler today.
Seriously, I was not intending to buy a router.
But, it was very pretty, and on sale too!
Could have gotten by with my old one, but surely that would not have been as much fun.
LXCam
Never heard of that Riv. They any good? Well more importantly, what’s the HP rating :3gears:
R
RivennHewn
PNW
Triton has taken over where Porter Cable left off with these 3-1/4 horse routers. Supposedly, they’ve fixed the electronic feedback issues and upgraded the bearings. We’ll see.
PCustoms
VT
Was going to say looks a lot like the old Porter Cables.
I'm clinging to my collection of 690s, but really should get something bigger for the table.
R
RivennHewn
PNW
Made a last minute call as I was about to mount the router to the acrylic plate. Decided to clock it 45 degrees. Thinking it’ll balance the side-to-side with the end-to-end movements. Also didn’t care for the power cord sticking straight at me. Easy to change if I don’t like it.
Jayman17
Seattle, Wa
Might have to give that a flick start with your finger to get it spinning. :evil: Hope you post a video of that in action on a slab when you get going. How long is that table?
R
RivennHewn
PNW
Ain’t getting my fingers anywhere near that thing!
Table is 12’ long, but the rails hang over another foot at each end. That gives me 12’ of useable length. Not sure about max width yet. Table is 42” wide, but the hardware takes away some inches
R
RivennHewn
PNW
Slowly making some progress on the dust collection system for the router sled/table.
Life throws you way too much silliness sometimes.
Still figuring out what it’s going to take to be able to do this in the garage. If it fails I’ll have a plan B to set up a roller system on the mill rails.
Would rather be inside, out of the weather 😕
R
RivennHewn
PNW
Tonight’s fun little project.
I needed more outlet capacity on the ceiling above the router table. Added this double sided box. Kinda tight quarters for the wires inside there 😬
Now I have room for both garage door openers, the router table, and a bug light 🙄
I hate ceiling outlets that point down, leaving dangling cords. Now my cords can be secured to the ceiling, nice and straight and clean.
At least, after I finish the drywall and paint 😕
Also added a retractable cord reel above the router table.
Anyone else “All about cord management “?
