LutzTD
nice building, got some real usable sqft's
How do you lube all the sand ??????Lube is your friend.
Usually it's inadvertently.How do you lube all the sand ??????![]()
Someone mentioned that great idea before. They must own DR.DR Towable backhoe.
Every Floridaian should own one.
Thanks. They say, 9 times a charm.Looks good this time!
Like "My cousin Vinny"Thanks. They say, 9 times a charm.![]()
Ummmmm .....you do.If only I knew someone with an order picker.
Then tie strings to the hydraulic controls so you can operate the lift functions from on the platform. I’m sure you’ll be safe.Shorty, build a work platform for the Kubota...
You clearly should be doing a Postdoctoral Fellowship at the North Florida Safety Skool.Then tie strings to the hydraulic controls so you can operate the lift functions from on the platform. I’m sure you’ll be safe.
Fixed it.Mechanical linkage is more positive than string. Find a couple of forked sticks the right length, zip tie them to the control levers and you should be good. Until you're not.
The boss will get these pics tomorrow.
I seem to remember telling you about covering boxes.
Forgot, this week was insulation. Closed cell 2” ceiling, 1” walls. Glad I checked up on them after the first day, a little on the thin side. Probably 1/2-3/4 on both.
Sent this to the boss. Even at 1” the ribs shouldn’t be that visible.
The second day they added to the first coat and finished the other half. Made up a quick gauge and only found one low spot that was just under 1”. Another oops was the open outlet boxes guess they have never seen one.
One was completely covered with extra foam.
You can lead a horse to water...I seem to remember telling you about covering boxes.![]()
Of course they would.Uh, that’s why I paid extra so they’d do it.
If I covered the boxes, they probably would have buried them all.![]()
