Show us your handplanes
ararat
Ararat NC
Thinking rosewood, but but haven’t done a density calculation yet. Friends thought rosewood as well.
Probably won’t actively remove it, may let the wear of me using it see if it makes a difference 🤪. Is lacquer thinner the answer, or acetone? I know finger nail polish remover worked on a home made coffee table😡😤. Is either gentler to the system?
Either way it's some nice wood for a plane.
I removed poly from a chisel handle and ended up using a card scraper and then sandpaper.
Card scraper would be my choice well ahead of abrasives, but hoping I can remove the final bits chemically. I really hate sanding, it dulls the appearance so much.
ararat
Ararat NC
That's the best part of using handplanes and scrapers is that it pretty much eliminates the need for sanding.
  • Like
Reactions: RTM
milkovich
Akron Ohio
112 Back online. It was a mutt, but now it’s a mutt with rosewood furniture. The knob is wrong (it’s off an early 6/7) till I can find a low 3/4 knob. I thought it might be a store brand plane but it does have the sw logo on the cap screw. The thicker hock blade works a treat.
Eric Brown
An interesting bronze plane. No markings. The skate on the bottom is about 1/8" wide, 3/8" high and 9" long.
Thinking this plane was used after a 1/8" wide slot is cut into a piece of wood. The cutter has a Tee shaped set of scooped cutters.
This would leave a slot with a hollow at the bottom. Perhaps used for canvas or screens stretched and a cord pushed into the slot until it hits bottom where it could expand.
Anybody know for sure?
Old tool guy
So you’re thinking like a t-slot? Wouldn’t the chips clog up?
FullRaceMerc
SoCal (SGV)
Can the cutter be moved to the side, so it would cut next to the center guide? Set up higher & to the side I'd wonder if it would cut beads on cabinet face frames prior to mitre work & assembly.
Eric Brown
I'll try to explain again. There first has to be a 1/8" slot before this plane is used. The cutter then only has to move the shavings from the side cutters up the slot. I tried it once on a piece of soft pine. It worked, but wasn't fun. Today instead of a cord they use a more rubber like strip that compresses.
Eric Brown
Union Manufacturing is beginning to sell the X-Plane designs again. It uses a vertical post with a nut on each side of the adjuster yoke. High quality. They just had a video conference and it has Robert Porter of Union Manufacturing, talking with Robin Lee of Lee Valley, Joel Moskowitz of Tools for Working Wood, Paul Hamler miniature maker, and several other people. It was a very interesting conversation they all had about the state of manufacturing hand tools.
crguy
SW Washington
Porter found out making new planes isn't all that easy. And then, trying to find enough buyers to make them profitable is a another real problem.
CRSINMICH
Southeastern Michigan
Eric Brown: Judging by the the fourth picture you attached, the plane you posted would cut a bead. It may have been based on or inspired by the 1878 patent by Justus Traut. It doesn't look like a commercially produced plane but it was well made. I think the T shape of the cutter may have been to provide relief. It's possible that there was another cutter that would have cut a 'hollow' that would match the 'round' or bead. It is a lovely plane that may well be one-of-a-kind.
Beerhippie: That is a nice spokeshave based on a Stanley 151. Notice that the Marples number is A151. Coincidentally, this tool also could have been based on a Justus Traut patent. It's really not all that surprising because Mr. Traut had at least 150 patents.
Eric Brown
Definitely not a one off. I have seen others like it. I still think it was used to stretch either canvas or screen wire in a frame.
bmwrd0
Beaver Fever Oregon
What do I have?
It came with a Sweethart blade and a cap that doesn't work when they are all paired up. I fit the knob off of my Stanley #8 and it screwed right in. I want to say it is a 4-1/2c type 5, but the adjuster is throwing me off.
What do I have?
WisJim
Menomonie, WI
What do I have?
What do I have?
It's an Ohio O4 1/2C. The Ohio planes used Stanley numbers with an "O" prefix and they used tapered blades that were thicker at the cutting end. I like the couple of Ohio planes that I have, but they parts mostly don't interchange with similar Stanleys.
bmwrd0
Beaver Fever Oregon
Interesting. Thanks, Jim, Ohio was an idea I had but wasn't sure and didn't want to jinx myself on it. I have a #5 that might become a parts donner, as I like this one, and the SW blade does not work at all!
I have a couple of 2-3/8” wide tapered blades, probably for woodies, that might work. Let’s chat later in a PM
milkovich
Akron Ohio
One of the cool things about tool hunting here in Akron Ohio is that there's a good chance that the tools were somehow related to the rubber industry. My patternmaker's vise supposedly came from Goodyear Aerospace (which Lockheed later bought). Here's an estate sale No. 4 handplane from the "type 17" ww2 years which isn't that remarkable except that it's a 4C (maybe unusual for a type 17?) and under the rust was marked BFG 3990.
