Be careful with the load on that. That's a metric **** ton of leverage on that hitch. Most class 4 hitches are only rated about 1000-1500 lbs, but only about 1ft behind the hitch. Without doing the sum of moments on that hitch, your capacity is probably significantly less than the crane before you bend the hitch. I limit myself to about 500lbs on my receiver crane.
Mini smoker for when I just want something small while having a beer. Not done yet though
Not 100% happy with how all the weld turned out, but it is done and functional. I ground out some weld and replaced it. Picture on the bench is before I ground out some welds and redid them. I also shortened the part that goes into the truck hitch.
Yep I am curious what will fail when something does. I am debating adding a second receiver where the center tail lights are and having a second mounting point to eliminate the twisting. If I don't I will just add a plate that bolts to the top of the bed and is welded to the pipe.
Also I shortened the part that goes in the truck receiver over a foot. I used a section of square tubing and cut it to length after it was done. During use the vertical pipe is about 2" from the hitch now so the total lever arm is a little shorter, but still long.
Actually the hitch has no rating. I called the bed manufacture before out of curiosity and they did not have a rating for the hitches on the older design beds. They now use a b&w weld in product with a rating.
Now add your favorite singular & and miscellaneous compound four letter words here [and call for Tylenol and bandage delivery about now too if not already on hand, (what were you thinking not bringing those
)]! Thank You for sharing your project! Harry......................... but I see enough room above your center marker for a central one right below the bed, [we may be saying the same thing here].......................... Harry
add a trailer tongue jack to it and support it on the ground. If you really want to get fancy add to to triangulate it.
Not knowing how to weld I ask when I see that Blue "rainbow" color adjacent to the weld does that indicate that you have proper heating, and maybe proper penetration ?
Thanks Mike. So what I get from that is when I see that rainbow there was good gas coverage of the area when it was welded, and that my gas regulator was adjusted properly.
Wanting to make one or two welding carts.
I picked this up today for $70.
Thinking about using it two different ways.
#1 Use as is and put a welder on each cabinet. Add supports for leads as needed.
#2 Separate into two different cabinets, one for each welder.
Either will need modification to hold a full size cylinder (330CF) or two.
Pros....cons.....ideas?
I'm leaning towards separate cabinets. The double cabinet method will end up being a large cart, dragging two cabinets, 2 welders and 2 cylinders around.
Separate cabinets will work out better, with one exception. The smaller cabinet may be too top heavy with a full sized cylinder unless made wider for stability.
Bill
Thanks again. One of these days I will have finished the Home remodel, and intend to make an attempt at welding. Just yesterday while cleaning out an old bed frame the wife thought I was going to toss it. I saved it thinking I could practice welds on the steel.
My experience has been the opposite. I have cut up and welded 3 different frames for a variety of projects using .035" flux core with my Lincoln 180 and have had absolutely no problems or complaints.Iirc most bed frames are pretty ****** to weld with.
Reminds me of thisThe colors are not only indicative of what color the parent material reached but also how effective the shielding gas was at protecting the parent material as it cools.
Bill
Reminds me of this
