Absolutely! That one looks nice! Should be an easy restorationImpulse buy. Again...
Absolutely! No questions asked.I'd class that as Automated Acquisition...
What would you do for a restoration? Would you sandblast and paint?Absolutely! That one looks nice! Should be an easy restoration
You are correct. Sandblast/ paint and then treat the bare metal surfaces. If I ever find one I want to paint it a dark blue and highlight the words in white or gold.What would you do for a restoration? Would you sandblast and paint?
I'm working on a 5169 right now but im stuck when it comes the paint color, im trying to find something close to the original color.
Amazing piece there Hoorn! Well done@SquareWave I've never used a sandblaster on any of the Reed/Craftsman vises I've redone. I wire wheeled, filled in any deep gouges with JB weld and sanded smooth. I like red oxide primer and in all these examples I used Rust-Oleum satin midnight blue and a paint pen for the lettering. Rust-Oleum navy blue is also a very good match for that 1940s Craftsman color.
I'm currently restoring a 1939 Walker Turner lathe. I've had pretty good success removing the old paint by covering a part heavily with Citra-strip. I'm always looking for ways to work smarter, not harder, and hosing off the Citra-strip after several hours or the next day with a high pressure hose then immediately drying it is so much easier than breaking out an angle grinder with a wire wheel attachment and a mask.
Wow, I didn’t notice that. Well in that case even more well done! I have never even found one in the wild and you have 4@Smokeshow69 thank you brother, those pictures are actually four different vises, with one repeat. Two 5181s, a 5183 and a Reed 104 1/2.
I love how the tool states for polishing but you almost never see them set up for polishing. It’s usually for wire wheel/bench grinder purposes which is always sketchy looking
That vise looks great the way it is.What would you do for a restoration? Would you sandblast and paint?
I said Millers Falls primarily because I've had a number of Craftsman BB marked block planes that looked like MF rather than Stanley. I have a Stanley brace of about the same vintage I'll dig out tomorrow to compare.Nice find!
My notes indicate BB is Stanley? Can you compare features one to the other makers?
MF manufactured the planes themselves; I have always wondered why they chose to enter the plane business as late (1929) as they did. They continued making some into the 1970's.Now a key Q: who made the planes for MF? They also resold other brands.
But my source could be off too: Full notes:
BB = Stanley, ca. 1939 - 1950 (This code only found on amber handled flat blade style screwdrivers, and a block plane; phillips screwdrivers of this same style and time period were found to have the I-circle code)
Also this note:
F-circle = Miller Falls, ca. 1949 - 1964
So likely to be a bit late for Long C if its really MF? (and the date range is right for MF)
