The ram was really stuck in the cylinder but I got it out. The seal was completely destroyed and the white back up ring is swollen a bit. Unfortunately, the new white back up ring that I have is different than the one that is in there. Also, I ran across rust in one spot inside the cylinder. I don't know why it's just the one spot but any suggestions on what I can do about the rust? Would fine steel wool be bad to use in there? I also need to find a new white back up ring and dont know if I can buy this individually?
The rust is obviously where water sat, more than likely due to the Angle. On the plus side... It's appears High on the cylinder so shouldn't interfere in the sealing zone, it will have to be cleaned up/rough edges removed to prevent damaging the New seal during installation. It's possible to buy the heel plate as a individual item, for the reasons stated... I always reccomend that you tear the Jack down prior to purchasing parts, this way you can order all necessary parts in one shot or worst case scenario end up with a unusable kit due to internal damage that isn't worth fixing.
