This week's update, electrical work complete, house upgraded to 400A service and a separate panel put in the garage. HVAC mini split installed as well as garage door.
This is why you have to be specific with contractors. They mounted the lights all horizontal when the majority should have been vertical. They simply followed the studs rather than consider light distribution. Superintendent forgot to give them my diagram.
Here they are corrected. This also shows the 18x10 insulated garage door. I had windows added to the top to allow daylight in. That a long with the back window are plenty to work in the garage in the day time without lights if I want.
Liftmaster 8500 jackshaft opener is the stuff. Super quiet. It does all the fancy remote control via cell phone and all that, but I don't really see the point in that but whatever. I just wanted something that kept the mechanicals out of the center of the ceiling.
The computer program I used was recommended by folks here for the light layout, quantity, etc and it was spot on. 12 T8 4 bulb fixtures with two banks on separate switches worked out great. I had to turn a few fixtures to clear the attic ladder and space for lift in ceiling.
NOTE: The Lithonia fixture in the program was the closest I could find to the Utilitech I actually used. The Lithonias at Home Depot use a ballast that interferes with radios, and supposedly the Utilitech won't have that issue. I need to test, but fingers crossed.
http://www.visual-3d.com/tools/interior/default.aspx?id=14782
You can also see the mini split air handler back by the restroom door in the below image. It's silent and does a great job keeping the space a comfortable temp and insulation isn't even in the attic yet.
Here's what it looks like from the outside now during the day - trim work around garage door is scheduled for early next week to finish that off.
And at night:
The cans are on a photocell so they come on at dusk and turn off at dawn automatically with LED bulbs. I will set the house up the same so the eve lights all come on and off at the same time for a nice uniform look. The photocell is wired to a switch so I can just turn them off if I choose.
Up next - attic insulation, garage door trim, final touches on electrical, diamond grind and epoxy floor.
