machine_punk
I got some time in the studio this weekend.
I've mentioned that I recently got into arc welding with the Lincoln 210 MP. I'm the sorta guy who likes to be prepared, so I picked up some spare consumables at the LWS. I prefer to use the Local Welding Supply, if I can. I have an account there (even though I always pay cash) and the salesman usually gives me a pretty good break on prices. Now that I know most of the guys there, I usually walk in with, "This is what I can get it online for, can you get close to that?" Even if it is a few dollars more, it is worth it to me to shop locally.
Here is a picture of several things, including the fishing tackle trays I use, for now, for TIG and MIG consumables. I'm going to do something different than this on the welding cart I am designing, but you'll have to wait to see what that is.
When I learned to TIG, at Contour AutoCraft in England, They had a jelly jar full of sharpened tungstens, so we didn't have to stop and sharpen one, if we messed it up. I like the idea of keeping several, sharpened tungstens on hand, now that I finally have a TIG welder. I assume they used a glass container to prevent contamination of the tungstens. I was not enthused about the idea of a glass container in my own shop. I don't seem to have a very good track record of keeping glass from being broken in the shop.
You can see below, in the bottom right of the picture, that I started with a cutoff bottom of an isopropyl alcohol container. Well, that is fine for while, but totally unacceptable in this studio as a long-term solution.
My requirements for a tungsten holder:
- made of a non-breakable material
- will not contaminate the tungstens
- Able to hold any length of tungsten, as you grind it shorter and shorter.
- Able to easily identify which type of tungsten is in the holder.
This means it cannot be steel or aluminum. I considered copper, but wasn't sure if that could cause issues with contamination of the tungstens. I've been stumped about what to use for the last couple of weeks. Then, today at Home Depot, I figured out what would work.
View media item 64421
PVC pipe. These are the two tungsten racks I came up with. Not the prettiest material, but easy to work with and easy to glue together. I've gone for an unconventional use of PVC glue here--**** joints. Certainly not recommended for pipes carrying water, but I think it will be more than strong enough for this purpose.
I think this meets my requirements. I've certainly never heard of tungsten contamination by PVC. I cut a larger (1.25", 30mm) PVC pipe in half to use as the base and thinner (3/4", 19MM) PVC pipe for the vertical tubes. I cut the tops of the pipes at a 45-degree angle (not sure what that is, in metric
). I coped the bottom of each pipe, with my oscillating spindle sander, to match the diameter of the base. I made the tallest pipe to hold new tungstens (7", 175mm) and the shortest pipe to hold the shortest tungsten I could imagine being effective in a TIG torch. For reference, the tungstens in the middle pipe were cut in half (3.5", 90mm). Now, I just need to do something about identifying which type of tungsten is in the rack.
View media item 64423
This is an awkward picture, because they are still upside-down, at a weird angle, on the wires I used to hang them while painting them. Here is my solution to "which tungsten is this?" I simply painted the racks the same color as the end of the tungstens are painted. Now I can tell, at a glance, across the studio, how I am doing on any given tungsten.
View media item 64419
I've been on a roll with painting lately. I take a fair number of my tools to different events, such as Metal Meets, and I like to be able to quickly identify them and hopefully prevent others from confusing them with their tools. So, everything that might leave the studio on a trip gets The Aerodrome Studio Skunk Stripe (yellow, with a brown stripe down the center). The goal is to be able to quickly identify my tools across the room. I wanted to just use brown, because I haven't seen anyone else use it for tools, but it is not bright enough color for this purpose, so I use yellow with brown.
This is a Harbor Freight 5-Drawer Service Cart, which recently became the storage cart for my welding tools. Here is a drawer full of my welding wrenches.
"Welding wrenches?" you ask.
Yes. I don't like those inexpensive, punched steel wrenches they sell to people who weld. I made a list of all the wrench sizes I need for all of my welding equipment, went to the flea market, and bought one of each. I bought the two largest ones new, from eBay, because each end has a different size, but both sizes are used when installing or removing a gas regulator on a cylinder. You also see a couple of grinder spanners in there, since I use my grinders a lot while welding.
View media item 64420
Here, you see some more painting silliness. My goal is eventually to have just about everything in the studio matching the theme in one way or another. I want it to be a place full of stuff I like, which inspires me to be creative on my projects. Here are a couple of standard quart-size (1100 ml) paint cans I use to store borax and boric acid.
I originally thought powdered brazing flux was mostly borax, so I got a box of the commercially-available washing powder. Then, I read a little more and figured out it was actually boric acid, which is the primary ingredient in borax. We can buy this in bulk in the US for pest control. Roaches really don't care for boric acid. I've gotten in the habit of pouring some under any base cabinets I install, to prevent roaches in the future. Anyway, bulk boric acid is even cheaper than brazing flux. I just needed a can to keep it in. Since this is The Aerodrome Studio, it couldn't just be a plain can.
I know the painting in theme colors is a little over-the-top for some, but I grin every time I see it and it makes working in the studio a very personal and pleasing experience. And yes, I am aware of the orange-peeling on the borax can. I haven't had that happen before. The paints are the same type from the same manufacturer. I may fix it someday, but for now, it just adds more character to the studio and gives me something to tell a story about.
View media item 64418
I did also run a temporary compressed air hose this weekend. It is the BRIGHT orange hose you see in the first picture. I want to install one of the aluminum pipe kits eventually, but I want to focus on upgrading electrical first. So, this is just a regular 3/8" (9.5mm) air hose I strung along the wall, from the workbench to the compressor, with "J" hooks screwed into the wall.
That's about it, for this week's update.
#ContourAutoCraft
#Lincoln210MP
KDub
#ContourAutoCraft
#Lincoln210MP
KDub
