The Everything 3D Printer Thread
mike93lx
Richmond, VA
My printer is finishing the last of the sample filament that it came with (600g)... two 1 kg rolls of PETG were delivered today and a dryer is showing up Wednesday. Unfortunately, I have to snap back to reality tomorrow morning and do some real work🙁
Should have bought a printer a while ago
I got my 10 year old to sit down with tinkercad for a bit and he made this. Begged me to scale it to fill the print bed 😂. A 37.5mm wrench is always useful to have around, right?
slodat
Central-ish, WA
My original X1C has become unreliable. I replaced the complete hot end yesterday. All seemed well for about an hour of extruding PETG. Now it’s not extruding at all. I stopped the print and pulled out a few feet of filament and cut it off. Started over and same thing. Printed for an hour or so and it stopped extruding. The old hot end was the original almost three years old. Not sure what to look at next. Any pointers from someone who knows more than I?
ptt49er
Rock Hill, SC
Try a different roll of filament. We've had a couple of rolls just do some really strange stuff when printing.
ArcReactorKC
Out in the county NE of KCMO
How many hours does it have? Very possible you have wear through on the PTFE from the external spool or AMS.
ER70S-2
I caved and bought an H2D yesterday as I wasn't sure if the price was going to go back up after the new year or not. I got the last one at Best Buy in Delaware, so tax free. I contemplated it for several months and it seemed like a good time to buy. The H2C is completely unnecessary for me as I only do functional prints.
Obviously the build volume is larger than my current Prusa and I'll be able to print more advanced filaments, the chamber is heated, it will be faster, etc., etc. All that stuff is obviously better, but print quality is the most important feature to me. I really hope the print quality exceeds that of my Prusa. If it does, I'll be happy.
RichieP_MechE
Near Pittsburgh
Experimenting with 3D printed press brake tooling. Works surprisingly well. PLA, 20 walls, 50% infill. The test piece is 16 ga steel.
I've got a short video of the action on instagram:
Followup post: finalized die design for a production run of Christmas gifts. This is a spoon rest made with a combination of the 3D printed dies and standard press brake tooling. Material is 16 ga 304 stainless steel. Top punch is ABS because that's all I had on hand when I started the print, bottom die is PLA. Each are 25 walls thick with 50% triangle infill.
Also cut together a video of the fabrication process (relevant 3D printed press brake die content starts about 55 seconds in)
mike93lx
Richmond, VA
That's awesome
jeepxj
How do you log failed VS successful? What's driving the cancelations? Assume thats a failure that gets noticed before it finishes?
Theres QR codes on the front of each machine. operator taps for RFID chip or scans QR code:
Brings up this window on device:
If failed is selected the plate isn't counted towards production for the queue job. in this example 5 print jobs. it would send the retry one to the next printer free.
all the canceled prints were me testing things out with the queue logic.
mike93lx
Richmond, VA
Nice setup.
Is a failure rate around 10% typical? What's the main driver?
Are you drying filament before running it?
jayz66ragtop
SoCal
Had this same issue on my X1C and it turned out I got three spools of bad filament. Tried a totally different filament ( PLA from Bambu ) and it printed perfectly, switched back to one of the other spools from amazon and it acted up too so I returned all three spools.
ArcReactorKC
Over 20 printers for production parts we are at 4-6% failure. Usual issue is poor first layer adhesion because I don't clean the plates until I start to see severe issues. I'm sure the failure rate could be reduced by the time/payoff isn't worth it.
jeepxj
we find most. like 90%. of first layer failures are due to a bad Z offset during bed probing due to a little bit of filament stuck on the nozzle tip.
burger
Erf
I'm a few weeks into this 3d printer game... how do you clean your (printer's) nozzle?
jayz66ragtop
SoCal
Finally doing the first print with the H2C! I promised the boss I wouldn't setup the new printer until I rearranged the office and came up with a better way to store filament. Having spools stacked up like the leaning tower of Pisa is probably not the best way to do this, especially when you have four stacks almost waist high. Bought a used two drawer lateral filing cabinet and it's almost perfect, I wanted a three drawer but glad I didn't get it because it would have been too tall for the space with the printer on top.
First print is a poop bucket because of the new arrangement the one I had for the X1C is too big to git between the back of the H2C and the wall. First observations, it's much quitter than the X1C except when it's changing print nozzles and takes a lot longer to heat up the chamber. Other than that, we'll see later this morning on print quality, it's auto leveling the bed now.
ER70S-2
Nice! I'm doing my first real print with my new H2D right now. So far, so good and I'm not really concerned about saying bye bye to Prusa. They are just too far behind at this point.
Anyone have thoughts on a high temp filament dryer? I was about to buy an AMS HT, but now I'm thinking about a Sovol SH03.
mike93lx
Richmond, VA
I just bought a sunlu s2 and dried a roll of PETG last night.
The s2 and s4 seemed well regarded in searches and it was only $45.
PelicanPines
Watched a few videos on the Sovol SH03... If I needed one... That would be my goto choice.
