The Everything 3D Printer Thread
Keyblazer
Irvine, CA
These are the two Cura generated rated “Flow Towers” I printed.
Left is before I changed the e-steps, and right is after.
Nom clue if there are clues there..🙄
Jswain
Calgary, AB
I'm not sure if you mentioned what speed you are trying to print at, or what speed you previously printed at but you will likely need more heat to print at 160mm/min versus 50mm/min if that's the case. You are pushing over 3x as much filament through the hotend as you did before...
And if you're already maxxed out with a normal hotend that means all metal w/ a new thermistor.
(I've never run clipper and usually print PETG ~50 but I now to go from 25-50 required quite a bit more heat)
ArcReactorKC
Out in the county NE of KCMO
The stringing is really rough there and is negating really any ability to read those completely accurately. Was your machine stringy before the extruder change? For what its worth I've put a ton of the cheapo amazon red metal extruders on a bunch of printers. They are cheap, and a little rough around the edges but for the speed capability of a bed slinger they seem to be fine.
Did you say you changed the e-motor? What is the possibility it is a different degree motor? What control board and stepper drivers does your ender have? You may need to adjust the current on the driver or, it could be failing.
Have you removed the nozzle and told it to extrude through just the empty heatbreak?
Keyblazer
Irvine, CA
Will do.
I pulled off the extruder.
Stepper looks and is designated the same.
Close up exam of the extruder, didn’t tell me anything. Just some filament dust.
Everything moves as it should.
harley jim
Cleveland Tn..........out in the sticks
Hello everyone, I just set up my first printer and I'm starting the setup of a laptop to use with it. I dont have a clue of what I'm doing but I want to learn, and several people have said this is the thread to watch and learn from, so I'm here and have been reading everything, I have an Ender3 and I'm going to install fusion 360 on the laptop, Jim.
bugnut
Central Ohio
HJ do not know if you have fiddled with fusion and don't want to engage in a debate but found that for folks without any experience, sketchup and the youtube tutorials made it easier for them to quickly get models drawn.
Also go to thingiverse and other similar places as a host of already created pieces are ready to download and print!
86turbodsl
Been watching this thread for a while, i have an Ender3 i haven't setup yet. I'm a very experienced CAD guy, using Creo daily. Does anyone have any experience using Octoprint or equivalent? I'm not going to do the sd card shuffle. I picked up a few old HP thin clients i want to deploy one of them for remote control. I have no experience on the slicing and printer side of things, but general knowledge of cnc i do have.
Mark_17
Octoprint and the other slicing programs are very similar (if not identical). With your CAD experience, you won't have any issue navigating them, they are very simple and straight forward.
A few minutes on youtube and you can learn how to do all the basic setups in Octoprint and add multiples to the same print etc...
nicholam77
Minneapolis, MN
I would highly recommend watching some 3D printing overview / basics tutorials on YouTube. I'm sure there are tons geared toward the Ender 3 specifically. I'm sure people on this thread will be happy to answer questions but that's probably the fastest way to get up to speed.
In a nutshell to print something you need:
1. A 3D model, usually in the form of a .STL (mesh object) file
2. A "slicing" software program to translate that .STL model file into g-code the printer can understand
3. Save resulting g-code to your printer's SD card
For the first item, I would highly recommend starting with pre-made models from the internet vs. designing your own, unless you already happen to know Fusion 360. Some common websites to browse and download models (in STL format) are Thingiverse and Printables.
For the second item, there are multiple free Slicers out there, probably the most popular being Ultimaker Cura and Prusa Slicer. I use Cura so I can only speak to that, but Cura has a preset printer profile with appropriate settings for the Ender 3. Again... YouTube how to set up an Ender 3 printer with Cura and you'll get lots of hits. Also watch a video on how to slice a file in Cura, and you'll be off to the races.
Fusion 360 is awesome if you need to design your own stuff, but not essential to 3D printing if you are able to find models you like online. If you're trying to learn Fusion 360 and have no CAD experience (like me), be prepared for a fairly steep learning curve.
Hope that helps and good luck!
Octoprint is great. I'm running on a Pi Zero 2. Not only do you eliminate the "SD card shuffle" as you put it, but it has a ton of useful plug-ins, from webcam monitoring, mobile app notifications when your print finishes, bed leveling, etc. Octoprint allows for remote control off your network with Octo Everywhere. There might be other solutions, too. Highly recommend.
Keyblazer
Irvine, CA
Welcome to the Madness Jim.
I’m kinda new, too but totally addicted. I started with an Ender 3 V2, added an Ender 5 Plus, and now working on building printer #3, which will be a hybrid Ender 3 V2, with a lot of mods per my last post.
For me, the most important thing to learn/understand/ master is bed leveling. Get that down and you are 75% there.
Thingyverse is an awesome place to start.
I’ve found, and printed so many projects from there.
For me, the fun part is making the printer, print itself updated parts!
Last couple of days it’s been printing upgrade parts for my Ender 5 Plus.
Front “Drop Bar” relocation brackets and frame stiffeners.
I have about 8x more stiffener brackets to print now.
Welcome, and go for it!
Keyblazer
Irvine, CA
I like these for calibration on my Creality CR-6 SE. https://www.thingiverse.com/thing:1278865
Try printing one really slowly, they only take 10 minutes or so.
Actually, I’d done a test cube when I’d first set up the printer.
This was the result, that looked good to me…
So, after messing with the this extrusion issue for hours, I decided to swap the Red unit, for the Silver “Official Creality All Metal” extruder, that just arrived.
I wasted a no time fitting it…
And the results were obvious…. Visually and audibly. No clicking, just prints.
Here is the Cube I just printed.
302C638F-B3B8-49EE-A85A-E9D56C3A318A.jpegNext to the one I printed before I added the new extruder…
I don’t think it’s perfect, and I would welcome input.
Edit:
Ah, Looks like the part cooling fan was not switched on...
So clearly there is/was something wrong with the Red Version… I don’t know what it is, but the results speak for themselves.
I will be returning it.
Buyer beware.
I will run that same flow tower, and post results.
Jswain
Calgary, AB
Edit:
Buyer beware.
I use that same red one, no issues. Perhaps your cooling fan is cooling your nozzle too much and that's why you had no clicking....are you running a silicone cover?
slodat
Central-ish, WA
The X1 arrived today. Fair warning… lots of photos are coming, I’m sure. My five minute assessment is it is awesome! Literally did nothing but power it up and load filament.
This is a test print that comes loaded on the printer. The orange is Bambu PLA that came in the box. The black has been open and on the shelf for at least 18 months.
It is truly difficult to believe the quality of this print. Top and bottom. And, effortless two colors! I’ll put the machine through its paces seeing how it does running my parts.
Initial impression is it’s a very nice machine and appears to print well out of the box. Printing a bin now. I’ll load up ABS after it’s done and see how that goes.
Screenshot from the ap while I’m out getting a bite to eat:
harley jim
Thanks everyone, that's some good advice. I did cad design at the fab shop, unfortunately it was Draftsight which was canceled by Dassault systems. I have been on youtube watching lots of video and taking notes, I have some downtime coming up starting next friday so I'm going to be studying hard.
Keyblazer
Irvine, CA
That Bambu printer looks gorgeous.
What do they cost?
Yes, running a sock.
That cube looked ok, So I decided to try a print I’ve been waiting to print for a while.
Makita battery charger wall mount.
Set it off about 5pm last night.
I checked it, and it seemed to be going ok, there was no clicking from the extruder, but I did notice some brown patches and little stringy bits of the blue Meta PLA that looked burnt as it laid down the base.
But when I got up this morning, it was finished printing, and this is what greeted me…😬
I guess I’m at a loss at this point.
I will check my extruder calibration again this morning, and report back.
Maybe I messed something up in Cura….
Edit:
I didn’t spot til just now that it looks like there was a X shift too. Weird.
jayz66ragtop
SoCal
X1 just did this after printing the first layer:
If these features work well, it could bode quite well for process reliability.
Yup, that's one of the features I really like. It self inspects and makes adjustments on the fly.
If you haven't already have the printer check for updates. There was one that came out mid Decmeber so your's may not be running it.
slodat
Central-ish, WA
It prompted to install updates on the first power up. It's running the latest stuff. I'm very impressed with it so far. I need to get it dialed in running Overture PETG and I'll be quite happy with it.
The AMS screwed up when a roll of filament ran out. I had to disconnect a few PTFE tube connections to remove the filament. Not a big deal and it didn't scrap the in progress print. Hopefully the run out piece is reliable.
Jswain
Calgary, AB
What do they cost?
Edit:
Maybe post some screen shots of your slicer settings
jayz66ragtop
SoCal
Oh, ok. I think mine did an update as well after connecting to the WiFi but couldn't remember. Funny you say that about the PETG because since the last update it seems ABS and TPU print fine with the default setting but the PETG I have doesn't seem as happy with the default settings. Since I had ABS in the same color I just switched to it after the first small part acted up.
Interesting about the PTFE tube. I ran out once in a print as well, I think it did have to tell the AMS to unload the filament and pulled it out after disconnecting the PTFE tube that goes from the AMS to the printer.
I think I mentioned it before but head the warnings on the FAQ and don't trying to print TPU through the AMS. Trust me, don't do it... I got lucky and was able to get it out without issue but others had to take the AMS apart to get all the filament out.
jayz66ragtop
SoCal
My Bambu arrived on Thursday, very impressed so far although I have had limited time to play due to business commitments. I hope to start catching up here next week…
Awesome! Hopefully you have as much good luck as slodat and I have with it.
I should have gotten a referral fee or something LOL
slodat
Central-ish, WA
It took me considerable trial and error to get results i could live with running PETG in the Prusa. The only real trouble I’m having with it in the X1 is the 5% gyroid infill. It’s.. soft. I don’t know how else to describe it.
Agree! Your posts are why I bought the X1.
Keyblazer
Irvine, CA
Anyones you have adjusted
That’s kinda my issue.
I don’t remember changing any slicer settings.
If I remember correctly, all I did was change the nozzle setting in the top bar Cura menu to a 0.6mm.
Ran two “Retraction Tower Tests” first yesterday.
Both were from the Cura Extensions menu.
This one is the simple one.
Pics are front and back of the tower.
Then I ran a more complex one, called “Retraction 1-6”.
I don’t even know what that means… LOL
Result.
So, I swapped to white filament, and checked the extruder calibration yesterday.
This is what I did.
Marked the filament, where it stopped.
Pulled it out, marked 100mm and 120mm
Reinserted.
Set the Creality pad to preset heat the nozzle to 200c.
Found the Extruder menu, and advanced it 100mm… because 100 is not an option, I did 4x 25mm.
This is how it looked.., under extruded by maybe 5 mm.
So. Basically, it’s still under extruding?
Will try to adjust the E-steps today.
Keyblazer
Irvine, CA
Well, I thought I would run a calibration print while I had the white filament in.
As soon as it started printing, I was confused. Big blobs of the previous blue filament in the white, on the second layer,long after it should have purged. Some of them were burnt looking.
Extruder started popping again.
Layers looked weak, so I stopped the print.
Thought I would clear the nozzle and purge the hot end.
As I looked closer at it, I spotted blue, thru the fan… where there should not be any!
Pulled of the fan shroud to be met with this.
I’m confused where this filament t came from.
Maybe I didn’t get the Bowden tube seated properly, or is there another issue?
Pulled it all apart.
Screws holding the hot end to the upper heat sink/cooler were not very tight.
Would this cause my print issues? I hope this is it.
At this point, I’m thinking I’ll just replace the whole hot end with a better one.
Wondering if I should go Direct Drive too.
Want to try TPU at some point.
My Ender 3 Creality direct drive unit has been flawless.
Looked at Microswiss, and the new NG looks super neat, but I don’t see how you can mount the BL Touch…
Opinions?
Black300zx
Elkton, Md
So I spent a couple days scratching my head with some really bad lamination quality on a set of parts. These are replacement slider bushings for the seats on my boat which are no longer available from Grady White. I made myself a set about 3 weeks ago which printed flawlessly with the PLA filament that was included with my Ender3 Max Neo. They fit "good enough" but I wanted to make a few minor refinements before offering sets up to others who need these parts.
I finally realized that my issues started when I switched over to a fresh spool of filament because the original spool didn't have enough left. I switched back to the remainder of the original filament, printed about the first 20% of it, then loaded up a spool of black PLA that I had been using for everything else. Boom - perfect prints again.
The white spool of Overture PLA was brand new in a vacuum sealed container. Did I just somehow get a bad spool of filament? The all white parts have some terrible delamination with laminations literally separating if I gripped them about as firmly as I'd hold a pencil. The white/black hybrid parts started off with a different spool of white PLA and then changed to black. These parts are the quality I'm used to. Both printed with the exact same gcode file.
Jswain
Calgary, AB
You may need to adjust settings for the new brand of filament, or you may need to dry the filament
Black300zx
Elkton, Md
Same brand, purchased and opened at the same time and stored right next to each other. I'll play around with temps a bit to see if I can't get that spool working right
slodat
Central-ish, WA
Printed a poop shoot for the X1. This is a tall part and it turned out nice.
And, drawer labels for all the drawers in the shop.
I am so happy with these. I used red for the contrast color because it's the only color I have in PLA. These are nice. On the build plate fresh out of the printer:
This shows the magnets on the back.
And, installed. I will be making a lot of these over time.
