Jehannum
Made another drill bushing, as I need to center up a 1/4"-20 hole in a couple 5/8" dowel pins on the back of the 455 in my GTO (need .007" offset pins in place to fix the >.010" but <.011" total indicated runout of the bellhousing for the Tremec 5 speed). Gotta pull it out, and my first idea (3/8-13 allthread welded on to the end of the pin and used as a puller) wasn't feasible for my Lincoln 135 welder at highest voltage and lowest speed. Couldn't get enough penetration even at the highest voltage and lowest feed rate.
New plan is to thread a hole in the pin for a 1/4-20 bolt, and then use a washer, a pipe ******, and a nut to pull it out. Space is kinda tight, so I'm using the drill bushing to center a right angle drill (not pictured) up to the pin.
