3/8" breaker bars: Pass/Fail. Every one I've had lasts about a year before the end eventually twists off - which is a pain in the *** if you're using it with an extension. On the bright side it's warrantied - in fact the first one I broke they replaced it with a 1/2" because they were out of the 3/8ths.
Impact sockets, deep-well: Pass/Fail. Occasionally you get one that has internal flaws and they crack instantly - I've had one and one store had several sets on the clearance table with one missing from replacements (one had a cracked one right there in the box). Otherwise, they're fine.
4" Grinder: Pass. The orange one died only because after 3 years of rough use it got some sand into it cutting away on some trans crossmember bolts. The blue one's lasted about 18 months now, rough use, no issues, and it was all of $9 when I bought it. By rough use I mean it stays in the back of the truck almost all the time, if I have to go out in the yard to cut up something using a generator it may get dropped in the dirt, mud, snow, etc.
I notice they cleared out the socket racks/shelves, looks like a new line or new packaging coming in for all of that stuff.
3/8"-1/2" combo ratchet: FAIL. First thing I tried it on, a clean bolt, stripped it. Clicks sound like the guts could be plastic. I only bought it because it was on sale and I promptly returned it. (I looked at some ratcheting box-end wrenches recently and passed because they sounded the same when clicking).
Hand riveter set: Pass/Fail. I've gone through three of them; the jaws slowly strip out, they're made for doing like one job. I suppose if you strip the jaws for the small 1/8" rivets you could step up a size and keep going; the last one I used the large rivets until I used them all up and it worked okay. They did exchange it no problem, but I haven't seen them in the store the last few times.
18V cordless drill: Fail. Mine is an older one, but two things happened to it - first, the battery didn't last, it stopped taking a charge after a few months. I had a 14.4V that lasted much longer (had about another year in it at that time) - I only bought the other one because it was cheaper/faster than driving home to get the one I forgot that day. So it sat in the back of the truck and one cold day I opened the door, it fell out, fell about 3 feet to the ground and the top half broke right off at the button. While it worked it was fine, it would be a good disposable piece, but plan for it to not last forever.
14.4V cordless combo kit: Pass, more or less. I see these seem to no longer exist. I had no issues with the kit other than I now can't replace the battery that after several years won't charge, and when running the sawzall to cut metal it only lasted about 10 minutes. After pricing out better quality kits, I just bought a cheap 1000W generator and use the regular tools.
Magnetic tow light kit: Pass. The only problem I have with the damn thing is it's wired backwards so the wires stick out the wrong side of the right light to go across to the left light, some one of these days I'm going to remember to pop off the lenses and swap them side for side to fix that. For $10 with coupon they're hard to beat, I've even used them as trailer lights.
