Gorgeous work!
DOC!!!!!
Wow, didn't know you were on here!!
Good to see you are still doing your thing!
-Still doing all kinds of things!Comics, machinework, muscle cars, photography... Oh yeah, and the paintball thing.
Not that I want to, you know, brag or anything.
Doc.
Or is it that those that are really serious are still in it, but not too many weekend players are starting up?Is paintball still really that big? Seems to me like it died down from what it was ~10 years ago.Or is it that those that are really serious are still in it, but not too many weekend players are starting up?
-Well, at the risk of derailing this thread, yes and no.
Like most businesses/industries, the sport took a pretty big hit in the Recession of 2007-2008. At least a couple fairly large companies went belly-up, and I'd bet general participation fell by at least a third.
But, that was a third of some 15 million players a year. A big hit, sure, but not fatal.
We're not yet back up to pre-Recession numbers (then again, who is?) but things are definitely on an (admittedly weak, but definite) upswing.
Speaking personally, prior to the Recession, I did basically nothing but paintball work, and had more business than I could handle, with months-long waiting lists. Post Recession, I had to branch out into general machining and repairs just to keep the lights on- hey, I make what are basically toys. It's one the first things a kid's gonna drop if it comes down to food and rent, or playing a game.
And since then, the percentages have varied widely- for a few years there, the majority of my work was general/repair, but at the moment, I'm probably back up to about two-thirds being paintball work.
More generally speaking, yes, there's more than a few companies that make several million a year in sales of just paintball gear, with at least three or four knocking on the door of $100M a year. It's no longer a niche market, and hasn't been for well over a decade.
Doc.
Thaxboyd, MUCHO respect for you guys that play with gears!
WOW... I have someone who respects me![]()
Just a couple of additional pictures.
Put up some pictures.I have a couple of 20" Delta bandsaws that each had a missing upper blade guide. I had several of the DoAll blade guide you pictured, so I also modified them and made mounts for the saws.
that's some nice work!My dad needed a new cable-drum for his antique clock. This is the old setup:
But the drum crushed and solder came apart:
I wanted the new one to be supported (contact the shaft) at both ends without relying on being soldered to the ratchet-ring to hold it up, but I also don't want it to be solid brass for weight reasons. My solution was two hollow ends pressed together:
Turned down as needed then for style points I put a radius in each end hill-billy style (big hss Weldon style ball-endmill held in a toolholder)
Drilled a couple 1/8" holes and tapped one so that a small set-screw acts as a cable clamp, and it's ready to solder on!
MUCH more solid.
Sent from my B15 using Tapatalk
At 72-years old, I'm only just now learning to be a machinist. Though I've used my ancient Index Super 55 mill on a few slots, this is my first complex fabrication done mostly on the mill.
More.
