Thanks. The funny thing is I didn't even keep the first die I built during my apprenticeship but I hung onto this little guy. Definitely going to keep it around my shop.JJ--that should be displayed.
you meanLooks like a henweigh.
you mean
Like: what's a hen weigh ?
Yeah we do a lot of repair work for this company. They are a steel foundry/forge. I've heard their lathes/mills etc are absolutely massive.Looks like it would be an awesome band saw!
Sent from my SM-T230NU using Tapatalk
Fly cutters are cheap.
Oh god no. Half a degree or less. Literally you only want a thou or two of clearance on the back sweep.Ok thanks Like 5 degrees or ???
If it's setup correctly, it will be an almost immeasurable amount, this is SOP they teach in trade school for flycutting. Besides, if he is already having it cut on the back sweep and is "double cutting" with his current setup, then he is already dishing the part.Tilting the head might give you clearance
on the back side but it's going to dish
or concave the piece.
Yep tramming indicator is the easiest way.An easy way to set this up is to put the indicator you use for tramming your machine into the spindle. Now, bring the machine a thou out of tram by loosening the head bolts until they're just snug and giving the head a few whacks with a rubber mallet.
Re-sweep the table with your indicator to confirm you have a thou tilt at the diameter of your fly cutter and go to town. I usually make the left side of the cutter low when viewed from the front of the machine. That way I don't get showered with chips.![]()
We have some Robo drills at work but they just use them for drilling oil holes in the drive hubs in our department.I enjoyed going through this thread. Lots of interesting skilled people.
Here is a picture I took while playing with some crankshafts I made on my Robodrill.
Frank
Oil free two stage direct drive air compressors.We have some Robo drills at work but they just use them for drilling oil holes in the drive hubs in our department.
What are those for lawn mowers Or ?
I usually torque it to precisely 3 EGU (elbow grease units).Who knows what the torque specs are
after tramming a Bridgeport head?
I'm 6'3" so your elbows may be calibrated differently.Yeah, how big of a guy are you?
I'm just 5'6" so it might take more
egu's for me.
