The Tiny Tools Thread
nine4gmc
Dallas
Big *** Snap On :lol:
charlief1
Merry Christmas or happy holidays to those of you that don't celebrate. Nice little vice you're got there.
jpickar
I bought thses two small tools with a bunch of stuff a few weeks ago. The pipe wrench is make in Germany. It is 6" and the adjustable is made here. It is a "Sterling" No. 1, made by the Frank Mossberg Co. of Attleboro, Mass. It is 5"
Neat little tools that I will never use, but hey they are tools!
John
O
The sterling is a Bicycle version of the "Auto" wrenches (like Ford used to supply with model T's and A's
Nice finds!
O
A couple of additions:
These are now my smallest Ignition wrenches, one Bonny (stamped and it had the old Bonny sticker... I barely notice that was what the sticker said, I nearly wire wheeled it off!). The cool ones are the matching (sizes reversed) pair of Blue Point.
And a Little Oil can; I don't think its the smallest in the thread though, and a 4 oz Tinners hammer head.
O
The small ratchet is a Titan (Toptul) 1/4 drive next to a SO M70 1/4 for contrast and yes, that's a dime not my std quarter next to it!
nine4gmc
Dallas
I believe the Titan post but post 256 has got to be an over sized quarter :lol_hitti J/k good stuff Outlaw!!! :beer:
Outlaw, some tiny tools for your thread! Did some digging through tools in my garage today and came up with some great tiny stuff to share.
Williams Special 3/32" offset wrench
Vulcan miniature salesman sample working chain wrench(JH Williams Co.)
JH Williams Superrench Screwdriver #1997
Snap-On Tools-INC Screwdriver #H-50
Mavawreck
Durham NC
Picked this little guy up yesterday at a flea market.
Hard to see, but "2nd" is stamped over some existing cast lettering.
And the manufacture is ground out
Also has "Guaranteed" cast in the back of the the jaw adjustment on one side
jakemac
New England
While packing my truck to go mow a lawn tomorrow (5hrs each way, one day trip), I was dumping a bucket from the back of my truck to sort out some tangled ratchet straps. Out of the pile drops an odd bit of metal. It was a small vise with 1" jaws !
There are no marks on it, so I don't know who made it, and I don't remember when I picked it up. It could have been in the bottom of the bucket for at least 6 years !
jpickar
Here is a 4" Craftsman adjustable wrench I picked up yesterday.
John
wildbill23c
Idaho
Surprised nobody has posted the Dremel 580 4" Table Saw
Or the 2" Mini Cut-Off Saw
I try and look around several places when I have the time and money, for miniature tools. Haven't had much luck though here locally. I wish I had engineering and metal-work knowledge to build some miniature farm equipment like a small swather, baler, hay stacker, etc.
davethorik
Norka, Ohio
John
i love the cute little 4" adjustables. they seem to be uncommon...either nobody bought 'em or everyone broke theirs. not sure if I have ever seen a C-man.
Here is the one I found, Snappy (actually made by Diamond Tool & Horseshoe) at a yard sale, it is my first one. I love it, and actually use it a decent amount.
edit; this little guy is actually 4.5" oal, how long is your oal?
jpickar
Mine is 4.25 oal.
John
O
Took these pics last weekend and forgot to post em:
Additions to the tiny tool box collection - The big one is for contrast, its a std size weight sheet metal hammer, the small one is around one oz. head weight.
The mini duckbills are a no name pair:
Alan Douglas
Cape Cod, Mass.
This 3 1/2" block plane appeared in the neighbor's compost pile, a blob of rust when I found it, a little better after a soak in vinegar. It's probably too far gone to save, but I'll see if I can get it apart.
jakemac
New England
Cleaned, polished, and painted
I'm so happy! :bounce: Found my other miniature chain wrench, the one on the right. It was hidden in a Williams socket box :willy_nil but I'll be sure to keep them together now!
It's a J.H. Williams Vulcan BI JAW.
timdp
That is a jeweler's saw. For anyone planning on using one without breaking lots of blades, the blades need to be pre-tensioned. Clamp blade in one end, put the handle in your belly and the other end of the saw against the bench (blade up). Push against the bench with your body and tighten the other blade clamp so the blade is tensioned.
The other tip is to ALWAYS hold the blade vertical. Generally a V block is used to support the piece being cut. Saw in use with V block: http://www.micromark.com/jewelers-saw,6747.html
Tim
Here is a "Hack Saw" the blades have to be clamped, as they are too small to have pins or be pinned...
rlitman
Long Island
What an insanely weird method.
Here's the right way:
Loosen the three thumbscrews (the bow length adjustment screw needs to be FULLY loosened so that the bow is able to move around in both length and be free to pivot a few degrees).
Clamp the blade sticking straight from the bow end.
Adjust the bow length until the blade sits in the right position in the handle clamp, and clamp it sticking straight out (there must be a little curve to the blade at this point because the two clamps are not pointed in the same direction!).
Grasp the handle end of the frame under the fingers of one hand, and push the rounded button on the end of the bow firmly with the thumb to apply initial tension.
Tighten the final thumbscrew. This is where the magic happens!
If you clamped both ends right, the blade should now exit the clamps without bending (if it's kinked, you should start over and get everything straight, or expect to break blades quickly).
The magic? The bow not only slides in and out, but also pivots a little. When you tighten the thumbscrew it pivots the bow into the final correct position (where the clamps now line up), and sets the final tension.
Oh, and that wingnut at the far end of your blade: completely unnecessary.
As for working vertically, that's not necessary if you have the right hand control. I like to work with my work clamped in a panavise, and adjust the angle to suit what I'm cutting.
JUNK-MAN
PA
Some little stuff in my collection:
Little 0-1/2 Starret micrometer
Crescent 4"
Little wrench with 2 feeler gauges attached to it, one says "Plug" any Ideas on what it is and what it went with?
O
Junk Man, that's an ignition for VERY old cars. Usually there will be two blades; one for the plug and one for the points.
