Tools from the old world
DieCastElectrician
Ottawa ,Illinois
Schröder/Schroeder/Schroder depends on where you are from and if your monitor can display a "o" with 2 dots :);)
i special ordered it through a local dealer.
Maybe one of these adresses can help you:
http://www.searsoutlet.com/5-0-3-Po...h/d/product_details.jsp?pid=87392&mode=seeAll
http://chadstoolbox.com/rs40064-schroder-40064-ratchet-tap-wrench.aspx
http://www.tooled-up.com/product/schroder-ratchet-t-type-tap-wrench-2-5mm/16237/
http://www.crawfordtool.com/Schroder_4.006.0.html
http://www.amazon.com/dp/B001DZ6YSS/?tag=atomicindus08-20
...since you build a Hazet garage.... ;)
btw. here is a test of a DIY magazine: http://www.selbst.de/pdf/kombizangen.pdf
a buddies pipe bender set from Rothenberger:
Nice Bender
How Old Would You Say It Is?
Monte
Germany
Well, yes... but I don't want to buy only Hazet because of the brand. I like to try and own some other good or even better brands also.
Thanks for the link! Considering the testresults and the price I can get a 3-piece set for, it probably is going to be Knipex.. :bounce:
can´t go wrong with Knipex...it´s the pliers brand over here, they offer everything from A to Z and the quality is good as well as the design. And they have the "must-haves" like the pliers wrench and mini bolt cutter...
last hazet buy workbench and roll
Awesome !
difficult to say since the current bender looks the same, there are only minimal differences in coating of the parts it seems.
Steinel reduction nozzle for heat guns
cosmik binturong
.fr
a teaser of some Knipex/Würth/Mob/Unior stuff for sale soon:
there will be more... stay tuned! :D
aussieracer
After a couple of months break adding tools to my collection, I got the bug again a few weeks back. These are my recent additions.
Makita 18V LXT bits....started with just the drill and impact, and added the blower and angle grinder 2 weeks later.
Then some Koken stuff from eBay. Z-series 3/8" set, impact driver and 3/8" hex set.
Free pen and sticker... Also brought a cheap ar$e Rolson 1/4" extension set
Love the quality of this impact driver...can't wait to use
Need to buy male Torx bits next. Currently using Kincrome set that have WAY too much play/wobble. Preferably in 3/8", but not too long for tight spaces. Thinking Koken, but open to suggestions.
Mr MoAiZo
Germany
I'm a bit in doubt about upgrades my standard pliers (side cutting, combination and needle-nose).
Isn't there a recent comparison test/review available somewhere online?
The brands I'm interested in are: Knipex, Stahlwille, Hazet, NWS. These seem to me the obvious high end brands for pliers to chose from.
Stahlwille are rebranded VBW. VBW belongs to Stahlwille.
I would stick to Knipex, NWS and the Austrian-made Gedore.
In this order.
Monte already said what I could not say better:
berol
UK
Knipex seems one of the best (I have the pliers wrench).
Stahlwille also cannot be bad, but is pretty expensive (and might not be better?).
Hazet I already have a lot of (own the 2014 pliers) and from
NWS I have a VDE stripping pliers.
Gedore or Wiha could be an option, but I probably prefer the others above these.
Just to make choosing harder, have you considered facom? The "spring" they have in the handle is quite a useful feature.
Matt_C
London, UK
I have a set of those Facom pliers (the snub nosed ones in the pic above, plus two pairs bent needle nose) and they haven't let me down. The "spring" is a useful feature - wish my Knipex side cutters had that!
cosmik binturong
.fr
Is Facom the OEM for those pliers?
those are made in Laissey(link in french), the pseudo-Facom plant that is in reality the historic Bost Frères pliers factory where lots of pliers are made for Stanley/B&D brands and for numerous others. they wont be made there for long methinks, circlip pliers fabrication has already gone to PRC... :sad:
<iframe src="//www.youtube.com/embed/sdsmrOh0fe4?feature=player_detailpage" allowfullscreen="" frameborder="0" height="360" width="640"></iframe>
superautobacs
Vancouver, BC
I think so. :dunno: They have France stamped on the handles.
I've always thought it to be BOST
[edit] Cosmik beat me to it. I was looking for a good close up photo of their pliers. I thought I had photos that I took when I was in Paris, but I guess I didn't. Internet search didn't yield much either.
You get a choice with the latest Bahco line:
Monte
Germany
why ? Going all japanese ? :)
they offer models with spring too
:thumbup: Please write a small review after some use. Especially about cutting metal (nails, rivets) and sanding. :beer:
cutting rivets works, but if possible i would drill them out. Cutting soft metals works too (aluminium, sheet metal, car body...) but for hard/tempered steel (nails/screws) i only can recommend the Bosch blades below ....if at all....for nails etc. i would try a angle grinder, recip saw or bolt cutters first...sanding with the delta plate just works fine so you don´t need an extra delta sander... The 115mm round pad doesn´t work as an orbital sander replacement, it works, but an orbital is simply faster.
Bosch Metal Max multi tool blade with carbide teeth
cosmik binturong
.fr
as usual, you are right, the lousy clowns that are running Facom have nothing to do with the pliers that were designed/engineered and made by the fine folks at Bost. we'll see what will happen when all pliers creation & production is moved to PRC... well, no need to wait, they'll do like the others lifeless shells from SB&D with almost no R&D: buy stuff from OEMs and resell with a nicer margin... :puke:
:wtf:
have they too moved all pliers production to Spain and way way far away? :eyecrazy:
those pliers are nice though, pricey but nice.
cosmik binturong
.fr
no, not yet. i'm alone now so i'm starting to thin the herd and, for the Knipexes, have bought way too much of them to get what was sold with them... yes, it's made in Japan, from a japanese brand, it's green and it cuts 16 gauge sheet metal like a hot knife butter and i already have it's green little brother and another blue cousin from Germany. :D
oh... too bad i have an old SuperCut now so those won't fit... :(
hey! Mr. Bosch, if you read this, send me some SuperCut compatible blade samples. lots plz! thnaks!
i promise to paint that horrendous orange vibrating piece of fine german engineering Bosch blue if you do and put some Hello kitty! stickers on it. :lol:
anyway, next week i should get a 2011 or 12 swissy-sassy GST-135-something to finaly replace the missing Kress jigsaw. that will be the eighth or ninth B-blue tool for the stable. when it'll eventually get there that is... :)
decaf
Stockholm, SWEDEN
New 1/4" set from the local Wurth store, i really like it!
My collection of belzer ratchet is complete. Got my 1/2" at last.
Then i needed some special tools. This is for fork work on my KTM.
Special tools cost a lot of money.
Monte
Germany
no, not yet. i'm alone now so i'm starting to thin the herd and, for the Knipexes, have bought way too much of them to get what was sold with them... yes, it's made in Japan, from a japanese brand, it's geen and it cuts 16 gauge sheet metal like a hot knife butter and i already have it's green little brother and another blue cousin from Germany. :D
another Hitachi shear ?? Piiiiiiiics :willy_nil
they do make them...well not exactly the carbide ones but maybe in the future.... if you call Mr. Bosch :)
noooooooo....:sad: paint all Bosch tools orange ;) it dramatically increases the subjective quality :D
:thumbup: nice :thumbup: family pic please :pimpflash
Bahco file
node105
Australia
Partial delivery of an order of some longer Bessey KR 2K clamps arrived yesterday; KR100-2K, KR125-2K, KR150-2K.
I wonder where they are made? Not one indication anywhere. I know current thinking is Germany, but there is definitely something suspicious about the omission.
dutch79
The Netherlands
I added 2 more starterwrenches to my Hazet 11x13:
Heyco 430: 15x17 and 19x22.
Also a Matador 251 open ended wrench: 19x22.
And to conclude: a 1/2" Heyco ratchet with 45 teeth (50-00-7):
I must say the Heyco is a pretty nice one regarding design and slimness. The head is compact because of the turning knop in stead of a switch.
2 more pictures:
..and a comparison with an old and later Hazet ratchet.
3 different types of direction-adjustment:
kris ltc
malaysia
hi. cosmic do you still have the knipex 180mm pliers wrench ??? 25.00€ + shipping? do you deliver to malaysia ?
cosmik binturong
.fr
nope, a nibbler, a bit bigger than the Trumpfie, will do nicely for a corrugated roofing project methinks. :thumbup:
crappy family pics Saturday... or later! :D
gotta ask for them then... can't find'em on Bosch PT french site... :sad:
okidokie, i'll paint'em AEG orange then. :thumbup:
Saturday too, although some of the family is away(polisher, one die grinder and another one that i cannot remember... :eyecrazy:)
2 more pictures:
:drool: looks like Heyco is doing some excellent design work lately with that rat, the Maxline wrenches and all the stuff shown by unknown82 and uuze a few years back... long time no see the later though.
any 1/4" or 3/8" version available? i have too much halfies now... :D
the Heyco is a real beauty ! :drool:
time to go visit their factory Monte, and get an in-depth interview for us of the engineering and design team(s)! ;)
you can do Saltus too... :D
Today the new ratcheting combination spanners are on stock. Here are some impressions.
are those forged by Stahlwille in Germany and then get the ratcheting mechanism from Kabo added after or are those totally Kabo-made in Taiwan? :confused:
note that i do not consider Kabo-made wrenches as bad. only that Kabo-made at Stahlwille price is not really my cup of .
Monte
Germany
nice ! :drool:
nice !! crappy or not, pics are always welcome ;)
if you don´t mind to order from DE....http://www.ebay.de/sch/i.html?_trksid=p2050601.m570.l1313&_nkw=bosch+supercut&_sacat=0&_from=R40
lol :D
or B+D orange.............................:D
if you can´t remember you have too many :lol:
ok i will try it :D
you can find a pic of the Saltus factory in this thread :) No interview though. But you can interview me :D
Stihl HSE 42 hedge trimmer www.stihl.com
cosmik binturong
.fr
Schönen Dank! :D
hey! what's that Bosch Rotocut shown under the blades for???
i don't have money for Bosch-blue tools anymore!!! :willy_nil
(only for Hitachi-green ones if you guys buy my Knipexes in the classifieds! :D)
probably... some are not much used but when needed they handily beat not having them or having to rent them like the polisher.
:D
launching a new green business in the 'hood? :D
speaking of green, any swedie lurkin' around that knows what a "Snabbing, Made in Sweden" tool is for? looks like a compact stripper for rigid cable to me but hey, i'm usualy wrong and self-delusional about knowing what a tool is for. :lol:
here come them pixes:
superautobacs
Vancouver, BC
Agreed! They do produce some stylish designs. :pimpflash
I wonder whether some of the early contributors are still browsing this thread, quietly.
:+1:
I memory is a bit hazy, but I do recall a German brand that actually forged their own wrenches, then ships them to Lee Way or New Tools to have the guts installed, and then shipped back. Part of the reason why they are costly....I think it was Hazet. ...... or wait, maybe it was KTC.....:p
It's interesting to note that the open end is not the trademark Stahlwille profile. If they were forged in Remscheid, then you'd think that the open end profile would be their usual design. Hrmmm. :dunno:
node105
Australia
Some arrivals today. Bessey ain't what is used to be (&^&^%#*& chinese ####.
They are only clamps after all, and why would one expect the bases to be flat?
That's a float glass plate, and an easy 1mm clearance; the others are not so poor. At least the pivot pins have reasonable fits; unlike another batch of another brand recently which shall remain nameless. General finish is modestly tidy, but the die punching leaves something to be desired; camera at limits.
node105
Australia
... and a couple of Vallorbe cabinet rasps. At least the Swiss still know how to make tools; cut very nicely.
dutch79
The Netherlands
Received my (used) Knipex pliers. I've choosen for the long versions (200mm) for maximum leverage.
Snipe nose: 26-15-200
High leverage diagonal cutter: 74-06-200 (VDE)
Combination: 03-05-200
Then I also got a pair of (old industrial/all metal) drawer boxes of the dutch brand "Gispen" (high end furniture):
cosmik binturong
.fr
yeah... looks like you're seriously Weraddicted too! :D
the wooden wrench organizers looks purty too. beats **** plastic stuff hands down. :)
BJ42LX
WNY
If you like I can drive over to Le Roy and ask them WTF is up with their clamps. Granted, Bessey USA is only a sales and distribution company, but they should have a say in all this with the parent company in Germany.
