Würth Year End Sale and Stahlwille eBay find
Würth had some good sales and package deals at the end of the year. Here’s what I picked up.
View media item 1097191/4” drive spinner handle/extension, T-handle 1/4” hex ratchet with long bitholder, “Limited Edition” black 11mm outer hex+1/4” drive set with bits, 105 pc “all the bits” set.
Spinner handle is the best currently on the market: comfortable handle and female square on top. Also good length.
The T-handle (which was bundled with the bit set and spinner - they have the same deal running through the end of the month) is your standard Reverse Gear ratchet, but the handle shape allows more torque than my other T, from Williams, so I think I’ll use this one more even if the Williams mechanism is better. Blade retention could be better, but it’s fine overall.
View media item 109720
I already had Würth’s 90 pc all the bits set in my workbench, but this one is even more comprehensive. It loses a few compared the 90 bit set (e.g. 3mm slotted, SQ0) but gains the longer bits as well as the 5-point security bits. I already replaced the hex bits with Wera (because hex plus is better) and PH with PB Swiss (solely for ease of visual ID) but otherwise the bits are fine and nothing beats having everything you might ever run across (except for micro sizes) in one nicely-packaged set.
View media item 109721View media item 109722
I’m less impressed with the socket set. For one thing, the package is much bigger than their other one, and it has fewer parts (though it does have the bit extension).
View media item 109723
The ratchet is much larger, and the bit head is standard Reverse Gear instead of the usefully tiny on other other set (big one has finer tooth count, if you care).
Ratchet can be fashioned into a T-handle (bits or sockets, using the included 1/4” square adaptor) but is not shaped to slide through the bit holder like the extensions with other Reverse Gear bit ratchets (e.g. Facom/USAG, KS Tools).
Bits here are standard 1” rather than the nice short ones in their other set.
View media item 109725
Long story short, buy that one, not this one. The standard one is a more useful set for most uses where you’d want to use a bit ratchet, and probably the best overall compact bit ratchet and socket set set on the market at any price right now.
Also, I think this was Stahlwille’s 2018 advent calendar set (eBay find):
Has combo wrenches from 6-19mm, a flashlight, and metric hex keys.)
View media item 110180View media item 110183View media item 110182View media item 110179View media item 110181
These are my first combo wrenches. I don't typically need them for anything I do. But if you're going to have a tool type you may as well have the best version, and I think Stahlwille's are it. Flashlight is a neat idea that could be executed better. The power button should be on the handle, not the head.
