Tools from the old world
measuredtwice
USA
That's a really short spring. The old Snap-On 36 toothers had super long springs and do well with a shortened spring. I haven't tried swapping springs on a ratchet with a spring as short as that Stahlwille.
The replacement is a much lighter spring. You might try using a longer length of the replacement. You'll have to compress the spring more during assembly which can be tricky. It's even more difficult with the super long spring on the Snap-On 36 tooth so Snap-On made a special tool. It's just a thin piece of spring steel with a hole that's smaller than the diameter of the ball bearing. You use the tool to compress the spring and the hole traps the ball bearing to keep it from flying across the room. It would be easy to make your own.
Ordered some new springs to try and reduce backdrag on a 1/2" Stahlwille. Didn't want to cut the original spring, because I think I will be selling the ratchet on. Got the spring from a Chinese seller on Ebay. Thinner gauge wire so a softer spring.
The softer spring results in much lower backdrag and the ratchet mechanism still seams to work properly, but the switch became floppy. Just stays where you leave it rather than positively engaging on either side. Not recommended.
node105
Australia
Hafu Torx
Here's a brand I hadn't seen before. So I ordered some. Made in Germany. A bit of web ferreting , and downloading their extensive catalogue of almost exclusively keys, it seems they are the ones who make for a bunch of brands.
link to their 100 page catalogue of hex keys
https://www.hafu.de/index-en
node105
Australia
And a set of metric Wiha that arrived a couple of weeks ago from TBS Aachen at 60% of the locally sourced Hafu.
Wiha 26247 L-key with T-handle set ComfortGrip Hex
agon with side drive, matt chrome-plated 6-pcs.
mr.lemons
UK
Hafu and Oplast look to use the same handle. Makes tracing OEM a bit confusing.
really proud of that post, eh?
or did you hit the pub early tonight?
:beer:
Been a while since I've seen the inside of a pub. :sad:
Deleted the duplicate post. :thumbup:
mr.lemons
UK
Copied Monte.
Swapped the top onto some brake cleaner to see if it fits other cans. It clipped in place, but instantly started spraying brake cleaner all around the inside of my car. Not the smartest thing I've ever done. :lol_hitti There must be a little variation in spray nozzles.
Mr.Smoke
Ontario, Canada
Pretty sure I got these from my grandfather when he passed away back in 2007 and had totally forgot I even had them. The only marking/branding I can see anywhere is a C.H. on the handle/driver and each smaller driver. No idea how old they are and I've never seen anything quite lile them before.
Has anyone ever seen/used these before?
measuredtwice
USA
I had the exact same set in the late 80s or early 90s. I still have it... somewhere. It was very inexpensive.
Mr.Smoke
Ontario, Canada
Yeah I figured it wasn't some high end, expensive set that was rare or anything like that. Had just never came across anything quite like them before and was curious. Googling seemed to be useless for finding out any information.
RoundedNut
driveway
Hafu Torx
Well it looks like they make that for INBUS as well. I was on the fence about INBUS and I think I'll pass.
https://www.amazon.de/dp/B08DDCZ3MR/
Dave455
Sussex, England
These were sold in the U.K. in the mid 1970’s. They were called “Toolmate” here, and I think were made in Japan.
Yes, they were a copy of the Xcelite PS-88 screwdriver set which, at the time, came in a similar plastic box. No, the copies were not the best quality. I have a set somewhere that I was given at that time, but can’t locate them right now.
I can recall using them building a model railway, and wiring Christmas lights. They were fine for that. Probably not for much else!
The Xcelite tools are of a much better quality, and do have their followers! Xcelite version shown below.
Monte
Germany
Inbus = Hafu ...same company
Gesundheit.
lol :p
Copied Monte.
This one fits too....but i wouldn´t try it inside a car either ;)
Phang
Singapore
Hazet 1979-91
well built and bright
it has a built in 3.7 v 2600mah lithium ion battery, likely a 18650
[/url]
16again
Boynton Beach, FL.
Anyone have this Snap-On tool? Perhaps a spare they would like to sell to me?
measuredtwice
USA
FYI. Model # is spp744. There are some on Ebay for $12-15 shipped.
https://www.ebay.com/itm/284185412274
https://www.ebay.com/itm/133418224402
Snap-On used to sell them for $1 with free shipping but I can't find them on the store so they are probably discontinued. Those were the good old days!
https://www.garagejournal.com/forum/showthread.php?t=38759
Simple to make out of a scrap of spring steel.
Gert
Netherlands
Found me this metric Stahlwille Stubby set, took me some years to find.
16again
Boynton Beach, FL.
You were a great help. Ordered one of them just now. :thumbup: Thank you
Dave455
Sussex, England
That’s a good find!
Short length ring spanners / box end wrenches are a very underrated tool in my opinion, and I can’t believe Stahlwille discontinued the No.18.
They still offer the “aircraft spec” No.180 (as you probably know) but not in metric!
jimmyin3D
southbay, CA
Some NWS pliers. Beautiful quality especially liking the NWS 147-62-200 safety grip pliers. The shape of the circle is much more shallow allowing for easy gripping of hoses in all sizes, also works on clips. I like it much better than the Knipex hose gripping pliers as well. I thought the tips would be fragile but there isn’t any give or bending.
Also the small flat nose pliers are awesome, I had my eye on a pair like this for a bit but it’s been great dismantling the electronics of a CM block grinder.
I really like NWS pliers, especially the regular grips.
mr.lemons
UK
Got round to trying a longer (softer) spring. Used a slice of mesh in place of the tool. Thanks for the helpful info on that, it reduced parts flying and swearing. As the spring provides tension for the pawl and the switch, it's a trade-off between backdrag and floppy switch, but the longer spring works quite well in both regards.
Qualitytools
SOCAL
Jimmy I really like that 147-62-200, I have the KNIPEX one and I found it too big for vacuum lines for instance
Doing some search on the NWS I found at KCTOOLS the -205 bot 200 (not that big of a difference in length) where did you buy yours? Thanks
measuredtwice
USA
Happy it was helpful :beer:
Reed Prince
Northern Virginia USA
I had an application recently that required a Pliers Wrench that was larger than any I already owned, so I finally had a reason to buy this one.
Perhaps my collection of Pliers Wrenches and Cobras is finally complete. Of course, I've thought I had everything I wanted/needed a couple of times before this most recent purchase. :bounce:
SRSemenza
Not complete until you get the 400 Pliers Wrench :bounce:
Might as well get it now ....................... you know your going to need it :D
Seth
Gert
Netherlands
That’s a good find!
Very true, and underrated indeed. The metric ones hardly ever pop up on local craigslist here. I am glad I found these.
Monte
Germany
wow nice assortment ! :thumbup::pimpflash
Anybody have a source for the
"Hansewerkzeug" tools for measuring/adjusting gap dimensions in the US or that will ship to the US. TIA
https://www.mactools.com/en-us/Paint-and-Body/Hand-Tools/FT141131/Panel-Gap-Gauge
https://www.eastwood.com/eastwood-hands-free-panel-gap-setting-tool.html
there´s also this:
https://www.autotoolworld.com/Dent-Fix-Equipment-Corporation-PG213-Gauge-Perfect-Gap_p_226039.html
Hello everyone,
This is the first time I post here.
Here's the first Hazet tool I got from tbs-aachen.
Welcome ! Beautiful set ! :beer:
mr.lemons
UK
Gertus drills.
Took a gamble on these. The price on Amazon keeps bouncing from £40 down to £8-9. I don't know anything about Gertus. Prices for the set vary on different sites, starting from about 11 euro. Was hoping for German coo somewhere on the case, but no such luck. May have fallen for the Chinese tat parading as German trick. Will find out when I come to use them.
http://www.gertus.de/index.php
mr.lemons
UK
Empty Gedore case picked up from Ebay.
Same as their 1/2" socket cases, but about 20mm deeper.
Not sure how easy it will be to remove the inner dividers. May have to cut them out. :dunno:
mr.lemons
UK
Disappointed with Pferd key files.
<iframe width="560" height="315" src="https://www.youtube.com/embed/RwvFinTOtMA" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Dave455
Sussex, England
That is a bit disappointing. I think you can expect better than that.
I have to say though, that a warding file (which is what those are) is probably the wrong tool for that job. They have to be thin for the role they are designed for, but most times, in general engineering, one needs something a bit heftier.
I don’t bother with warding files at all now. Once my biggest needle files run out of steam, I tend to reach for something such as the “Habilis” files shown below. They’re little longer than a warding file, but work so much better for most jobs.
To be honest, for the piece you were demonstrating on, I’d be using something heftier still, such as the Vallorbe “precision” file shown with the blue handle in the first picture. I don’t generally bother buying “sets”. If you just buy the shapes you need they are not too costly.
