To POP POP and to all interested in removing cylinders:
To remove the cylinder from a Walker 93632 (or any other jack) you should use a exhaust tube expander inserted in the cylinder to prevent it from flattening when trying to remove it with a pipe wrench. Even a very slight flattening of the cylinder will prevent the wide part of the ram from going into the cylinder. So expand the tool as much as it will go and apply the pipe wrench over were the expander is. (Harbor Freight sells three different sizes of expanders.)
IMPORTANT! When using a exhaust tube expander check that there are no raised sharp edges on the exterior surface of the expander. Sometimes the manufacturers do not deburr the sharp, raised edges on the expanders, product of the manufacturing process, and these edges will leave a mark inside the cylinder requiring plenty of honing afterwards. If this were the case, take apart the expander and file the edges smooth. You only want soft edges on the expander.
Be aware that the cylinder in a Lincoln 93642, series C, is factory torqued to between 500 to 550 ft. lbs! So the cylinder in the Walker 93632 should be around that range. The reason for such a high torque is that these jacks do not use any type of copper or aluminum washer as a seal between the cylinder and the pump block, as other jacks do, so the seal is just metal to metal. If you could make a copper or aluminum washer to be inserted under the cylinder, you could use less torque on it.
A way of knowing if you are close to the torque required is to make a mark on the cylinder, before removing it, so that when your are reassembling the cylinder it is just a matter of aligning the mark to the position it was before removing it.
Perhaps you may want to use thread sealant if you think the cylinder might leak afterwards if you are not able to torque the cylinder to the required range.
You better have a solidly mounted vise in case you decide to remove the cylinder. And you are going to need a 5 or 6 feet long steel pipe as an extension for the pipe wrench. Better use at least a 24" pipe wrench. Good luck!
