What did you do "IN" your garage today?
polexican23
burbs-Illinois
Laid down 2 coats of Master series rust preventer on my VW chassis.
Tomorrow nite will be the top coat. A nice gloss black.
Sent from my SM-N950U using Tapatalk
rohartman
I cleaned on the old Carbir CS2 race car and pushed her into her semi retirement spot. Hell she deserves it with 9 National Championships and over a 100+ National wins! and new track record at every track we ran but it kills me to see her just sit there.
jwh
Rochester NY
Changed EGR valve on 2005 Grand Caravan. Wasn't bad once I figured out which version I needed. They had a part change sometime in the model year - no part number on the one on the car. Found a website where I got a build sheet.
John
oldmxracer
Looks like she has one nice retirement home !
Fix Until Broke
SE Wisconsin
Oldest son and I took apart the youngest son's bicycle that we got at a garage sale to try and figure out why the pedals would lock up sometimes. Seems the previous owner didn't tighten the jam nut on the bearing/brake preload and just tightened it down with the same torque as you use to hold the axle on the bike. We took it all apart, figured out what was wrong, cleaned everything up and put a new layer of grease on everything. Put a preload on that didn't feel like it was crushing rocks inside, tightened the jam nut, then finished the reassembly. Also removed a non-functional hand brake.
I tried to let the oldest son do most of the work, but ended up doing half of it myself - not because he couldn't do it, but because I struggle helping someone else do something that I've never done unless I do it myself. It's something I need to keep working on. Good to spend time in the garage with the kids though :)
zmotorsports
Northern Utah
Thank you!
I feel guilty for putting it off so long since it was so easy and made such a difference in the looks of the cover.
I know the feeling about putting things off. I had a list of things I wanted to built in my last shop that would make my shop time more enjoyable but they always got put off because of things that made me money.
In my new shop I have done many things that I wish I had done years earlier and it sure changes the feeling of the whole place and makes me smile to myself each time I use the tool or piece of equipment.
zmotorsports
Northern Utah
Last night I got home and was able to spend some quality time with my son in the shop discussing his Jeep WJ build and then looked over the coach and did a couple of minor things and cleaned up the shop from last weekends wind storm that blew grass clippings into my shop and just sat and relaxed in the shop until the wife returned home from work.
niget2002
Josephine, TX
Spent time debugging a really weird issue with the 3d printer last night.
My print bed is 200mm x 200mm. The part I was printing was 220mm x 10mm.
If I rotate the part 45 degrees and print it, it comes out 218mm x 10mm (reproduceable).
BUT (and here's the crazy part)... If I rotate the part -45 degrees so it's angled the other way, it came out the correct size.
I still can't figure out why, but at least I have the part printed.
Mpower5266
Newnan, GA
Do you work for Pegasus? I used to order everything from them back when I autocrossed and did road racing.
Oh it looks to say Fegus or something in the car, never mind. Haha
bmxdad
Puyallup, WA
This you?
https://en.wikipedia.org/wiki/Carbir_Race_Cars
Carbir_Race_Cars
mrobins297aaa
south east michigan
Last week upper and lower balls joints on the driver side on my F250.
First time I used my HF rechargeable led light......pretty nice.
Job took 8 hrs.
fordkid88
Worked on my project truck all day. Driver seat brackets fsbbed up and wired. Still have to do the passenger. Putzed around trying to get this 05 mustang dash into my 93 explorer. Close but I'm having some issues with the support.
mfnlonewolf
Victoria,Tx
Have been cleaning up inside for the last 2 days while it is raining from the tropical storm on the Texas gulf coast. Sorting nuts bolts, and general reduction of useless items to the scrap yard. About 7.5" of rain here so far.
:bounce:
polexican23
burbs-Illinois
Never used it but many of the guys on Volksrods swear by it! :)
The main contact with Master series is a VW guy himself.
It is the first time using it and I just put down the top coat. The rust preventer went on like liquid glass with a roller, but either this stuff is too thick or I took too long applying it cause it was not as easy to apply.
Also a VW chassis has soooooo many nooks and kranies to get paint into.
LS6 Tommy
Northern NJ
Put the E46 treatment on my E90, not sure I like them, maybe I do, need to give it a few days.
I don't understand any of the "eyebrows" people put on headlights. It's not the look, I just don't like reducing the amount of light I put on the road...
To each his own! :thumbup:
Tommy
Spudd4242
Moved this bikes and lawnmower around so the wife can park in the garage again. The Honda in the back I picked up for $300 a few weeks ago. I can’t wait to get rid of it!
Smiles79
Northwest Missouri
Well I don't have it yet...
In August my girlfriend and I are moving into a newly-remodeled rental. The best part is the 30'x36' pole barn on the property. Yesterday I had a blast laying out where I'll put the Firebird, the boat, my Ranger, the motorcycles, the work bench, and seeing what I'll still have left over for a work space. I can't wait!
Sent from my Pixel using Tapatalk
C_F
Utah...SNOW BLOWS!
Wow, that's different! That will look pretty cool when you're done. What made you want to try that swap?
EOC_Jason
Bentonville, AR
Took apart the back of my Honda mower (again). Last couple times mowing after a bit the rear wheels would lock-up when trying to pull backwards, obviously something was warming up and expanding causing it to bind.
More reading on the interwebs pointed to undersized bearings used in the mowers (compared to new models). So the 'fix' is to sand down the shaft a little.
Cleaned everything up good too while putting back together. This time instead of lithium grease between most bits I'm going to give a dry teflon spray a try since a lot of crud got in where it really shouldn't...
Going to go mow the front yard in a bit and see if it's any better. Last time I took it all apart it was a couple mowings I believe before the issue happened again, so we will see...
Lee Celtic
Llanberis, North Wales UK
Made up a set of leads to add a secondary battery to the S60.. cleaned said car inside and out topped up the oil and water ready for a road trip.. Heading to the airport tomorrow for a two week trip to Greece.. :)
BuffettFan
Central Illinois
Wow! looks very good!
Could you write a short "how too"so I can copy cat.
Thom
Alright, but remember, you asked for it!
I don't claim to know anything about engine turning, this is just how I did this project. I'm sure others on here have done many more and better jobs than I.
I would recommend starting with a piece of scrap and trying different diameters of tools to get the look you're after. Typically, the larger the piece, the larger the tool you'll want to use.
We'll start with the tool I used in this application. It's a 1.75" PSA arbor that I used double sided tape to affix a piece of scotchbrite to.
View media item 84212
View media item 84214
I then started in the right hand lower corner. You will want to always start your rows from the same side of your workpiece.
View media item 84215
I clamped a guide at the top of the workpiece and marked the lower edge of the piece.
View media item 84216
I then determined the spacing I wanted between rows and marked the measurements on the table.
View media item 84220
I finished the first row, stepping over half the diameter of the tool, eyeballing this distance.
View media item 84221
Then moved the guide to the next line.
View media item 84211
I then finished the second row positioning the swirls half way between the ones in the first row.
View media item 84209
Repeat as needed to finish your parts.
View media item 84208
Once you are set up, it goes very quickly and using the clamp and guide system, results are very repeatable.
Great thing is if you make a mistake, just scotchbrite the whole piece and start over.
I used about 6 of the scotchbright circles on the table cover, running the drill press at 350 rpm, no lube or coolant. It doesn't require very much pressure either.
Good Luck with your version and be sure to post some pictures!
:beer:
ambenz
NW Chicago Suburbs
It has been a great couple of days to work out in the garage
Rain has kept the temps in the 60F range and that means less sweat!
Day #2 in prepping the pony for a Assurance Ceramic Coating.
If you were to get your car detailed and prepped like I am doing, a detail shop would charge you over $800+ for my size vehicle.
The high price is due to the surface prep labor and materials involved in order to get your paint looking "as good as possible!"
Ceramic coating is a "premium" wax alternative.
A Ceramic Coating creates a permanent or semi-permanent bond with a vehicle’s paint, meaning that it does not wash away or break down and does not require repeated application every few months.
Less work keeping my paint protected!!!! Yay!
Yesterday I washed and "blue" clay mitt the body to remove the enviroment from the paint.
Today, I started this morning using Rupes "diamond" polish.
It is smoothing out a few scratches and allowing the orange to sparkle.
I have been tireless in fixing paint chips and trying to make the 11 yr old paint look new.
https://scontent-ort2-2.**.fbcdn.net/v/t1.0-9/35927112_2306728039353728_4532361296774955008_n.jpg?_nc_cat=0&oh=f19adc9ae63e1a26ff836dce08e1b974&oe=5BAD791A
The paint looks like glass and it isn't ceramic coated yet!
https://scontent-ort2-2.**.fbcdn.net/v/t1.0-9/35923587_2306727986020400_4077937942788571136_n.jpg?_nc_cat=0&oh=337788f67f44dc4cd44b9d645cd31bd1&oe=5B9F0CB3
It is nice to have the mini buffer for all those small areas and contours.
https://scontent-ort2-2.**.fbcdn.net/v/t1.0-9/35970627_2306728076020391_4994157116743745536_n.jpg?_nc_cat=0&oh=aebae76801be0f41bbc12a57a5b9d02f&oe=5BBC23CC
Getting the painted surfaces inside the door jams too...why not?
https://scontent-ort2-2.**.fbcdn.net/v/t1.0-9/35920406_2306727909353741_9088455479021010944_n.jpg?_nc_cat=0&oh=6b75635194936673a5952bc8e7106735&oe=5BAEA371
https://scontent-ort2-2.**.fbcdn.net/v/t1.0-9/36088339_2306727846020414_2365981029623136256_n.jpg?_nc_cat=0&oh=08e9a6fc95b3a6b6393acedcd04848fa&oe=5BAD3FB2
Took a break for dinner and then it is back out to wipe it down with Croftgate Surface prep just before we apply the "Assurance" Ceramic coating.... so Stay Tuned!!!
Gummi Bear
Sunset, Texas
Wow, ambenz.
There’s no way I would be able to to do what you’re doing there. It looks fantastic.
I went to the woods because I wished to live deliberately...
Henry David Thoreau
ambenz
NW Chicago Suburbs
...That HAS to be the best kept and cared for Mustang, maybe any car, in the WORLD!
Looking fantastic, as always!
Wow, ambenz. .... It looks fantastic.
That is a lot of effort, but it looks like it paid off. Great looking car.
Thanks for the nice comments guys.
I got half the car ceramic coated tonight, Saturday is day #3 LOL! :wtf:
https://scontent-ort2-2.**.fbcdn.net/v/t1.0-9/36063508_2307168609309671_9035503394164310016_o.jpg?_nc_cat=0&oh=0b34f0dbc43798de112c4d8bb7d4ffbf&oe=5BA7158D
No way my Mustang is the best kept...I know a lot of Stangers who are cardinal clean freaks and win Top 5 almost every judged show they go to.
I have very stiff competition whenever we go to a Mustang specific show.
If you want to see my Mustang in person, I will be at the car show below, Saturday, June 30th, 2018.
I got my gun loving Uncle to stay at the house while I'm gone.
058f2b11f6ee9eb5ecb0d2e6f07e2d27
11th Annual Queen City Mustangers Car Show from 9-4 at Lakota West High School
8940 Union Centre Blvd., West Chester, OH​​
The road trip down to Ohio is half the fun!!!!
rmalkow2
Brighton, MI
I've been working to get my hodge dodge of cabinets to share a similar color scheme. I've settled on this light metallic blue Rustoleum paint for the top coat. I just finished number 2 today including a hard pine top.
Streetbu
Central NY
Drove my project car out of the garage for the first time since replacing the frame, and a just about every other part on it.
shedfullatools
Nova Scotia
Upper control arm on my Buddy's Blazer after work today, warned him it was shot when we did the shocks last week. One good bump yesterday finished it off with a proper 90° bend and multiple tears in the crusty old sheet metal :lol_hitti
Elkjunkie
Washington
Shortened a salvage opener 4 feet and hung it. I wont get to test it until I get my new springs per forum advice. Also a bit more suspended shelf work. Thanks all!
