What’sit?
dffay
Fine knurling with two internal dimensions: 1.0 inch ID and .85 on the other side.
Internally it is stamped SNAP-ON TK-20.
Google isn’t very helpful.
D
dffay
Definately Snap-On. Might predate the latest numbering system and its small enough to not have enough room for a lengthy code.
D
dffay
Nice piece off machining. Ferrous metal.
D
dffay
My only other guess is that it’s part of a set with larger and smaller ones. So the big part number is truncated per piece.
loganb
Omaha, NE
AI(Claude) wasn't of much help and was suggesting some sort of ignition service tool or part of some type of set for seals etc. It did actually cite this very thread though which I thought was more interesting
D
dffay
Smooth inside. Something used to gather needle or ball bearings to place over a shaft?
I’m stumped.
Wrench97
Southeastern Pa
The rubbing block is on the points so it would have to be to clean that up, I don't imagine it was used a lot by the late 50's in shops it was common to replace them as opposed to filing and cleaning up/oiling the wick and rubbing block.
