What’sit?
dffay
Fine knurling with two internal dimensions: 1.0 inch ID and .85 on the other side.
Internally it is stamped SNAP-ON TK-20.
Google isn’t very helpful.
D
dffay
Definately Snap-On. Might predate the latest numbering system and its small enough to not have enough room for a lengthy code.
D
dffay
Nice piece off machining. Ferrous metal.
D
dffay
My only other guess is that it’s part of a set with larger and smaller ones. So the big part number is truncated per piece.
D
dffay
Smooth inside. Something used to gather needle or ball bearings to place over a shaft?
I’m stumped.
Wrench97
Southeastern Pa
The rubbing block is on the points so it would have to be to clean that up, I don't imagine it was used a lot by the late 50's in shops it was common to replace them as opposed to filing and cleaning up/oiling the wick and rubbing block.
driftpin
The reason you replace points is that the rubbing block on the distributor wears, why would you want or need to 'surface' one? There is always the points pitting, and wearing because of the capacitor's energy characteristic is changing, causing the pitting on one point or the other. (Charges the capacitor)"Here, kid, catch!"
An electrifying moment.
^ The rubbing block on the breaker points set was a much softer material than the steel cam lobes inside a distributor.
This is the first time I've ever heard of "resurfacing" distributor rubbing blocks or breaker point rubbing blocks.
We sold "cam lube" made specifically for lubricating the steel cam lobes on distributors to prevent premature wear of the rubbing block on the points (NL2 Niehoff - NL2D was the display card of 12 tubes.)
I can't imagine "resurfacing" the rubbing block on a set of points in 1955, because (a) point sets were relatively cheap and (b) in many cases, you could buy the stationary arm and the contact arm separately - the cost of replacing the piece with the rubbing block would be pennies.
Long ago we sold "commutator smoother" tools to re-surface commutators on starters and generators.
rust in the eye
Chicagoland
If the rubbing block isn't parallel to the cam it might wear quickly on the "high" point hence altering dwell and timing. Explained in the catalog description posted up by 3baygarage. The tool ostensibly put over the cam and rotated, the knurling removing material from the soft rubbing block until full contact is made.
This procedure never occured to me but it makes sense. I only have one engine with breaker points but I'm going to check the contact.
Jack_K
Australia
I feel like this tool is required more now than before. So many points I get now have issues such as poor alignment or only a very small contact area on the cam.
I don't know about the labour costs vs parts cost back then but there were and still are people who will sit there filing worn points instead of replacing them.
Jack_K
Australia
For the five out of a hundred that still run points.
Out of the people using points, obviously not the entire population.
When points were current, decent ones were available but now it is mostly cheap garbage with plastic cams. So many I get have the wrong tension too.
With tools like this, in the back of the catalog, in the various special tools and sets sections (valves, brakes, wheels, etc), I always like to look at the evolution. The history of a tool. What did mechanics use before Snap-on (or any other mfgr) offered a "Distributor Rubbing Block Surfacer"? Flexstones wrapped around a socket? A light film of high temp distributor grease on the cam? Or nothing?
Snap-on introduced this in 1955 and it appears in catalogs until 1967. They still had a whole page devoted to miscellaneous distributor tools well into the 70's, but this tool was no longer offered. I am guessing a third party mfgr (such as Clark-Feather, etc) talked them into it.
Same story with Cornwell. They introduced it even earlier (1950) and it vanished earlier (1964), too.
Not to be outdone, MAC also offered it (starting in 1952). Note the same ("Dandy") merchandising language...
D
dffay
Interesting. So, would there have been a committee that would meet with the Board and somehow convince them that a specific tool was no longer needed or marketable in the changing evolution of autos?
That era still had plentiful points and condensers. I wonder why certain tools were phased in or out.
Just my random neural firings…
Wrench97
Southeastern Pa
Usually when they stop selling, Snap On use to have overstock/discontinued items sales once or twice a year at a distribution center by invite only fro your route salesman. I bought a set of round handle metric offset box wrenches once for 70% off, still lifetime warranty but there was a catch since they were 18mm - 19mm and if the 18mm end broke no problem you got 16-18mm flat handle replacement but had to buy a 17-19mm if you needed that end......
Beerhippie
Far NE Oregon
I think it's much simpler. A tool stops selling--or sales go way down. Marketing tells management, management tell the factory to stop producing.
I imagine a tool made to abrade a cotton/Bakelite cam follower would last a looooong time. How many more can you sell once you reach saturation?
Sure, there were points long after sales stopped--but the shops that worked on those rigs already had the tools.
