Woodworking 101--Tools and Tips
cheechi
Triad, NC
Diablo makes very nice TCG blade that works very well with extruded aluminum. When Lowe's clearanced out their specialty Pergo blades I watched the store that had two in stock, they never dropped enough to be affordable as an extra 'may never use' blade.
That TCG blade I got from Northern, I know they have a 10" one also (I honestly forget if I got one for my table saw). My miter saw has a depth stop and I use the TCG sometimes if I'm too lazy/not enough room to set up the table for a slot cut.
trainer
Northern Ontario, Canada
When I exchange for a sharp blade, it goes onto the chop saw or table saw and the older, but still servable one gets to live out its life in my portable bench saw.
Although, I'd certainly look at a 12" mitre saw if mine ever needs to be replaced.
J
jimreed2160
Tallahassee FL
New workbench
My new little workbench in the dusty area is beginning to take shape. I installed a power strip and put a vise on the table to see if it will work out in the tight space. The drill with a wire wheel has also found a home. I picked up a $5 set of pliers and nippers at HD--nice to have tools where you need them.
I cleaned up a blade this morning and felt good confining most of the rust dust to the back room. Shop organization seems to never end but the results can be very rewarding.
J
jimreed2160
Tallahassee FL
Clamp cart
So with the previous posts on clamp organization, I was feeling a bit behind. In addition, my new workbench location had a few hundred pounds of clamps just behind my head, waiting to fall. Then I remembered a roll around stand I made for my Leigh jig. Time to repurpose that bad boy.
I started with the stand and popped the top off. Then I filled it to the brim with Jorgies, Bessies, and assorted C-clamps. It weighs a ton but at least it gets the clamps out in the open.
My plan is to use this for awhile and see how it works. Everything is loose right now and I may want to fasten it up. Time and use will show the way.
Alchymist
Central PA
Like the C clamps with the scrollwork handles. Have a couple of them myself, and a couple small ones that my mother used to use to clamp her rug making frame together.
Bob Heine
Boca Raton, Florida
I found a solution for end caps on the wood vise handle. Not really wood working but it did seem to work. It's kinda like metal/wood/plastic working.
The sprinkler system in my yard has a lot of PVC fittings and the threaded ones often get buggered up. For decades I dug a big hole, cut the damaged fitting out and glued a new one in. Wandering through Harbor Freight a few years ago I found a cheap set of NPT taps and dies, including the 1/2" size that most frequently gets buggered. At $14 it was too good to pass up. I can usually fix a fitting by removing the sprinkler head, tapping the fitting and installing a new ****** between the fitting and sprinkler head.
The dowel I used for the vise handle is 7/8-inch OD but I remembered that NPT fittings are based on 1/2-inch ID so maybe the die will work. Gave it a try and sure enough it started cutting threads.
OK, I wouldn't call the result of the first pass to be threads. More like it shaved down the dowel to a tapered 3/4-inch OD, much closer to the NPT thread size.
Because NPT threads are tapered, I thought (hoped) I could cut a decent set of threads by reversing the die. It isn't like a sharp cut set of threads cut in black pipe but it isn't bad and it cut the shoulder of the reduced dowel much better.
I took a couple of photos of the finished thread but they are all out of focus. You'll have to trust me -- the threads came out pretty decent.
The whole process led to the handle having simple threaded PVC caps on both ends. I had to use a strap wrench and channel-loc pliers to tighten them down. If they ever start to loosen, I'll probably drill a hole and install a fluted dowel.
rrich1
She's technically up and running.
Earlier today I glued and pinned the parallel guide into the chop. Next was to make a roller guide for the parallel guide. After my first failed attempt I got it right the second time. I need to take it back off and round the edges and sand it.
Put wax on the screw and run it in and out a whole bunch of times.
Up next it to take it apart and put the piece of leather on the chop and then oil it up. 9ccbc1201ce860b98cd4962c42c37b63.jpg163d856c0f6f8e025b67af2ddf93fa0e.jpg6806cb3b6d391bb2c5c26444b786d04c.jpg
Sent from my Pixel XL using Tapatalk
J
jimreed2160
Tallahassee FL
Bob--Your ingenuity continues to amaze me. Great job on the handle.
rrich--That vise is stunning. I am sure you will smile to yourself every time you turn the handle.
shortykorte
Tallahassee, Fl
Rrich1, that vise is sweet. Sure would be nice if someone offered a kit. Wink wink.
Jim interesting take on a clamp cart. Great repurpose. If you’re bored, I can drop off two bookshelves that need to be converted to my clamp cart. I can come by Friday.
jar944
Northern VA
Still need to build the drawer boxes, install the feet/trim and crown. apparently according to swmbo starting on the dining table we are eating Christmas dinner on comes first.
jar944
Northern VA
excellent work Jar944. I love sapele.
Thanks. I'm liking it the more I work with it. Hopefully I still like it after this table build. I got a really good deal on 11' 4" boards for the table top because they have some wild reversing grain. I just need it to cooperate.
J
jimreed2160
Tallahassee FL
Charlie Chan say
Pretty figure in wood like pretty figure in woman. Nice to look at but hard to tame.
drivesitfar
ALL: in my almost daily search for cool old tools and vises here's another woodworking bench i thought I post pictures of here since i'm saving the design for maybe a future build for me. i know it might not be the most efficient design, but i think it's cool. you?
the vise isn't anything special so i'd probably update to one of my pattern maker's vises or at the least a quick release on, but the seller's asking price is well over a grand so i'll have to make one before paying that much for it.
hope you are all staying safe and making cool stuff this weekend
J
jimreed2160
Tallahassee FL
Drives--Of course the seller is free to ask any price but I think full retail is about $100 for the vise with the bench thrown in. The top looks like maple flooring. The vise seems to be in great shape and I am sure the vise and bench would clean up nicely.
As a bench, I am less than thrilled. It seems to have been made for some special purpose--perhaps as an assembly table. The vise in the middle has almost no utility. Corner mounted vises are good for crosscut sawing and also allow access to the workpiece from two sides. Front mounted is not good for crosscut sawing and no dog holes means the front dog is useless. Of course, that is probably why it has lasted almost 100 years.
My dad picked up a table similar to that one from a florist's shop that was huge--maybe 5 feet by 7 feet. It was one sweet assembly table except for one thing--FSD runs rampant in the genes of my family. That table stayed so cluttered that I could barely open up a few precious square inches for my projects. I had a large commercial hollow core door table in my shop that suffered the same fate. One day I noticed that it was a parking lot for a dozen vises and decided that it had to go. My shop has been better off since that change. For me, one of the treatments for FSD was to decrease the flat surfaces so things had to be stowed immediately.
Sorry to have totally trashed the cool looking bench. It IS cool looking.
J
jimreed2160
Tallahassee FL
It is cold in the workshop and I did some cleaning and straightening up. I found two interesting things.
The first was a European style jointer plane that is the size of the Stanley #8, or 24 inches long. It is lightweight and easier to adjust than it might appear. I just tap the blade down until it bites the wood. If the shaving is too thick, just whack the heel. If the shaving is too thin (can they be too thin?), just whack the toe. I love a shaving that passes light through.
Second item is a piece of aluminum bronze from the grinder room floor. I ordered it a few years back so I could make some lever caps for planes. Prices are up--$30 to my door in 2003 is now over $100 plus shipping.
R_einan
Eastern WA
Well, my fall project has come to completion. I picked up the coffee table I built as a housewarming/Christmas present for my cousin and his bride from my friend today. After I put a couple of coats of garnet shellac on it for a uniform color tone, he sprayed it with 3 coats of precat lacquer and buffed it out. And just in the nick of time, I’m driving it over the mountains for delivery on Monday. I sure hope they are as pleased with it as I am!
royce
fairbanks ak
My goodness, that is gorgeous.
Thanks for the post.
Royce
drivesitfar
ALLFAST: i started a thread on CLAMPS a year or maybe two years ago and got a few snickers, but i think it has more than a few good posts so you have my vote to start a thread with any tools you think worthy and i can't recall seeing one on the kind you mentioned.
Jim: no worries cause i know that old workbench isn't ideal, but I liked the look.
ALL: here's to all the WOOD BUTCHERS like me who read this thread and maybe become more like WOODWORKERS
R: great looking table!!
J
jimreed2160
Tallahassee FL
All--Vintage chisels can get some ww in a lather. Some like Butcher steel, others swear by the Stanley 750s. Some like stubby Stanley #60s and others like long and thin sash chisels. There seemed to be more variety in days of yore. But you are correct--it is a very slippery slope.
R--Great project. They will enjoy that table for a long time.
Drives--I liked your clamps thread. Clamps are the unsung heroes of ww.
jar944
Northern VA
Charlie Chan say
LOL true. It ended up not being very figured at all. Which is fine with me.
I still need to kerf joint the edges with the saw before I glue it up in three 15" sections and run them through the planer.
bj383ss
TX
Love all the projects going on in this thread. I haven't posted in here in quite some time. Jim I don't understand how you keep finding cool stuff in your shop.:bounce:
Couple of snowmen I made for Xmas Gifts. They are made from Pecan and their hats Walnut. Stuff is the hardest wood I have encountered. These are for my mother in law. The cool thing is the Pecan is leftover scraps from a built in I made my Father in law 10 years ago. So hopefully they will have sentimental value to her.
20171208_175808 by bjohnson388, on Flickr
Bret
J
jimreed2160
Tallahassee FL
Jar--That is going to be one nice table. I am sure you will enjoy eating off of it --NEXT Christmas. I would be looking for plywood and pretty tablecloth for this year. Hope you meet your deadline. :willy_nil
BJ--My shop is full of hidden treasures--I find stuff almost every day and only post pictures of a fraction of it. The best treasures I find are figured wood. I will start posting pictures of that. I love your snowmen. They are very artistic and have little personalities showing thru. I am sure your MIL will be tickled.
jar944
Northern VA
LOL we did that last Christmas, but it was a old formica island countertop I had on saw horses.
J
jimreed2160
Tallahassee FL
Well, us woodworkers do need to innovate. :lol::lol::lol:
I once had a buddy bachelor ww who lived in the apt next door. His dining table was a table SAW. It was one of his few post divorce possessions. When topped with a piece of plywood and a tablecloth, the saw just vanished.
J
jimreed2160
Tallahassee FL
Wood prizes
Now that I have lots of drawers, I can begin to sort out the wood stash. Here is a random drawer with wood goodies. There is padouk, ebony, figured maple, and a nice piece of lignum vitae.
The other pieces are samples and then there is some apple scattered about. The apple is great for repairing saw handles.
J
jimreed2160
Tallahassee FL
Clamps clamps
Since I repurposed the rolling stand into a clamp cart, I have been scrounging clamps from all corners of the shop. It was cold today but I managed a brief foray into the chill to continue. Today's haul was LARGE C clamps. Some of these came from my dad and some were purchased new. They all pose storage issues because they are big and heavy.
I put them on the side of the box as I collected them. It is not a good permanent home because they stick out too far. BUT I found the perfect space for them inside and out of the way. While I was at it, I found a place to store my saw vise. That dang thing really gets in the way and is a bother for something that is rarely used. But it earns its keep when I need to touch up a handsaw.
So far, the clamp cart seems to be carrying about a quarter ton of clamps. It is nice to get the larger ones out in the open where I can see them. I give this project a 9 out of 10 for value.
jar944
Northern VA
Ha I could see that. :thumbup:
The countertop worked great, other than I kept walking into the leg of the saw horse.
J
jimreed2160
Tallahassee FL
Holiday project ideas
With the holidays here and vacation time available, QST is in the air. What are you doing in YOUR shop? We already have seen bj's snowmen and jar's table. I will add something from last year's post. Remember the legs I found? And then remade the paper dispenser? It was a fun project and something that is open for copy. I just dug it up and set up a table for gift wrapping. You could make the same thing with some plywood and a long rod. A paper dispenser sure is handy this time of the year.
So show yer projects!
drivesitfar
Jim: great ideas for storing scraps and i love your little wrapping paper stand. i had a small version of that with rolls of emery cloth on it and i gave it away so i need to make another one.
BJ: nice looking snowmen, but curious why the big hats? :thumbup:
are they super smart and have huge brains? :bounce:
ALL: in case any of you want to give me more ideas for clamp storage please do on the CLAMPS 101 thread or just show off your cool new or old clamps.
https://www.garagejournal.com/forum/showthread.php?p=6883508#post6883508
i've been moving wet cedar i bought from a local mill for next year's projects and even though it's backbreaking work you can't buy this stuff at HD can you.
if there is a better way to dry and sticker wood outside please let me know.
jar944
Northern VA
Got the top kerf jointed, and glued up into 3 sections.
J
jimreed2160
Tallahassee FL
Drives--I wish I had your energy. That's a lot of nice wood. Just make sure there is a sticker about every 18".
Jar--I wish I had your clamps. Man, that's a cr*pload of clamps holding sections of a looooong table. Can't wait to see the final top. But that should be REAL soon now. Keep moving, there is still time to make the deadline.
