New project
The mailman brought me a new project. It is a small #3 sized smoothing plane made by Peugeot Freres. As best as I can tell, the lion was first used in 1850. I have a later model just like this one and really don't need it. BUT I just could not resist the offer of $14.53 delivered to my door. Besides, it will be a fun rehab and the finished project should have lots of charm.
The body looks like very tight grained beech. The sole is dished and needs to be flattened.
But I started with the blade. Seems the previous owner used a steel hammer on it.
So I need a little anvil time.
About fifty licks later and it was in much better shape. I can grind the edges flat from here.
The blade is in really nice shape, especially on the cutting end. It has a nice taper and is very thick at the end. I wire brushed it and cleaned off most of the scale and heavy rust.
It needs a new wedge but lucky for me the original wedge is present, well, most of it is--at least the important part. The blade is a little tight on the sides so I will carefully grind it to remove just a hair from each side. I find this a common issue with older woodies. The wood continues to shrink and it prevents the blade from adjusting properly. In my opinion, it is better and easier to grind the blade instead of opening up the mortise.
