turbowoodworker
Hey rich, not sure if this has been mentioned concerning your screw troubles, but I find that dipping brass screw in beeswax can help avoid breaking too.
Alright guys, need a little help. I have been designing this coffee table as I go and have a leg and apron design in mind. But I have run into an issue... I want to do a double bridle in the top of the legs. I had planned the aprons to be 3" tall which means the cuts in the end of each leg need to be 3" deep. The idea is to have the aprons run through each leg so that you see the end grain of the maple aprons on both outsides of each leg. I was going to notch the top of one apron and the bottom of the apron so they lock together in the center of each leg. I really didn't want to rebate the aprons where they meet the leg. The legs will be tapered from 3" down to 2" or 1 1/2" after the bridle cuts are made. My intention was to bring the taper all the way up to the table top.
Here is my issue: my dado set is only an 8" blade, leaving me with a maximum depth of ~2"... leaving me with 2 options... 1.) rebate the height of the apron to 2" where it will enter the leg, which takes away from the visual on the outsides of the legs, and also leaves me a angular issue to overcome so the joinery is tight. Or 2.) use a standard kerf blade to make multiples cuts until I reach the ~13/16" width thickness of the aprons and clean up the bottom of the notch with a chisel.
Any thoughts gentlemen? I am leaning towards the 2nd option, but thought I might ask some more experiences individuals.
...The large spot in the back looks like moisture from a flower pot. That is common with antique furniture. Long surface contact turns the walnut black...
Ahoy! Land ho! Flat surfaces spotted ahead!
WooHoo!
I'm not sure haven't figured out what I'm calling it yet. But it's probably more of a tote than a basketEba--Looks good. Is that a basket or tote? The dowels need to be fixed in place or trouble will ensue. All you need is a pin. Good luck to you and your project and to your friend who is getting married.
