Really nice looking woodwork! I like the contrasting colors and grain on the doors -- should take stain or clear sealer well and look even better.Recent project on 93' yacht. Owner wanted 4 single bunks for crew, where there was 1 island double with narrow shelves outboard. I widened the shelves and installed bunk rails, then reconfigured the double bunk into 2 singles with a filler (not shown).
I think I see a little round magnet on the right side embedded in the wood, so I'm guessing a bunch of those with a screw at each end holding the "magnet board" to the side of the case.Nice CRS! How are those No. 66 cutters held in place on the inside of the box?
Thank you.Really nice looking woodwork! I like the contrasting colors and grain on the doors -- should take stain or clear sealer well and look even better.
I often think about how smart you are to have "others" do the paint/stain work. That's the part of wood projects that I always hate. Do the boat owners usually hire the finish work out themselves, or do you ever act as a "GC" and subcontract out the finish work? I saw a can of West System on the shelf -- were you using that as glue, or did any of wood get an epoxy coating?
tx: marty was exactly right. It is another left over strip of mahogany with Forstner holes drilled a bit deeper that the neodymium magnets. I wanted to be able to see the profiles on both ends of the cutter. The uncovered magnet is for some future shop-made custom cutter. Well, that and the magnets came in a 10-pack.
Those small magnets are interesting to work with. They tend unexpectedly fly off. You won't have to look far though. They'll be firmly stuck to the nearest piece of steel.
Use self-stick sandpaper on the end of a dowel....I am having trouble figuring out how to sand the flat bottom of the Forstner holes...
carl: I'm not sure why you would want to sand the bottom of those holes. They won't be seen when the pins are in place. Is it the case that some of the pins don't sit in their holes correctly? If you had dowels of the same size you might be able to put PSA (Pressure Sensitive Adhesive) sandpaper on the ends and spin them in the holes. If you have a drill press and a short length of mild steel you could make a dowel plate and make the holes in it the same size as your dowel pins. Or, you could just buy short lengths of the appropriate size dowels.
Whatever your reasons for wanting them flat, it's a clever idea. Hey, I have some dowel pins too and a bit more scrap mahogany. Hmmm...
CRS, pics don't do the box or the table justice especially after seeing them in person. They came out amazing.I had some thin white oak that I wanted to use up and decided to make a box to hold my STANLEY #66 Beadng Tool and its accessories.
Box for STANLEY #66 Beading Tool
I also wanted to try making hand dovetails for a second time. I used Paul Sellers' Dovetail Technique and had excellent results. You may recognize the lid from my previous post about repairing dents in wood.
In general, when you make a mistake on a project you have a few options. You can: 1) live with it, 2) replace it, 3) hide it, or 4) feature it.
I made a huge mistake on the beader box. I made the lid too narrow to fit from the back to the front. It wasn't possible to live with it and
I didn't have enough wood left to remake the lid. I thought about buying more white oak but one of the main reasons for making the box
in the first place was to use up left over wood, not generate more left overs. That left options 3 and 4. I chose to make a feature of the solution by adding a small strip of mahogany (more leftovers) to the front edge of the lid to make it wide enough.
In addition to making a big mistake, I also overlooked decorating the box with some beading. I corrected that by making beaded mahogany side handles for it. Serendipitously, the three mahogany pieces added some style to the box. They're accent pieces. Yeah, that's what they are. I meant to do that.
Carl,carl: Nice job all around! I like the look of barrel hinges but I imagine that alignment could be tricky. I put a brand on my last box too.
Sounds like you're putting that router plane to work exactly as it was designed. Narrow stopped dadoes are a perfect application for it. How 'bout some pictures?STANLEY #66 as Router PlaneI knew that this odd cutter for the Beading Tool was for routing. One end is 1/4" wide and the other is 1/8" wide. Until today it was hard to imagine what I would do with a 1/8" router bit however, I'm installing 1/8" plywood partitions in a box to hold sharpening stones. Using the #66 I was able to make 1/8" wide stopped dadoes with flat bottoms exactly 3/16" deep. I'm amazed I could do that.
I am too.STANLEY #66 as Router PlaneI'm amazed I could do that.
carl: Those simple projects can getcha. I have a suggestion for sealing against the ceiling (see what I did there?) You may already know this but foam insulation 'tape' is cheap and comes in rolls. There is adhesive on one side. Peel off the cover and stick it to the frame. It comes in different widths and thicknesses.
Just remember, good, cheap & fast, you can only get 2, good & cheap wont be fast, cheap & fast wont be good & good & fast wont be cheap!This may be more home improvement than woodworking, but it is wood... Really just posting to lament a bad decision and how trying to save a little sometimes costs a lot. In this case, time.
We have a while house fan mounted in a hallway ceiling. To those not familiar, it's a giant fan that pulls air from inside your house and up into the attic, where it exits. It's great when hot summer days give way to cool nights. Open some windows and pull that cool air in.
There's nothing between those plastic louvers and the hot, dirty attic air. And no seal to keep it from seeping into the house. This became very evident when we had the terrible fires (I'm in Cal). We temporarily taped plastic over it too keep smoke out, but now it's time for something sturdier, insulated, air tight and easy to install and remove.
Simple thing, build something akin to a picture frame, where the glass is a sheet of 3/16 wood and the picture is foam board insulation. I have some 8ft 1x2 pine boards leftover from another project and decided to use those. Only when I looked at them they were banana shaped. This is where better judgement should have kicked in.
I tried to find straight parts and cut those out to use, but in the end there really wasn't. I also found the ceiling isn't flat, and the different boards were not exactly the same width and depth. So this has been a clusterf*** of a simple project. Gaps and ill fitting boards everywhere. I'm hoping to wrap it up today, but who knows. I did learn cheap can be expensive.
Some questions for those who spray the poly, or whatever you use for final finish.
What products and what sprayers do you use?
Currently, I'm using polyurethane, brushed with foam brushes, multiple coats, sanded between coats.
Satisfactory results, but time consuming.
Better options?
Better options?
Love this. My dad was a marine carpenter and I fondly remember watching him put together cabinets and furniture like this in his shop, and then getting to tour client's boats as it got installed.Recent project on 93' yacht. Owner wanted 4 single bunks for crew, where there was 1 island double with narrow shelves outboard. I widened the shelves and installed bunk rails, then reconfigured the double bunk into 2 singles with a filler (not shown).
Paint grade cabinetry, to match existing, with rails and double-doors to be finished natural.
I'll be using some Everlast Hinges from Home Depot for my basement gate project. Being all wood, I needed something heavy duty. They apparently can handle 60 lbs apiece. I went for function over looks, but they have a bunch of decorative hinges for gates.I just spent 15-20 minutes catching up and love all the new posts. Good to see this woodworking thread ALIVE AGAIN.
I’m getting ready to finish up cedar fence and start new deck so should have plenty of pics and work to share soon.
that said any of you know a good source for nice gate hinges?
