Vise Info Thread
ranger08
Thanks Ranger for these beauties, looks like the Bronze vise has steel jaws. Those will spark.
yes jaw plates are not original, will make some brass jaws when i can find the stock
i have several others, will post in a few days
tool_scrounge
Southern California
I was surprised to not see this in the spreadsheet
jaw width: 4”
max opening: 6.5”
weight: 7 lbs
has a swivel base
Unique design optimized for low cost. Both jaws move. The left jaw moves in ~3/4” increments. The right jaw has a short leadscrew to clamp the part. Together you get 6.5” of travel.
mikeinri
Wow, just found this thread, very overwhelmed by all the info and history here!
Mike
F
FMC1959
Montreal, Canada / Upstate NY
Beauties, like Kevin said and quite a diverse collection. It does not say under your name/avatar, may I ask where you are located...USA, Europe, Australia...etc.
I love the classic US vises like Parker, Reed, Athol and many other brands. But when I see models like your Joplin, Stabil (fabulous and beautiful condition), the brass Parkinson, and then the unpronounceable German vise...just WOW!
ranger08
im in New Zealand, our old tools here were generally imported from england and australia in past, and an eclectic range from europe, very little early trade with the US, although i do have many US vises however they are well covered in these forums.
ranger08
Wow! Any lettering / branding on the last two, @ranger08?
Mike
The Parkinson never had branding at that date however either had a “0” or a “1” stamped internally, this one had a “0”, apparently later when other companies were copying this design then patents were included in the castings by Parkinson
the boley has date and casting numbers and production number
KMScott
Athol #79 with a E.M. EK Swivel base. Years ago I had a Athol 79 missing it's swivel base. Instead I built my own swivel base to make the vise whole again. Now the mystery is found with this Athol 79 mounted to a E.M.EK Patented swivel base.
3" jaws that opens to 3-1/4".
ranger08
Stabil 60 DBGM
germany late 1930s to 1950s cast iron
jaw 2.5” open 2 ” weight 11 lbs
Just found out through a fairly reliable source that dbgm was a type of patent that stopped use after 1945
also Stabil was a company that made metal toys and mechano type toys prior to ww2, they were then made to make medals and the like for the axis forces.
antman213
I have the opportunity to get a Hollands No 60 (6" Swivel base vise).
But i'm having a hard time finding much info on general info on Hollands.
In particular, when did they stop making vises (or get bought by Yost) and what is the difference between a No. 60 & a No.26H. I'm they seem to be very similar but is one just a newer model of the other?
Also, why are the swivel hold downs so short, not very many pictures available of one deconstructed to show the swivel base.
Any info would be much appreciated
akasrick
south jersey
Regarding the swivel hold downs; I think they are stubby just so's they don't interfere with reading the side. How large are the swivels balls, will they interfere with tightening the vise down?
akasrick
KMScott
Antman, pic’s would help since the model 60 on the Spreadsheet looks to have been modified. The 26H has cast in jaws and if the 60 has replaceable jaws I would say the model 60 is newer. I have restored a 27H and really liked the swivel base movement and how well it locked down but did question like you the height of the lockdown body and handle. Share some pic:s and maybe I can replace the pic:s on the Spreadsheet with your vise, oh you should already have the vise by now right.
akasrick
south jersey
Kevin: The H22 1/2 on the spreadsheet, mine, is a good candidate for replacing with a correct vise. My quandary when getting the replacement lockdown machined was getting it close to original or obviously incorrect.
It's a handsome vise.
akasrick
Altman, pic’s would help since the model 60 on the Spreadsheet looks to have been modified. The 26H has cast in jaws and if the 60 has replaceable jaws I would say the model 60 is newer. I have restored a 27H and really liked the swivel base movement and how well it locked down but did question like you the height of the lockdown body and handle. Share some pic:s and maybe I can replace the pic:s on the Spreadsheet with your vise, oh you should already have the vise by now right.
akasrick
skmbabon
Ottawa
1939 ad for Fray-Mershon "Defiance" line of vises. No mention of the publication name.
These 2 models, with stationary and swivel versions, are not in the spreadsheet.
Only Fray-Mershon (F-M) vise listed so far is 4M All Angle vise (Versa-Vise type) https://www.garagejournal.com/forum/threads/vise-info-thread.355753/post-6822187.
More pictures of 4M at https://www.garagejournal.com/forum/threads/weird-vise.375070/.
F-M thread w/link to patent for 4M at https://www.garagejournal.com/forum/threads/fray-mershon-vise.166868/.
There is also a #2 (presumably a 2M) and 3M which could be added to the spreadsheet.
An "All Angle vise #2" from Fray-Mershon in Glendale is mentioned in this thread: https://www.garagejournal.com/forum/threads/versa-vise.216044/.
There's a F-M 3M All Angle vise on Worthpoint: https://www.worthpoint.com/worthopedia/antique-fray-mershon-3m-all-angle-423856568.
@PghJKB shows the JR Long "Permutation vise" patent that the F-M All Angle vises are based on, and mentions he's researching the history of the type, at https://www.garagejournal.com/forum/threads/the-vises-of-garage-journal.44782/page-2110.
skmbabon
Ottawa
Perfect No1, claims to be made in Japan. 3-1/2" jaws, no other specs. Not in spreadsheet.
Dynamic rear and an interesting slide shape.
skmbabon
Ottawa
Trojan 726 pic for spreadsheet entry
