yes jaw plates are not original, will make some brass jaws when i can find the stockThanks Ranger for these beauties, looks like the Bronze vise has steel jaws. Those will spark.
Beauties, like Kevin said and quite a diverse collection. It does not say under your name/avatar, may I ask where you are located...USA, Europe, Australia...etc.yes jaw plates are not original, will make some brass jaws when i can find the stock
i have several others, will post in a few days
im in New Zealand, our old tools here were generally imported from england and australia in past, and an eclectic range from europe, very little early trade with the US, although i do have many US vises however they are well covered in these forums.Beauties, like Kevin said and quite a diverse collection. It does not say under your name/avatar, may I ask where you are located...USA, Europe, Australia...etc.
I love the classic US vises like Parker, Reed, Athol and many other brands. But when I see models like your Joplin, Stabil (fabulous and beautiful condition), the brass Parkinson, and then the unpronounceable German vise...just WOW!
The Parkinson never had branding at that date however either had a “0” or a “1” stamped internally, this one had a “0”, apparently later when other companies were copying this design then patents were included in the castings by Parkinson
Just found out through a fairly reliable source that dbgm was a type of patent that stopped use after 1945
Regarding the swivel hold downs; I think they are stubby just so's they don't interfere with reading the side. How large are the swivels balls, will they interfere with tightening the vise down?I have the opportunity to get a Hollands No 60 (6" Swivel base vise).
But i'm having a hard time finding much info on general info on Hollands.
In particular, when did they stop making vises (or get bought by Yost) and what is the difference between a No. 60 & a No.26H. I'm they seem to be very similar but is one just a newer model of the other?
Also, why are the swivel hold downs so short, not very many pictures available of one deconstructed to show the swivel base.
Any info would be much appreciated
Altman, pic’s would help since the model 60 on the Spreadsheet looks to have been modified. The 26H has cast in jaws and if the 60 has replaceable jaws I would say the model 60 is newer. I have restored a 27H and really liked the swivel base movement and how well it locked down but did question like you the height of the lockdown body and handle. Share some pic:s and maybe I can replace the pic:s on the Spreadsheet with your vise, oh you should already have the vise by now right.
Parker Union 973-B 3" wide jaws
Nice job on this. I really like that paint!973-1/2 B Parker vise. Weights in at 41 lbs, max opening is 6-1/2" the jaws are 3-1/2 inches wide.
skmbabon said:No mention of the publication name.
Thanks. It's possible. Closest issue I found was July 1940. Page layout looks the same."Hardware Age", perhaps?
Been studing skm's post links and have not seen enough info to answer your question. Surly it tightens somehow.Does the swivel lock on tightening?
Possibly a Jersey vise with the clamping section cut off.Anybody know what this is there is no branding on it
