Above 1200 Sq/FT Finally build my, long needed, shop
loganb
Omaha, NE
Nice looking addition! It sure makes it more enjoyable when it's not most of an afternoon to get done! The yard I grew up mowing was 4 hours with an 80's vintage 300 series Deere and 48" deck, was just over 2 hours after it got upgraded to a Deere zero turn with a 54" deck and is now a shade over an hour with a bigger diesel Grasshopper...so cutting that yard from 90 to 30 minutes seems very reasonable!
Heads up.....you'll probably find a few spots that aren't as smooth now that you're running 6 or 7 mph...so guessing some "smoothing" gets added to the fall project list!
Michael B.
Huntsville Al
You are correct about needing some smoothing out. I was already aware of some areas with the lawn tractor.
Michael B.
Huntsville Al
I spent some quality time with the 68’ today. I bought new tires for it about a week ago. While the wheels were off I decided to clean and wax them. The Krylon I used 19 years ago is starting to fade 🤷🏻‍♂️ It was also time for front brakes and wheel bearing repack. Then I started working on the heater core replacement I have been procrastinating on since the end of winter.
4D53E51A-2553-4E51-A5CA-E12C139E1F99.jpegD25AA1EC-7A11-4354-A014-87FBCAC51041.jpeg40E527D9-FDFF-456E-9148-C05EFF950910.jpeg5D43704A-CED1-4AB4-8141-B76BC61B7552.jpegF149E1D5-C89D-4D24-AC73-D249D5DE8936.jpeg06A909B5-6288-4CE6-BB82-BB5E0CA3B145.jpeg
Michael B.
Huntsville Al
Well fella’s, this week has been a mixed bag of blessings.
First the good news. I hired my daughter and SIL to install the leftover copper material underneath the front porch roof. It turned out pretty nice. I also have some blue materials leftover, so eventually I want to trim out the remaining areas under the porch with it. Maybe this will help keep the carpenter bees at bay next spring.
Now for the not so good news. I learned this week, that in the not too distant future (maybe 5 years max) there will be an overpass built behind my property, that may or may not encompass my shop. Even if the shop stays, I don’t want to live next to an overpass. I’m not certain about what happens next. There is still much to be discovered and discussed.
Michael B.
Huntsville Al
Did they give you any idea how long the overpass has been “thought about” prior to you finding out?
That’s too bad.
Captain this project has been ongoing for a couple of decades. There were at least 5 different routes being considered on this side of the county. I knew some came near my neighborhood but I didn’t know any of them came through the neighborhood. This plan will essentially cut the subdivision in half.
Mark_17
If Alabama is anything like NJ, that overpass might start construction in 10 years and finish in 100 years. I hope for your sake, that's the case.
Chrisb62
southwest fl
That is absolutely crappy news.......
Just when you are nearing the completion line as well.......on a awesome looking shop.
Michael B.
Huntsville Al
Saturday I listed the 68’ on Craigslist 🥺 Sadly it’s time to let someone else enjoy the ol’ truck. I will miss it, that’s for certain.
Sunday I introduced the newest member of the gang to the rest of the crew. She even got to ride the lift.
Michael B.
Huntsville Al
I started a new project in the shop this weekend. Ever since I completed the wall for the office/mezzanine, I have wanted to build a small roof section using leftover materials. I began the framing yesterday and finished the it this evening. Next I will install copper metal for the roof. The end of it will get either red or blue metal. The 👸🏻 thinks it should be red but I’m leaning towards blue. Any opinions fellas?
jbrentd
Northeast Oklahoma
Nice work at making use of the extra materials in creative ways. The copper under the porch looks great! I also think blue would be good in the shop awning. That will make a great transition into that area.
Sorry about the news regarding the nearby overpass.
Michael B.
Huntsville Al
Thanks Brent.
