Show us your handplanes
Farmer J.
UK, Cornwall/Hertfordshire.
Looks like someone else has the Spokeshave book!!
Has anyone here got the 'Planecraft' book?
I used to have a copy of it when I was a kid but that was stolen, and I see there's plenty for sale secondhand and wondered if it was worth getting another copy?
I found this info about it on 'UK Workshop' forum:
The original book, "Planecraft, Hand Planing by Modern Methods" was written in 1934 by CW Hampton, who was a director of C&J Hampton, who traded as Record Tools, and E Clifford who was later described as 'one of the most knowledgeable plane men of his time.'
It was published and distributed by C&J Hampton, rather than through the book trade. It was revised and enlarged in 1950 and 1959. It was a hardback, 8 1/2" x 5 3/4", of up to 250 pages.
In the US, Woodcraft Supply Corp published a softcover facsimile reprint of the 1959 edition in 1980.
in 1984 John Sainsbury published another, more radical revision under the title "Planecraft, A Woodworker's Handbook." Published by Sterling Publishing in New York, this had a larger page size of 10" x 7 3/4" and ran to 192 pages. In the UK it was distributed by Blandford Press.
ararat
Ararat NC
Looks interesting. It is on archive.org, but you have to log in to "borrow" it to view. https://archive.org/details/planecrafthandpl0000mode/page/7/mode/1up
I haven't tried it yet.
ararat
Ararat NC
Here's one of my favorite planes from my collection. Edward Preston moving fillister plane. I think the "T" joint between the boxing and the body is really cool.
When I got it, it was missing the nicker and wedge and the guide was cracked. I was able to glue the guide back together. I made a new nicker blade from an old unmarked tongue and groove plane blade. The wedge was from a scrap piece of beech. The nicker wedge on the original would have had the bump on the wedge facing forward I learned later, but I am going to keep it the way it is.
I have the 1972 reprint of the 1959 version. Have not read it. It started really slow. I need to pull it out and try it as a reference book.
(Just technical stuff on the book, not a readable copy)
Will look at the combo plane section, see if it speaks of working backwards.
Farmer J.
That could be interesting, I wonder what it says about that. It's over 50 years since i read it, so I can't remember exactly what it said! A professional traditional joiner friend of mine does work backwards with short strokes when cutting rebates and grooves etc, it's only the last few passes he does a fine cut full length of the work.
That's exactly how I was taught, maybe 15 years ago. That's why I figured it was a good place to look, a miracle worker of process improvement for me.
CRSINMICH
Southeastern Michigan
D.R. BARTON Coopers' Spokeshave
I've had this for some time but I looked at it closer after seeing the LARGE shaves in previous posts.
CRSINMICH
Carriage or Coach Makers' Router
I've had this one for a time also. I thought it was a weird kind of spokeshave. Looking at the catalog for the DR Barton shave (above) I saw the router. This one is NOT the Barton router. It's cast iron. I still don't know the maker. It seems to be a fairly rare type of shave/router hybrid and it's heavy duty. Anyone have more information?
ararat
Ararat NC
I haven't seen one like that before. That color is similar to Tyzack, you might check their catalog. I feel like maybe it was user made by a patternmaker. It's definitely a cool design. I have this little guy that is a similar color. Mine is unmarked as well.
Looks like a Geral or look-alike. Based on the Spokeshave book that @ararat showed above, probably a boxing cutter. Without stealing too much text out of the book here's a couple of illustrations. Edit: Dang, he caught me while editing
My two bit understanding, Carriage or Coachmaker's routers were designed to do the intricate decoration that early carriage users demanded for city life (the pinstriping of the day). Do lots of tools for cutting spaces for inlays, fat and thin, and following the curves of the carriages.
The book says this catalog carries them, but I don't see them
Hammacher Schlemmer 1930 and Walters 1888 - 1896 were also supposed to carry them.
Here is one I picked up from auction in the UK that arrived a few weeks ago. Very thin cutter, almost stringing level decorations.- No detailed pics, no name, nothing. I just took the arrival shot, and stashed it away for a few weeks. You can see the fence anchor point on the left, the hidden face is curved toward the cutting edge, and the cutter is between 1/16" - 1/8", at a guess. More here later in a few weeks. Those other two in the front left will make an appearance too.
ararat
Ararat NC
These got my attention
ararat
Ararat NC
These might have done some coach building, but weren't specifically marketed that way in the catalog. Preston Quirk Router, Rabbeting shave, sash router, Oveloe router. I have the guide off the quirk router so it will fit in the drawer.
CRSINMICH
RTM and ararat: Thanks for the information! The catalog photo was especially helpful. It was hard to imagine how this tool would have been used without a fence and I didn't see any indication of one. The photo shows tabs on the top and bottom edge of the router. Those must be the fence mentioned in the text. There's no indication of how the fence would have been held in position but I think I can imagine how it was done. BTW, the cutting iron on mine is made from 10mm square stock and the cutting edge is 15mm wide or, roughly 13/32" square stock with a cutting edge of 18/32".
ararat
Ararat NC
I think it would have been for cleaning up already existing grooves squaring up the bottom, so the fence wouldn't necessarily be needed if it was initially cut with another tool. I wish I knew more about carriage/coach building though. I have a coach makers vise that I couldn't find much on how it was actually used.
Eric Brown
It also would have been handy for tenons with that long registration area. No fence needed.
CRSINMICH
ararat: Click on this link to get to an 1859 issue of The New York Coach-Makers magazine. I doesn't give much information about building a coach but it's interesting to browse.
On page 103 of the November 1859 is an article about a "Locomotive Steam Carriage for Common Roads". That sucker could hit 12-14 mph on level roads. However, it burned 6-7 lbs. of coal per mile.
Joe Huld
South Pasadena Ca.
I won 2 boxes of miscellaneous old tools at a local auction. This Sargent 710C in the bottom was my goal.
Pretty cool I think it is one of the post 1915 planes with the high knob 1915 patent date cast in the bed. The cap is the single setting type that appeared in the patent application and was used in regular production after 1915. I recently got a very early " pre patent" 710C with a low knob, no patent date on the bed, and the triangular 1-2-3 cap. Attached are pictures. Apparently, this early type was made only in the 710 size and the 2 or 3 other examples I have found pictures of are smooth bottoms. The Auto Set planes hit the market years before the Stanley metallic Gage planes. The Sargent auto set planes are much less common the Stanley Gage planes
Cleave
Back Porch
Here's a couple of my unusual planes.
The first is by Metallic Plane Co, Auburn NY, and is a great alternative to a #5. The adjustable mouth is great.
The second is my oldest known tool - Randall and Cook, Auburn NY Rabbet Plane. As I recall the book dates this to 1835-39. Excellent condition!
CRSINMICH
Cleave: Those are both nice planes. Curiously, the Randall and Cook looks like it has a spring line and some boxing. I'd expect to see both on molding planes not rabbet planes. I guess they made things a little differently 190 years ago.
Cleave
Back Porch
Is that a 2"? Nice n beefy looking
2-1/4" wide iron.
The plane has a narrow strip of boxing and also a spring line.
Maybe they used that plane for the tapered edge on paneling and wanted a reference line for consistency.
The Randall and Cook cost $8 at a local auction with online bidding - I bid on it sight unseen, not knowing maker or age or anything.
ararat
Ararat NC
Could be "work in progress". It looks like maybe it was going to be a molding plane, but was never finished. Would add more cool factor to me if so. A pic of the bottom of the plane would be interesting. Nice planes.
Cleave
Back Porch
Here's the bottom of the rabbet plane. Looks to me like it was meant to be a rabbet.
I'd guess one workman on one job needed a spring line for some tapered step.
Here's a bonus shot of a couple A. Mathieson and Son and an Ohio Tool plow planes.
I had to bid on 3 of them to get a range of irons then won them all.
Also an old joiner back there made by Tileston in Boston probably circa 1840's.
sggoat
Trainman: any chance you might have before, during and after restoration of one or two of your planes? i know i for one would really enjoy watching a pro do one. i think i saw one on GJ last year, but not sure where to find it. if you know and can provide links on this thread i bet a lot more members will grab them and save them from the scrap yards.
i know one guy that has a cabinet full of nicer planes than my union and i think he had a couple of them on like new condition. i'd also be surprised if there isn't a web site or a forum on these good old tools.
thanks again for starting this thread
go to patrick Leach's Blood and Gore--all things Stanley, plus more
