Blocking rust after evaporust?
^ depends entirely on the item and your intended purpose.
A recently re-worked hacksaw got a couple coats of clear acrylic Krylon on the frame to keep it from rusting.
I didn't use "Evaporust" on these 10-inch Eclipse snips, but after cleaning they got a coat of carnauba wax and a drop of MMO on the joint.
Not sure exactly what I'll do with these gigantic open-ends yet. They'll probably get the same treatment as all the sockets in the photo below: after the "Evaporust" bath for three days, they got a bath in boiling hot water, trisodium-phosphate, and "Simple Green", then a quick rinse and then about half an hour in a 250° F oven, and then I wiped them all down with a cloth rag and "3 in 1" oil. The ratchet, breaker, sliding T, and extensions all got a heavy coat of carnauba wax (after cleaning and oiling the detents on them.)
Would I recommend this method for tools you're going to use in a shop environment? Not necessarily. The wax made the ratchet and breaker slipperier than deer guts on a doorknob, but it will keep them looking pretty long enough for me to sell them.
YMMV
Every man on this website has his own method. More (and different) answers to follow:
Bmberzins
Wipe the tools down from time to time or after cleaning them up with Power Lube or Liquid Wrench"Rust Inhibiter #LC9" on a rag or shop towel ? Maybe even with automatic transmission fluid (new or used)
Thanks, I have always had good luck with their products.
Steve_P
Although a different product, I like Metal Prep by POR15. It's a phosphoric acid and zinc phosphate product that will stop rust from returning, unlike evaporust. The only negative, if you care, is that it can darken the metal, from gray to black depending on how long you soak it. I've posted may pictures before, so search if you're curious.
JradM
Alberta
Paint. Though I think you'll need to wire-brush after evaporust to make sure you have a stable surface.
Wakefield
Arlington VA (but would like to get out to country
I assume that you have to remove every trace of that product from the metal after it has done its job ? Converted the rust to inactive "blueing" ?
fishwatcher
I think Krud Kutter for Rust is supposed to not just stop rust, but treat it for the future. check and see if it fits your use case.
It’s not a pretty result though.. the metal will blacken or turn dark grey and white. If you polish that off.. I wonder if you’ve then removed the rust protection.
Steve_P
No, you can leave it on. Forever. If you want. Or sandblast it off. Just whatever finish you want. I've got bare metal parts sitting in my basement for 20 years that haven't rusted after treatment with it. Granted, my basement is somewhat climate controlled, but it's also not arizona dry.
Search for my posts on it, it gives anywhere from a gray to a black finish. I've been using it for decades and love it. It's the next best thing to a true hot phosphate finish, which I also do. The typical cold blue treatments are absolutely **** in comparison to Metal Prep. I have used evaporust, but don't care for it because items typically just rust again within a few days- in that same basement.
RedRambler
Based on the thread topic, this might be the better audience, compared to my other post in the polishers haven thread.
I did a hammer for my dad last fathers day, polished the head. I saw the hammer over this weekend and he had not put any oil on it. Which lead to rust spots. I plan on repolishing it for him but in an effort to keep things from rusting, do any of you use a rust preventive coating, besides simply rubbing with oil? My initial research has lead me to Dry Coat as a solution, but it appears to only be available in 5 gallon buckets and up (which makes it a no go for me). I did find another option Rust Veto which is available in aerosol and up to 55 gallon drums. Curious if anybody has used one of these products or has a suggestion for another product or alternative to keep rust at bay for polished steel items.
JradM
Alberta
It's hard if you wish to maintain a polished surface. I'd probably suggest wax - it doesn't have to be so thick that it makes things cloudy. Lee valley as special "tool wax" that isn't very expensive, but regular ole carnauba wax like you'd use on a car works well too.
I haven't tried the fancy modern ceramic finishes myself, but if it works on car paint, it would probably work on a polished tool. Those ceramic coatings are purported to be extremely robust.
RedRambler
Thanks Jrad, good info. I did find the Lee Valley Tool Wax. I am sure you are correct and a ceramic coating would work also, like the one used on wheels. I will probably go the Carnauba route as that is much more readily available for myself.
Maui
Upstate NY
After derusting and going down to bare metal using a variety of different techniques I will either paint, use Johnson's paste wax, or use 3-in-1 oil depending on the tool or part. For drill press columns and metal lathe surfaces I almost exclusively use 3-in-1 oil. I like it because it is a non-detergent SAE 20 oil that goes on easy, smells good, and keeps the rust at bay for months on end.
RedRambler
I think that might be the ticket for a lot of items that I keep. The other aspect for example is the hammer for my dad, it will be out of sight out of mind regarding rust. That is why I thought something that could be sprayed on might offer the best results in that scenario. I will for sure get a bottle of 3 in 1 for my own tools. I tend to wipe all my tools clean after use, so doing so and applying some oil as needed is appealing to me. Below is one example of what I would try to protect, being polished might make it tough since it doesn’t have any texture for a spray to stick to. Wax might be my only option for this.
JradM
Alberta
I've a tangential idea - how about you nickle coat it?
It's inexpensive and easy to diy. You can get some strips of nickle from Amazon and the only other substantial ingredient is a low voltage power source - like a wall wart.
gregs
Do you have a link to any specific info on how to do this?
RedRambler
Another vote for Fluid Film. I use it on most tools after they come out of the evaporust. Kind of smelly but very effective.
What is the finished feel of fluid film? Is it slippery as WD40 would be? I want to find something that is dry, but offers protection.
Buy a can and give it a try. It’s not all that expensive. If I don’t plan on using the tool soon, I leave a fairly thick coat on the tool. If I’m putting it to use in the near future I wipe the excess off with a paper towel.
^ Yes. The price of a can of "Fluid Film" is well worth the investment. If you don't like it on your tools, it will silence those shrieking garage door rollers.
RedRambler
Haha. I like it. It looks like my local auto zone carries it so I will give it a try for sure.
^ Hey, I was actually going to call out for some bids for mine - they were just HOWLING. Couple shots of that goop and they're quiet now.
Silence is worth twice the price of a can of that stuff. :thumbup:
bwringer
Indianapolis
Fluid Film is lanolin, an extremely thick, sticky, waxy grease.
Lanolin comes from wool (it's the skin secretions of sheep), so it also has a very strong and extremely unpleasant odor of unwashed sheep. Unless you find this arousing, Fluid Film is best used on stuff that stays outside well away from your house.
It is a very effective and tenacious corrosion preventative.
Fluid Film will attract dust, and as an animal grease, many have found that dogs absolutely love the stuff. If you spray it on your truck, check underneath for dogs licking the frame before you go anywhere.
RickyPetite
Buck's County, PA
CRC Marine Corrosion Inhibitor. It's basically Cosmoline, used by the Navy on their deck guns. Ideally, you let it dry/cure to an amber finish (like varnish). I apply it, wait a few minutes and wipe it down. Probably lower its effectiveness but I can't notice a gummy finish. Never have a problem with rust ever since.
RedRambler
Cosmoline is what rust veto had listed on the description. I will look into CRC. Does it leave a slippery feeling? In my mind varnish is quite grippy once dry.
