Thanks, I have always had good luck with their products.Wipe the tools down from time to time or after cleaning them up with Power Lube or Liquid Wrench"Rust Inhibiter #LC9" on a rag or shop towel ? Maybe even with automatic transmission fluid (new or used)
Every man on this website has his own method. More (and different) answers to follow:
They don’t let their tools get rusty, and don’t buy rusty tools.I wonder what the women do?
I assume that you have to remove every trace of that product from the metal after it has done its job ? Converted the rust to inactive "blueing" ?Although a different product, I like Metal Prep by POR15. It's a phosphoric acid and zinc phosphate product that will stop rust from returning, unlike evaporust. The only negative, if you care, is that it can darken the metal, from gray to black depending on how long you soak it. I've posted may pictures before, so search if you're curious.
It's hard if you wish to maintain a polished surface. I'd probably suggest wax - it doesn't have to be so thick that it makes things cloudy. Lee valley as special "tool wax" that isn't very expensive, but regular ole carnauba wax like you'd use on a car works well too.Based on the thread topic, this might be the better audience, compared to my other post in the polishers haven thread.
I did a hammer for my dad last fathers day, polished the head. I saw the hammer over this weekend and he had not put any oil on it. Which lead to rust spots. I plan on repolishing it for him but in an effort to keep things from rusting, do any of you use a rust preventive coating, besides simply rubbing with oil? My initial research has lead me to Dry Coat as a solution, but it appears to only be available in 5 gallon buckets and up (which makes it a no go for me). I did find another option Rust Veto which is available in aerosol and up to 55 gallon drums. Curious if anybody has used one of these products or has a suggestion for another product or alternative to keep rust at bay for polished steel items.
Thanks Jrad, good info. I did find the Lee Valley Tool Wax. I am sure you are correct and a ceramic coating would work also, like the one used on wheels. I will probably go the Carnauba route as that is much more readily available for myself.It's hard if you wish to maintain a polished surface. I'd probably suggest wax - it doesn't have to be so thick that it makes things cloudy. Lee valley as special "tool wax" that isn't very expensive, but regular ole carnauba wax like you'd use on a car works well too.
I haven't tried the fancy modern ceramic finishes myself, but if it works on car paint, it would probably work on a polished tool. Those ceramic coatings are purported to be extremely robust.
I think that might be the ticket for a lot of items that I keep. The other aspect for example is the hammer for my dad, it will be out of sight out of mind regarding rust. That is why I thought something that could be sprayed on might offer the best results in that scenario. I will for sure get a bottle of 3 in 1 for my own tools. I tend to wipe all my tools clean after use, so doing so and applying some oil as needed is appealing to me. Below is one example of what I would try to protect, being polished might make it tough since it doesn’t have any texture for a spray to stick to. Wax might be my only option for this.After derusting and going down to bare metal using a variety of different techniques I will either paint, use Johnson's paste wax, or use 3-in-1 oil depending on the tool or part. For drill press columns and metal lathe surfaces I almost exclusively use 3-in-1 oil. I like it because it is a non-detergent SAE 20 oil that goes on easy, smells good, and keeps the rust at bay for months on end.
I've a tangential idea - how about you nickle coat it?I think that might be the ticket for a lot of items that I keep. The other aspect for example is the hammer for my dad, it will be out of sight out of mind regarding rust. That is why I thought something that could be sprayed on might offer the best results in that scenario. I will for sure get a bottle of 3 in 1 for my own tools. I tend to wipe all my tools clean after use, so doing so and applying some oil as needed is appealing to me. Below is one example of what I would try to protect, being polished might make it tough since it doesn’t have any texture for a spray to stick to. Wax might be my only option for this.
Do you have a link to any specific info on how to do this?I've a tangential idea - how about you nickle coat it?
It's inexpensive and easy to diy. You can get some strips of nickle from Amazon and the only other substantial ingredient is a low voltage power source - like a wall wart.
I am curious about this process as well. If the end result is a durable coating with a shine!!Do you have a link to any specific info on how to do this?
Looks similar to anodizing at home, which I have not done, but seems pretty cool to me. Once the power supply is sourced, seems like you could nickel plate for cheap. Thanks for the video!!
What is the finished feel of fluid film? Is it slippery as WD40 would be? I want to find something that is dry, but offers protection.Another vote for Fluid Film. I use it on most tools after they come out of the evaporust. Kind of smelly but very effective.
Haha. I like it. It looks like my local auto zone carries it so I will give it a try for sure.^ Yes. The price of a can of "Fluid Film" is well worth the investment. If you don't like it on your tools, it will silence those shrieking garage door rollers.
Fluid Film is lanolin, an extremely thick, sticky, waxy grease.What is the finished feel of fluid film? Is it slippery as WD40 would be? I want to find something that is dry, but offers protection.
Cosmoline is what rust veto had listed on the description. I will look into CRC. Does it leave a slippery feeling? In my mind varnish is quite grippy once dry.CRC Marine Corrosion Inhibitor. It's basically Cosmoline, used by the Navy on their deck guns. Ideally, you let it dry/cure to an amber finish (like varnish). I apply it, wait a few minutes and wipe it down. Probably lower its effectiveness but I can't notice a gummy finish. Never have a problem with rust ever since.
