Above 1200 Sq/FT Garage Refurb®
N
NUTTSGT
Northern Central Ohio
Eric, I love those dollys. I have about a dozen. Use them constantly and they take the abuse. Recently supported four corners of a pallet so I could load the pallet and move anywhere I wanted. Set the beetle wheels on it and they go anywhere. I even disassemble them to put the caster on other things. Great buy indeed!
When they were cheaper, like $8 plus the old 20% off coupon, I would buy them to rob the casters off myself. You couldn't beat the price for 4 casters.
N
NUTTSGT
I couldn't help myself and hoped to stack a 15% coupon but it didn't work. I know some have had luck doing but I didn't. . . didn't stop me though.
I've considered this for awhile since I got the new boxes and being this close to the press.
I wanted to put all my press "related" stuff in here. Like this
N
NUTTSGT
Well, seeing those boxes, outlets and covers above, its obvious, I'm adding g outlets somewhere in the garage. Yes, going to replace a couple of single gang boxes with doubles.
One reason is the 56" boxes have an outlet strip built in the drawer. What i don't like is how the cord comes out the back.
We're looking at like 3" behind the box of clearance needed without really straining the cord. So doing some research, I found theses on The Jungle.
zmotorsports
Northern Utah
Couple of more pics.
Here's clearance I gained cutting the rod down.
Eric, that is similar to how I have the rods for my hydraulic press. I have no bulbous end on either side and just slip them in from the front up to flush with the front of the adjustable worktable/beam. I like the drawer to hold the press accessories, I just have mine on a side table that I built, but I like your drawer setup.
N
NUTTSGT
Thanks Mike. I know when we ( neighbor & I) built the press, he said to put ends on the rods so they don't accidently get pushed or bumped in. Home shop maybe not an issue but factory updating/remodeling was his area of work at the time.
:dunno:
zmotorsports
Northern Utah
:dunno:
Yeah, none of our commercial hydraulic presses have those bulbous ends either, they all just have straight shafts/pins. In reality a retaining pin being "bumped in" is probably less of a concern than one would expect.
