Above 1200 Sq/FT Garage Refurb®
N
NUTTSGT
Northern Central Ohio
Eric, I love those dollys. I have about a dozen. Use them constantly and they take the abuse. Recently supported four corners of a pallet so I could load the pallet and move anywhere I wanted. Set the beetle wheels on it and they go anywhere. I even disassemble them to put the caster on other things. Great buy indeed!
When they were cheaper, like $8 plus the old 20% off coupon, I would buy them to rob the casters off myself. You couldn't beat the price for 4 casters.
N
NUTTSGT
I couldn't help myself and hoped to stack a 15% coupon but it didn't work. I know some have had luck doing but I didn't. . . didn't stop me though.
I've considered this for awhile since I got the new boxes and being this close to the press.
I wanted to put all my press "related" stuff in here. Like this
N
NUTTSGT
Well, seeing those boxes, outlets and covers above, its obvious, I'm adding g outlets somewhere in the garage. Yes, going to replace a couple of single gang boxes with doubles.
One reason is the 56" boxes have an outlet strip built in the drawer. What i don't like is how the cord comes out the back.
We're looking at like 3" behind the box of clearance needed without really straining the cord. So doing some research, I found theses on The Jungle.
zmotorsports
Northern Utah
Couple of more pics.
Here's clearance I gained cutting the rod down.
Eric, that is similar to how I have the rods for my hydraulic press. I have no bulbous end on either side and just slip them in from the front up to flush with the front of the adjustable worktable/beam. I like the drawer to hold the press accessories, I just have mine on a side table that I built, but I like your drawer setup.
N
NUTTSGT
Thanks Mike. I know when we ( neighbor & I) built the press, he said to put ends on the rods so they don't accidently get pushed or bumped in. Home shop maybe not an issue but factory updating/remodeling was his area of work at the time.
:dunno:
zmotorsports
Northern Utah
:dunno:
Yeah, none of our commercial hydraulic presses have those bulbous ends either, they all just have straight shafts/pins. In reality a retaining pin being "bumped in" is probably less of a concern than one would expect.
N
NUTTSGT
A little project for the afternoon... parents have a bird feeder that needs attention. They're having issues with '**** and squirrels getting up the feeder pole. Step dad used to have piece of duct work on it for prevention...
They bought a new feeder and his mental condition, he couldn't repair the duct work so here's what I came up with.. pole is 1.5" rigid conduit, so I bought a coupling and bent up some steel. A few minutes with the Horbart and its now a duct bracket.
It'll fit something like this, inside the 8" round duct.20260716_153759(0).jpg
I added a close ****** and a coat of paint. Hopefully tomorrow will be installation. 20260716_154301.jpg
N
NUTTSGT
How involved is it to attach and detach the backhoe? Is that a frame mount? Mine's a 2038R, so I suppose a backhoe would be similar on mine?
Should be the exact same being a 2038R compared to my 2032R. The only real difference would be the turbo for the extra 6hp.
It was fairly easy to detach, attaching should fairly simple as well. I will find out later today when I swap them out again.
Honesty, I thought it was going to be removing a frame and more buts just a different quick attach compared to the 1025R I had previously.
A couple of pics of the backhoe mounting framework.
Prospecter
Maine
You would also need a power beyond kit for the hydraulic side of it if you don't already have it.
Thanks for the reply and the pictures. Looks like a slick set up. Nice to have the Frontier attachments, too. I have a collection of attachments acquired over 40 years. Some work well with the iMatch system. Some not so much.
N
NUTTSGT
I bought this unit used as a TLB. It also already had dealer installed for 3rd function hydraulics and included grabble. It's not a huge machine but a noticeable difference over the previous 1025R TLB that I had previously.
I think its the prefect size for me, which includes working in the woods at my parents place.
N
NUTTSGT
Some if you may remember the tiling project I started back in May...its now finished. . . Just side tracked with work, other projects and life in general.
Ready for grass seed which my step-dad is going to take care of. . . If not, I will go back over and do it.
Here's a second area that stayed very wet a where I had previously gotten stuck trying to get this project done.
Probably hard to see on a phone, especially since the river rock is still dirty. After the rain last night, its probably cleaner. There's 2 tiles Tee'd into the main line. One has rock around to help with drainage and the second you can see above. I also cut, cleaned back the woods and created a swale with more rock in an attempt to direct the water were it needs to go.
There's still a third spot that needs attention. The tree line has a low spot, almost a foot shallower, than the frontage grass line. We'll see what happens once the rain starts back up and may tackle it this fall after it cools down.
Prospecter
Maine
I think 30 HP is the sweet spot for Class 1 3PH attachments. Enough, but not too much. I also like the operator stations on JD, and small niceties like hydrostatic transmission, quick attach implements, and a nice dash set-up. You did well. I don't need the extra HP on my 2038, but the price was right. Mine is also used.
N
NUTTSGT
Back by the house, I cleaned up a bit, added some stone and tamped it with the plate compactor. This gives me an area to work off of when am over doing stuff or cutting wood.
I'd like to enlarge this whole area, basically a driveway for "me." This way my step-dad can leave his trailer where it is and if there's more company over, it'll give additional parking area.
N
NUTTSGT
I had considered a 2038R but I was concerned that most if my work is in the woods and slow moving. I was afraid the turbo would create too much heat under the hood.
Once I found this deal, just by chance, I snatched it up. I was fully on board buying a used with 1 year old machine with 200 hours to save about $18K.
OutlawDrifter
KS
I don't think you'd have heat problems, but in all reality, unless you're pulling ground engaging implements or running something that is really taxing the PTO you won't notice a difference in the HP.
My Branson 3510H has a 3cyl Cummins rated at 35hp, tractor with loader/bucket weighs in at 4200lbs. I don't think I'd want to go any smaller. My buddy had a 1025R, and parked next to my JD X724 mower, they were the same size physically. The 3510H will do more than it should, but I like the lift capacity both front and rear. Just wish it had a cab in the winter when I'm clearing snow :LOL: 🤷‍♂️
N
NUTTSGT
I'm pretty sure the 700 series bodysize are quite similar to the 1 series, 1023/1025... the series 1 & 2 seem similar until you put them side by side or climb off one to the other. I believe the rear tires on the 2 series are 10" taller.
