Above 1200 Sq/FT Garage Refurb®
N
NUTTSGT
Northern Central Ohio
Eric, I love those dollys. I have about a dozen. Use them constantly and they take the abuse. Recently supported four corners of a pallet so I could load the pallet and move anywhere I wanted. Set the beetle wheels on it and they go anywhere. I even disassemble them to put the caster on other things. Great buy indeed!
When they were cheaper, like $8 plus the old 20% off coupon, I would buy them to rob the casters off myself. You couldn't beat the price for 4 casters.
N
NUTTSGT
I couldn't help myself and hoped to stack a 15% coupon but it didn't work. I know some have had luck doing but I didn't. . . didn't stop me though.
I've considered this for awhile since I got the new boxes and being this close to the press.
I wanted to put all my press "related" stuff in here. Like this
N
NUTTSGT
Well, seeing those boxes, outlets and covers above, its obvious, I'm adding g outlets somewhere in the garage. Yes, going to replace a couple of single gang boxes with doubles.
One reason is the 56" boxes have an outlet strip built in the drawer. What i don't like is how the cord comes out the back.
We're looking at like 3" behind the box of clearance needed without really straining the cord. So doing some research, I found theses on The Jungle.
zmotorsports
Northern Utah
Couple of more pics.
Here's clearance I gained cutting the rod down.
Eric, that is similar to how I have the rods for my hydraulic press. I have no bulbous end on either side and just slip them in from the front up to flush with the front of the adjustable worktable/beam. I like the drawer to hold the press accessories, I just have mine on a side table that I built, but I like your drawer setup.
N
NUTTSGT
Thanks Mike. I know when we ( neighbor & I) built the press, he said to put ends on the rods so they don't accidently get pushed or bumped in. Home shop maybe not an issue but factory updating/remodeling was his area of work at the time.
:dunno:
zmotorsports
Northern Utah
:dunno:
Yeah, none of our commercial hydraulic presses have those bulbous ends either, they all just have straight shafts/pins. In reality a retaining pin being "bumped in" is probably less of a concern than one would expect.
N
NUTTSGT
A little project for the afternoon... parents have a bird feeder that needs attention. They're having issues with '**** and squirrels getting up the feeder pole. Step dad used to have piece of duct work on it for prevention...
They bought a new feeder and his mental condition, he couldn't repair the duct work so here's what I came up with.. pole is 1.5" rigid conduit, so I bought a coupling and bent up some steel. A few minutes with the Horbart and its now a duct bracket.
It'll fit something like this, inside the 8" round duct.20260716_153759(0).jpg
I added a close ****** and a coat of paint. Hopefully tomorrow will be installation. 20260716_154301.jpg
N
NUTTSGT
How involved is it to attach and detach the backhoe? Is that a frame mount? Mine's a 2038R, so I suppose a backhoe would be similar on mine?
Should be the exact same being a 2038R compared to my 2032R. The only real difference would be the turbo for the extra 6hp.
It was fairly easy to detach, attaching should fairly simple as well. I will find out later today when I swap them out again.
Honesty, I thought it was going to be removing a frame and more buts just a different quick attach compared to the 1025R I had previously.
A couple of pics of the backhoe mounting framework.
Prospecter
Maine
You would also need a power beyond kit for the hydraulic side of it if you don't already have it.
Thanks for the reply and the pictures. Looks like a slick set up. Nice to have the Frontier attachments, too. I have a collection of attachments acquired over 40 years. Some work well with the iMatch system. Some not so much.
