The Everything 3D Printer Thread
WildBill
PNW
To gridfinity and beyond!
It is probably going to take the rest of the summer to do these bins, but I look forward to the process and the end result.
My wife doesn’t get it. Please tell me you guys understand that I had to buy a 3d printer to obsessively organize my personal hardware store.
I had 3-4 printers going mostly nonstop for a couple weeks printing different size bins for all my hardware. I was using my Flashforge AD5X printers loaded with the same filament in all four spots so they would automatically switch to the next roll as needed, then filling the empties every evening after work. Printed something like 500 bins, between 2-10 at a time depending on size. Now I just need to finish putting everything in the bins.
If you get tired this guy will print whatever size bins you need. The ones for sale are not gridfinity but he will make whatever, and is a really nice guy.
ER70S-2
What you need to do is organize one of her drawers first. Then she'll get it.
loganb
Omaha, NE
Great first prototype. 10 minutes in the car cutting some cardboard to then measure, 15 minutes at the computer then walk away and get this
Cupholder inserts showed up...think it's workable
Need to figure out "retention" so the cupholder doesn't want to lift out when you lift a cup...combine that into an "anti-rattle" feature and should be good...ish
loganb
Omaha, NE
I know engineering something is more fun, but have you considered glue?
LOL....I'm trying to avoid it but yes....it's the simplest and easiest for sure! Makes it harder to clean them out if they don't pop out....but I don't wash out the cupholders in my daily drivers often enough....I could also just make a TPU insert for the bottom of the inserts...
The simple solution for holding the insert in without glue I think is a larger diameter cylinder around it lined with foam to hold the insert tight and rattle free.
mike93lx
Richmond, VA
I have a sheet of silicone mat that I keep in the shop and one of the things I've used it for is the bottoms of cup holders. It can make them quieter and maybe a little easier to clean, although a printed tpu insert with short sides would be even better
bugnut
Central Ohio
Cut the bottom out of a coozie and slip over from the bottom side. Print a threaded ring and screw them in, about 100 other thoughts, just my $.02
ER70S-2
You can incorporate three vertical ribs into the main part around each cup holder hole that bow inward for a friction fit. Another option is to incorporate three vertical slots into the main part around each cup holder about 3/8" away from the cup holder. Slide some curved TPU pieces into the slots for a nice, tight fit. The possibilities are endless with 3d printing!
jfleisher
Marysville, Ohio
Use some of this to trim the edges of the cupholders?
burger
Erf
E6000 or 3M 5200?
The 3M 5200 looks like some serious stuff. The river is floating a tube to my house. It looks like it will stick any two things together in harsh environments. What's your experience with using it? Does it dry up in the tube after opened or harden at the tip?
kaymccampbell
Upstate New York
It's not something I stock. It does expire and there's dates on the tubes. Be wary.
I've used it to stick things on boats together. Like gluing down a fishing bridge or a center console or a hatch. I've seen it used to attach an ultra high flotation motor pod to the back of a speedboat. Strong, vibration, water and fuel resistant. I believe it's moisture cure. There is a debonder. I forget what it is, but it's something to keep in mind.
It takes a good area to be structural. Like a 3 inch band around the perimeter of what you're gluing. Both surfaces want to be clean and wax free. It's got a stupid open time like 24+ hours and a cure time about a week. Structural time is longer. I leave it for at least a couple weeks.
It wants warmth and humidity for optimal results. If you do it in a cold shop in winter, it'll wait to June to cure. Any time I've used it, it has been for a job, so I used it all. The only time I tried to save some it went off. But then it did sit for several months in an opened tube, so...
Old tool guy
Ok what happened here. Bambu A1, petg, 255 nozzle temp. Filament has been dried to under 25%. Printing a bottle holder for my bike, this is the bottom of the holder and this was the side on the bed. The bottom has the plate texture like always, and the first several layers are good, then several bad layers, then back to good.
mike93lx
Richmond, VA
25% is too high. What temp are you drying at? I do tpu at 65-70
I'd also probably enable supports
loganb
Omaha, NE
It looks like the worst of it is all on the overhang so I'm also suspecting that is most of the issues. Enable supports, it also might look a little cool so try adding 5 or 10 degrees to nozzle temp
Old tool guy
Supports were enabled, they had started to print but not for that portion. I have a sunlu drier. Does the drier temp matter all that much, i thought the goal was a certain MC regardless of how you got there. I thought i had read somewhere that too high of a print temp would cause stringing.
Cruzan80
Denver, CO
My first thought also with an A1 (or anything like it) is also if there are any air currents that could mess with things. Ceiling fan, open windows, etc. I have seen prints even with PLA have issues like what you pictured caused by sporadic moving air.
Is it in a print tent or other "boxed" space?
jeepxj
Ok I have a very limited supply of these school colors.
You guys have first rights to um. Any takers?
In yellow is what I took delivery of today:
Old tool guy
I could use a spool of Clemson orange. Is that the same as Cali orange? East coast vs west coast.
mike93lx
Richmond, VA
Yes, temp matters for drying. I'd crank it up and let it cook for a bit. Tpu is very moisture sensitive.
And increasing print temp too much definitely can cause stringing. For tpu, I go into the print profile and disable retraction. That's made a big difference in my prints
Old tool guy
What’s this tpu you’re talking about? I’m using petg. Dang northsiders …
mike93lx
Richmond, VA
@Old tool guy you may need to paint supports if it isn't auto generating them. For that kind of shape, I've had better luck with traditional supports instead of tree, increasing support top layers to 3 and using a rectilinear top layer for them. Should pop off pretty cleanly
KwikFab
Central Valley, CA
It is.
5200 for a permanent application, 4200 for a non-permanent application.
I used 5200 to seal up a steel water bed that holds 38+ gallons year round. As long as you give it several days to cure (I gave it a week) it'll never leak.
mike93lx
Richmond, VA
It appears that running less than two kilos of pet-cf through a standard p1s extruder was enough to wear it out. I've been having jambs and clogs at the extruder for the last couple weeks and it finally clicked why.
Guess I should order a hardened assembly
loganb
Omaha, NE
Check what the feed tube looks like as well...if it's causing issues at the extruder the tube is probably worn too
