The Everything 3D Printer Thread
WildBill
PNW
To gridfinity and beyond!
It is probably going to take the rest of the summer to do these bins, but I look forward to the process and the end result.
My wife doesn’t get it. Please tell me you guys understand that I had to buy a 3d printer to obsessively organize my personal hardware store.
I had 3-4 printers going mostly nonstop for a couple weeks printing different size bins for all my hardware. I was using my Flashforge AD5X printers loaded with the same filament in all four spots so they would automatically switch to the next roll as needed, then filling the empties every evening after work. Printed something like 500 bins, between 2-10 at a time depending on size. Now I just need to finish putting everything in the bins.
If you get tired this guy will print whatever size bins you need. The ones for sale are not gridfinity but he will make whatever, and is a really nice guy.
ER70S-2
What you need to do is organize one of her drawers first. Then she'll get it.
loganb
Omaha, NE
Great first prototype. 10 minutes in the car cutting some cardboard to then measure, 15 minutes at the computer then walk away and get this
Cupholder inserts showed up...think it's workable
Need to figure out "retention" so the cupholder doesn't want to lift out when you lift a cup...combine that into an "anti-rattle" feature and should be good...ish
loganb
Omaha, NE
I know engineering something is more fun, but have you considered glue?
LOL....I'm trying to avoid it but yes....it's the simplest and easiest for sure! Makes it harder to clean them out if they don't pop out....but I don't wash out the cupholders in my daily drivers often enough....I could also just make a TPU insert for the bottom of the inserts...
The simple solution for holding the insert in without glue I think is a larger diameter cylinder around it lined with foam to hold the insert tight and rattle free.
mike93lx
Richmond, VA
I have a sheet of silicone mat that I keep in the shop and one of the things I've used it for is the bottoms of cup holders. It can make them quieter and maybe a little easier to clean, although a printed tpu insert with short sides would be even better
bugnut
Central Ohio
Cut the bottom out of a coozie and slip over from the bottom side. Print a threaded ring and screw them in, about 100 other thoughts, just my $.02
