Any tricks to getting the tank nut off (other than eating more spinach)?
Proper fitting Wrench + Cheater bar = Goodness.
thanks, it took me over a hour to type all this up and only 5 min to dismantle that jack. Im just glad i can give back for all the info and deals i find here.
Hiball,
A question..........I've disassembled my jack according to your directions (And it is almost identical, down to wrench sizes). When I removed the release valve, the seal under it was cockeyed, not seated properly and partly mangled on one side. Would this alone cause the jack to not operate (Lift) at all? The seal is not a true oring, but rather seems to have a ledge on each side. Photo will follow. Is this kind of seal available? Oil isn't above the piston, so I may need a little. Also, should I continue with complete dis-assembly, or just see if this is the problem?
Very exciting to be fixing, rather than breaking things!!!
Unlikely unless the center piece (square) portion was
Mangled, that stationary portion is what allows the linkage to raise and lower when the gear is turned.
I'm not understanding your answer and my information might be incorrect.
Looking at this rubber "washer" or seal let me describe it. First, it sits on a round metal washer with a square hole in it that accommodates the square end on the release valve.
The seal could be an o-ring that was left squashed for a long time, giving it a different cross section. I notice in your example there is what looks like an o-ring that has deteriorated. Are o-rings what are typically used here? How tightly must the release valve be screwed in? Just enough so that when the handle is turned, that it doesn't unscrew? If it is an o-ring that goes in here, how do I size it. Diameter to fit the size of the opening, but what diameter of the cross section of the o-ring?
When I try to reseat this one it gets jammed off center.
There isn't alot of pressure at the release so just use a oring that matches the outside diameter, not terribly thick (2-2.5 mm). The proper way to reinstall the release mechanism is to lengthen the Inner adjustment to where you can square it up inside the lower slotted piece, then start threading the main gear assembly into the block, when it gets hand tight (bottoms out) turn the gear so it retracts the inner piece and at the same time tighten the outer gear. Repeat till the release assembly is all the way down. If you don't follow these guidelines you will simply just keep bottoming out inside. After you have tightened it up make sure the gear turns easily, if not loosen the assembly a bit. Hope this helps, it's hard for me to explain something in words when it comes with doing it for years.
OK,
When holding he release mechanism in my hand and turning the star wheel, it does not lower the square portion on the other end.
If the valve is in the release mechanism, is it possible it is jammed open or closed?
If I hold the star wheel immobile and turn the opposite (Square) end with a wrench will it break or should it unscrew?
Bill
Clueless in Detroit
The Valve has to be completely seated against that washer Solid or the Release wont work.
1. Insert the Ball
2. Inert the Washer
3. Insert the Oring
4. Lengthen the square by Unscrewing it from the Release Assembly.
5. Insert the Square section into the Washer
6. HOLD the Gear and thread the Assembly into the Hydraulic Block
7. When it bottoms out (Square against Ball/Seat)
8. Rotate the gear to the Right which will pull the inner square back up into the Assembly, Meanwhile screwing the assembly down into the block.
9. When the Assembly is completely seated, This will seat the washer and whenever you turn the Gear it will Rise and Fall. Thus seating and unseating the ball for Proper Jack Operation.
More progress.
Reassembled the jack except the cotter pin into the end of the piston. Even figured out how to thread the long spring through from front to rear and hook first to rear.
Star gears weren't meshing well until I discovered that the casting needed to be adjusted before locking into place with bolts.
It locks and releases.
It raises the jack.
To begin with, it raised it very little with each stroke.
Then I added some oil.
Now it does better but seems to be sucking for more oil.
When I put my weight on it, it feels spongy and flexes some but soes not go down until I release it.
Air in the system?
Not enough oil?
Other seals need work?
Cylinders scored?
I'll test it under load from the car tomorrow after I adjust it and add some more oil.
Greetings: It is 2/1/2012 and I have been reading your article on jack rebuild. I have a 2 ton Sears floor jack #328.12030 and it quit holding up and would slowly sink down. I read your article and followed it and when I got it taken apart, I found the main seal which is some kind of plastic to be cracked and chipped. The seal looks like a thick cup with no "o" ring and it seems to be made of some type of hard rubber or plastic. I cannot find the manual and the jack is so old Sears does not have any record of it.
Measurments are as follows, OD=45mm or 1.770", ID=25mm or .995", thickness =12mm or ,487". I was wondering if you had or know of some place I could get the seal? As this is my first PM I am not sure if I am doing it right. Incase it is wrong my email is [email protected]. Thanking you in advance Tony
First post here... I started rebuilding my near 40 year old NAPA Fleet floor jack this weekend. Everything went fine except for the fact I cannot get the outer tube to seal around the upper nut. Is there some trick. It does not appear there was ever any type of seal. Does it just seal metal to metal? Thought about putting just a very small amount of silicone gasket seal at mating surfaces. Any ideas?
Thanks, steve
I have a small Sears bottle jack with a slight seepage where the metal cylinder contacts the base. When I disassembled, I could see there was no gasket there or even any sealant. So this is where you could use the loctite to ensure a good seal??
