jakemac
I've got a pile of projects backing up in my shop (as I put it together), so I thought I'd start a separate thread instead of squeezing them into someone else's posts.
First up is a new wire wheel set-up.
I'm tired of having to start my old wheel by pulling the pulley belt. It would also be nice to not have to swap wheels when I need a course wire. So, my old trusty deathtrap needs to go. Enter a new deathtrap.
I'm replacing this -
With this - (I freely admit that I planned this with the thought to inspire jealousy in a certain un-named member here
I started with the motor, a 1/2hp 1750rpm Craftsman. It needed a TON of sawdust blown out, a new cord, and the bearings needed to be re-greased. The second and third pictures are of me getting it ready for paint without taking the motor apart. Getting the tape into the housing was challenging.
I used Valspar Classic Royal Blue. I was hoping it would come close to Craftsman Blue, but it's too bright. Still, it's the closest rattle can I've found so far.
The stand is an original Craftsman stand that I paid WAY too much for. It got wire wheeled (the last job with the old contraption) and painted Rustolium Metalic Black.
(More in the next post)
. I bounced a few other ideas around and finally came up the the idea to use Flue Stops (pic 1) (those things that look like metal paper plates that cover the stovepipe holes in walls). I removed the "painting" inserts and hammered the backing flat. The hole in the center is the perfect size to fit over the raised area of the bearing cover. I then drilled holes so the bearing cover screws can hold the shield on, and a hole in one to expose the reset button (pic 2). (I used a paddle bit, the first two tries didn't go well. That's why I bought extras)
), I only get annoyed when one of the wires finds it's way into the bottom of my foot.
