The Machine Work Thread
jeff g
Manchester UK
Hi
Very nice work :thumbup:
jeff
JTH
MO Ozarks
Ez-duzit that's a great looking part. I'm going to purchase a small mill today and hope I can
Attain half your skills! You've given me a boost as I thought 60 was a little late to get busy on a new skill set!
Jim Johnstone
Brantford, Ontario
Maybe this doesn't count since it's not in my garage, but today I get to re bore a drive wheel from a bandsaw. This is one monster of a bandsaw apparently.
Nor'Easter
Maine
I don't consider myself a machinist rather a fabricator with a knee mill... but these are some 6061 intake plates that fit a 6BT Cummins head.
H
Hephaestus29
Indianapolis
Re: The Machine Work Thread Why is my boring bar double dipping on the backside cut?
So I was trying to use my boring bar "for the first time ever" as a fly cutter.
It was double dipping on the back side of the cut.
Do I just need to break down and get a face mill or what ?
What am I doing wrong ?
Jim Johnstone
Brantford, Ontario
Normally with a flycutter you want to very slightly tilt the head so the back sweep of the flycutter stays a few thou above the part. Even with a face mill and the head perfectly trammed, it's pretty common for the face mill to still cut a tiny bit on the back sweep.
Jim Johnstone
Brantford, Ontario
Tilting the head might give you clearance
on the back side but it's going to dish
or concave the piece.
If it's setup correctly, it will be an almost immeasurable amount, this is SOP they teach in trade school for flycutting. Besides, if he is already having it cut on the back sweep and is "double cutting" with his current setup, then he is already dishing the part.
H
Hephaestus29
Indianapolis
Thanks, I've been playing around trying to
set it up and, yes it looks like about a
half of a degree is going to get me clearance.
Leveleer
Superior/Duluth
I enjoyed going through this thread. Lots of interesting skilled people.
Here is a picture I took while playing with some crankshafts I made on my Robodrill.
Frank
A_Pmech
IL
An easy way to set this up is to put the indicator you use for tramming your machine into the spindle. Now, bring the machine a thou out of tram by loosening the head bolts until they're just snug and giving the head a few whacks with a rubber mallet.
Re-sweep the table with your indicator to confirm you have a thou tilt at the diameter of your fly cutter and go to town. I usually make the left side of the cutter low when viewed from the front of the machine. That way I don't get showered with chips. :)
H
Hephaestus29
Indianapolis
Thanks everyone, I played around with it
further and yes, less than a half degree is
sufficient. I haven't tried your method yet
John but I will and I appreciate your input.
Jim Johnstone
Brantford, Ontario
Yep tramming indicator is the easiest way.
H
Hephaestus29
Indianapolis
Frank
We have some Robo drills at work but they just use them for drilling oil holes in the drive hubs in our department.
What are those for lawn mowers Or ?
Leveleer
Superior/Duluth
Some might find this interesting:
First machine I ever bought: Hardinge DSMA (purchased 1972)
First CNC machine: Spindle Wizard with 24 position tool changer (1976)
First CNC lathe: Okuma Howa 4PS (1977)
First multispindle screw machine: Acme Gridley RA6 (built 1942 to make 50 caliber bullets) purchased used for 6000 dollars in 1976.
Last multispindle: Guildemeister GM16AC
Last CNC lathe Guildemeister MF65-twin
Frank
H
Hephaestus29
Indianapolis
Any experts here on Hardinge Lathes ?
And please don't tell me to go to yahoo
Hardinge groups, there may be a lot of
knowledgable people there but the site
I have a Hardinge Chucker I'd like to
get going but I have a couple questions
about it.
