The Machine Work Thread
Jim Johnstone
Brantford, Ontario
Customer of ours is rebuilding 2 of their lathes, and hired us to machine down the saddles and insert bronze because the turcite wasn't lasting long enough. This is the little one. The big saddle was 4 feet long.
zmotorsports
Northern Utah
Some mods a few weeks ago to my lathe.
And while I had swarf on the lathe I decided to address one more little item that was bugging me. I hated to have to reach for an allen wrench each time I wanted to lock down my compound slide so I machined a little lever and drilled for a small roll pin to act as a stop when the lever was loosened.
Mike.
Jim Johnstone
Brantford, Ontario
Mike.
Nice work on the lathe mods. What kind of lathe is it? Brand ? Size?
IHmachinery
Pacific Northwest, Canada
An easy way to set this up is to put the indicator you use for tramming your machine into the spindle. Now, bring the machine a thou out of tram by loosening the head bolts until they're just snug and giving the head a few whacks with a rubber mallet.
Re-sweep the table with your indicator to confirm you have a thou tilt at the diameter of your fly cutter and go to town. I usually make the left side of the cutter low when viewed from the front of the machine. That way I don't get showered with chips. :)
HI folks,
I'm new to this thread, but will be following with interest. Quick question on this topic: why do you want your head out of tram for fly cutting? Any amount of 'out-of-tram', either left or right, will lead to dishing of the surface. Now, this may be tiny and not be important depending on the application, but I don't understand why you would want to force it. If the head is trammed perfectly, you get a faint tool mark on the trailing side, and a nice even cross-hatch pattern in the surface finish, which I always thought was an indication that everything was perfect. I guess I'm missing something ...
Jim Johnstone
Brantford, Ontario
HI folks,
I was always taught in trade school that you didn't want the trailing sweep to touch if possible. I had to fly cut those bronze strips in my previous post, to make sure they were dead nuts flat. If I could have trammed out my cnc by a thou, I would have for sure. My surface finish was gorgeous on the front sweep and a tiny bit scuffed up after the back sweep.
zmotorsports
Northern Utah
Pretty cool handles.
Thank you.
What are you using to hang up tooling?
I have a piece of unistrut fastened to the backsplash and then made some angle aluminum pieces to hold the BXA toolholders. I have a complete setup of the lathe showing what I used in my shop projects thread in my signature. If memory serves I think the lathe setup is around page 7 or 8.
Thank you. It is a Taiwanese 13x40 lathe, Precision Mathews.
Thanks all for the comments.
Mike.
KMScott
Stuffed this guy in my basement, brand new. Had to lower it 9" to fit under my Kitchen. I make parts for vises and sick and tired of fixing my old machine a Miltronics Partner 04. I'll never make enough to pay for it but my last 5 years of work will be a little easier. The tool changer alone is a life savor. I'll share some of my projects like the ones you guys are building now that I found this thread. Some nice work being shown.
Wes J
Peoria, IL
Customer of ours is rebuilding 2 of their lathes, and hired us to machine down the saddles and insert bronze because the turcite wasn't lasting long enough. This is the little one. The big saddle was 4 feet long.[/QUOTE]
Interesting. Looks like a CNC lathe. Do they not have way wipers and way covers?
You should machine a relief in the middle of the bronze pads so that it only bears on the first and last third and doesn't rock. It will still need to be hand scraped to match the box ways.
Jim Johnstone
Brantford, Ontario
Pretty sure they are both manual lathes. The customer in question is a steel manufacturer, all their work is roughing the forgings down, so they create a **** load of mill scale dust that murders the turcite, that's why they opted to try ampco bronze on these 2 rebuilds.
As for way wipers, I can't comment on that, we don't see the final rebuild, we're just installing the bronze. I doubt there is any room for way covers on a machine this big.
H
Hephaestus29
Indianapolis
Is that aluminum bronze ?
Seems like there was a thread over on
The home shop machinist where somebody
was talking about Turcite.
I used Aluminum Bronze for my lead screw
nut in my mill, it's supposed to have
really good wear resistance.
Jim Johnstone
Brantford, Ontario
That was my thread on HSM as well. It's ampco 18, which is bronze, aluminum and iron.
NedNorton
Colorado, USA
I'm working on some new adjustable feet for an INDEX Model 40 project. Most of the stuff you guys are posting up here is far better but, I'm working on it. Anyway... Thanks for the motivation to make my parts as good as I can make 'em.
Threading... 1 1/8-18
Parts... I'm happy with the finish. Finally dialing in speed/feed rate/depth of cut.
Going together...
3 more to go...
Keep up the good work, boys.
Cheers,
Chris
Griff93
Huntsville, AL
Nice use of a collet holder and mill. Can I ask just out of curiosity why you did this on the mill vs. the lathe?
Mike.
I wanted the depth of the counterbores to be all the same. This is easy on the mill as it already has stops built in. With the lathe using the counterbore in the tailstock makes it hard to get them very close to the same. There's also a stop under the bungs in the 5C collet so it's pretty repeatable for quickly positioning the work piece. My lathe is an 18" swing so it doesn't lend itself well to making parts this small. Don't get me wrong, it can be done and we do it some. It's so big compared to the part it's kinda clumsy. I'd really like something like a haas TL1 or 2 for making this kind of part. Having a 5C collet chuck or some other type of collet would also help.
zmotorsports
Northern Utah
3 more to go...
Cheers,
Chris
Those turned out great Chris, thanks for sharing.
Mike.
zmotorsports
Northern Utah
Knowing that they need to be a precise depth explained it. Makes perfect sense, thanks for clarifying.
Mike.
larry_g
oregon
Cheers,
Chris
I'll be interested to see those installed. Something I may need to steal.
lg
no neat sig line
J king
Ne oh
Here is what I needed for a while. A large drill bit rack to store and organize bits. Need to get a label gun to mark sizes yet. Takes up unused room that is hard to find in the shop.
J king
Ne oh
Alos got my steadies off the floor! Been busy trying to get things better organized.
Oregon rock crusher
West of Salem
I really like your drill rack. Any time you can take advantage of "hidden" storage opportunities in the shop it's a big win. Makes it so much easier to find the right bit when they're in order. Ed.
J king
Ne oh
thanks crusher... I use to machine rock crusher body's . looked like a big top thing.
IHmachinery
Haven't posted anything here yet, but here is a project my son and I started today. About 40 years ago I made a meat tenderizing hammer as a shop project in high school. I still have it and use it to this day. My son wanted to make one for himself so here we go ... Photos below show squaring up aluminium stock using a fly cutter, then chamfering, and finally starting to cut the 'teeth'. Will post more as we go ...
H
Hephaestus29
Indianapolis
I think I'd have to use stainless for a
project like that, just not sure about
using aluminum for something that
comes into contact with food.
Nice work though.
I like the drill rack too.
IHmachinery
It would be awfully heavy in steel, and lots of commercial cooking stuff is aluminium. Anyway, here is the finished head. Now on to the handle ...IMG_1347.JPG
ClappedOutBport
Nice work though.
There are loads and loads of aluminum pots and pans, so I wouldn't worry about it too much.
zmotorsports
Northern Utah
Machined a new brake lever knob for my mill Friday night.
Then made a wall mount rack for my MT3 drill bits.
Nothing major.
Mike.
IHmachinery
Here is an example of the kind of stuff I sometimes do. First picture shows a disc (piece of farm equipment) and you cab see the little dog-bone shaped spacers that hold the discs in place on the shaft. They are cast iron. Bearing seized and spun one of them to destruction, so I fabricated a replacement from steel. It is relieved on the inside of the bell end to accommodate the shape of the disc and only registers on the outer rim. The step on the small diameter fits int a bearing. I also fabricated the red-painted part on the left-most disc (whose purpose is to level the outermost furrow). I can show pics of that if anyone is interested.
zmotorsports
Northern Utah
Nice work. I don't miss farming at all. My hat is off to you.
Mike.
K13
St. Albert, AB Canada
Haha I remember having to make one as well in high school shop probably about 30 years ago. I think my mom still has it.
H
Hephaestus29
Indianapolis
This is what I did in my garage today and yesterday and last weekend.
It's a Head Tram unit. All I need now is for someone to let me use their spindle sander. LOL Maybe I can do it at work.
I did such a good job on the shaft "If I do say so myself" that I put it in a felt lined cigar box to protect it while waiting to be be installed. lol
