Above 1200 Sq/FT Eastern Washington Workshop
slodat
Central-ish, WA
Got the motion working with Mach3 on Windows 10 and a UC100. Going to swap the UC100 out for a Ethernet Smoothstepper so I can run the THC-300. The steppers run the gantry quite nicely.
I had this nice Hoffman enclosure so I decided to use it to house all of the controls. Welded studs on. Looks good and will work great!
I'm going to order a Razorweld Razor Cut 30 to get this thing going. Thinking I'll have a sheetmetal shop weld up a water table tray. Not sure if I'll keep this guy. So, I'm going to get it going for as little cash outlay as I can, while still putting a quality machine together. So, mostly using what I have :)
slodat
Central-ish, WA
Added water table cross supports made out of 1.5" square tubing I had on hand.
I'm going to sand it all down with 80 grit, prime and paint.
slodat
Central-ish, WA
Hoffman enclosure came today. It's 10W x 12H x 8D to house a 2hp Teco FM50. Front panel controls will be start and stop push buttons and a matching Allen Bradley potentiometer for speed control. This will be running my open face paint booth exhaust fan from the adjacent room.
Plasma cutter arrived. Razorweld Viper Cut 30. It will get me cutting. When budget allows, I'll upgrade to a better machine.
Had some help last night on the plasma table frame. It's getting close to being sanded down and ready for paint.
slodat
Central-ish, WA
Brushed on a coat of primer.
The CNC router didn't come with T-track on the outside edges of the table. This meant no way to clamp the edge of the mdf spoil board down- the only place it really needs to be clamped. I found some 8' lengths of t-track. They are about 2" shorter than the others that came on the table. Plan is to build a program to drill holes and pockets for nylon socket head cap screws on the two long edges of the 5x8 mdf and thread them into nuts in the t-track.
Got the t-tracks installed this morning. There's a lot of 6-32 flat head cap screws in the 16 feet of rail!!
slodat
Central-ish, WA
Going back together. The cable track will be here this week and I'll get it all assembled. The paint is what it is. I wasn't setup to spray. Brushing didn't turn out so great.
rubberrodder
Tacomatose Wa.
Ehh...a few brush strokes here, a couple dry spots there. It beats the heck out of rusty, crusty any day. I think it looks pretty dang good.
slodat
Central-ish, WA
Thanks for checking in and commenting guys! Once it was one color ish, it was easy to move on. If I wanted it to look nice, I think I'd have to spray it. Plasma tables aren't beauty queens once they are in service.
slodat
Central-ish, WA
Getting lots of little stuff done in preparation for full custom interior projects. Not much that's photo worthy. I did get this knocked out today.. Added a compressed air system ON-OFF switch to the entry door lighting push button switch box.
Turning the switch to ON energizes the coil circuit for the compressor motor starter and the soft start valve which then slowly pressurizes the shop air system. Turning OFF means the compressor can't run and it dumps the air header pressure. This circuit is supervised by the lightning contractor. So the compressor can't run when I'm not here.
Bib Overalls
Jonesboro, Arkansas
Sounds like you are getting close to the grand opening. No one on the Garage Journal Forum has worked as hard and expediently as you have. Envy you for your skills set.
hardly
Vancouver, WA.
Very nice setup! You're on the home stretch!
To get a spot in line for upholstery work, do we need to take a number?
slodat
Central-ish, WA
Thanks for checking out my shop and commenting guys! Looks like I've got some time to get the rest of the shop projects knocked out. :)
I'm itching to tear into this thing and get it together. It's "drivable" in town but not ready for prime time. In the mean time, I washed it off and drove to the shop this afternoon. I love it!!
slodat
Central-ish, WA
Thanks guys! Found a leaking freeze plug Saturday. Picked up parts but will have to wait. Shop needs my attention. Currently working on getting the spray booth installed.
drivesitfar
SD: your shop is looking great as always and keep up the great work!!
just curious how you are posting your pictures cause there is a HUGE issue with Photobucket wanting to charge members $399 a year to do 3rd party hosting when they get to a certain amount of pictures. are you using PB cause if you are and you reach a certain limit they all of a sudden without warning keep the links from opening up on GJ. take a look at a few of the old GJ garage gallery threads and you'll see what i'm talking about.
anyway have a safe and happy 4th and good to hear you are about ready to open up for business. are you planning on quitting your day job and just working for yourself now or do tell?
slodat
Central-ish, WA
I've been using Tapatalk's built in photo uploader and hosting for quite some time now. I have never liked or used photobucket. I had used Google Picasa for about ten years until they got rid of the photo link in their user interface. It's all a pain in the **** with the photo hosting.
I won't be quitting the day job anytime soon. Ultimately, that's the goal. For now, just keep plugging along at this crazy dream of mine.
drivesitfar
SD: good to know about Tapatalk if i ever get a new cell phone and want to try it. also happy you (and I) left Photobucket years ago before this latest fiasco.
KEEP THE DREAM ALIVE and it looks better at your shop every week you post up something you managed to do or buy for it.
do you maybe have a friend or an apprentice to help you and maybe learn some of what you do or is that in the plan? it's hard to do EVERYTHING yourself, but it's a lot easier to manage.
cheers
slodat
Central-ish, WA
Cut a template out of 1/8" MDF on the laser to locate and mark the roof penetration for the exhaust stack.
Now to box in the opening and remove a section of the joist in the middle of the hole.
slodat
Central-ish, WA
Top side is done!
Inside has a bit to go. This is going to be so nice. Turn on the exhaust fan, spray, turn down fan speed to exhaust residual.
slodat
Central-ish, WA
Man that is going to be so handy to have. Good job!
:thumbup:
:beer:
Thanks for checking back in on the shop, Dan! The spray booth is essential for the work I do. And, it has been the vision from the start. Not gonna pretend cutting into the roof wasn't a bit nerve racking. Turns out all of the layout work was worth the effort. Didn't have to move or adjust the booth at all once we started assembling the exhaust stack.
Thanks again!
Now, to get the inside done!
slodat
Central-ish, WA
I ordered the exhaust fan with a 3 phase motor so I could use a VFD to control fan speed. I whipped up the control panel placard on the laser this morning. Test run in 1/8 MDF:
A few changes and added keys for each control to line them up:
Once it's right in MDF, cut in 1/8 acrylic along with a drilling template:
All together:
drivesitfar
SD: since you might tend to either walk up on the roof or have workers up there before you close up the repair work you did on the rafters you might want to add some more support for that beam you cut. nails won't hold a lot of weight and home depot might have something that you can bolt or screw on to give it a little extra. it might be fine as is and i hear you about cutting into the roof especially since you just re roofed your shop.
looks great and I agree that is a great addition and should also help your long term health.
slodat
Central-ish, WA
Good call. I don't use nails, almost ever. It is all screwed together with 4" #8 torx drive screws. I walked all over it when doing the roof patch. It's good to go. It's just 2x12's.
slodat
Central-ish, WA
Controls wired in, ready to mount on the wall.
slodat
Central-ish, WA
Late night in the shop. Completed wiring the exhaust fan motor, VFD and controls. All class 1, division 1explosion proof, yadda yadda to meet code requirements.
It's crazy how much air a 24" blower moves!!
slodat
Central-ish, WA
Thanks for cheering me on guys! I appreciate you checking out my shop and commenting. Helps keep me going! I'm still smiling about locating the roof hole such that I didn't have to move the booth to line up, at all.
Getting there. In the process of assembling the filter wall.
slodat
Central-ish, WA
Progress on the filter wall.. A couple pieces left. Trying to decide what the first project will be. I'm thinking the new main entry door in bright white to match the roll up doors.
slodat
Central-ish, WA
Spray booth is done!
Filter differential pressure manometer.
