Vise Info Thread
KMScott
Athol 720. 6" jaws and weights 150lbs. Weight is a estimated by the owner. Nice vise.
mikeswrenches
Kevin, max opening is nominally 7 inches. Also this one, and for all I know maybe all of them, has smooth jaws.
Mike
KMScott
Columbian D45-M4. 5" Jaws that opens to 6". Weight 37lbs.
KMScott
Chas Parker 439 Double Swivler. 4" jaws opens to 6" and weights 67lbs
KMScott
Chas Parker # 39. 3-3/4 opens to over 6" and weights 47lbs. Black and White pic's only.
KMScott
Chas Parker # 8 Swivel Jaw Pre 1900's. 4-1/2 jaws that opens to 8" and weights 56lbs.
KMScott
Chas Parker #42. 4" jaws that opens to 3-1/2" and weights 33lbs. Considered a Filers Vise
KMScott
Chas Parker #249. 4-1/4" Jaws that opens to 5" and weights 73lbs.
KMScott
Chas Parker 93-1/2. 3-3/8 Jaws that opens to 4-1/2". Art Deco model with a open screw.
KMScott
Chas Parker # 49. 4-1/4 Jaws opens to 7" and weights 61 lbs.
KMScott
Chas Parker # 370 Swivel Jaw. 3-1/4 Jaws opens to over 3" and weights 25 lbs.
KMScott
Chas Parker # 100. 3-5/8 jaws that open to over 4" and weights 32lbs.
KMScott
Chas Parker 229. 3-1/4 Jaws that opens to 4" and weights 35lbs.
KMScott
Chas Parker 31. 3" Jaws opens to 4" and weights 13lbs.
akasrick
south jersey
Re: Vise Info Thread
Guess this is not for the record.
No Manufacturer on the vise, thinking Bonney.
These #s are on the anvil
PATD JUNE 2ND 91
#? 2 1/2
2.38 lbs
opens 2"
1 7/8 jaws
akasrick
KMScott
Prentiss 513/523 Vise. 3-1/2" jaws that opens to 5" and weights 28lbs.
akasrick
south jersey
Thanks akasrick, does it have a quick release? just seeing the spindle pivoting and was thinking it is a quick release.
No it doesn't KMScott unscrew the rear jaw, slide the rear off then tilt the screw up and pull out. No washers, nuts or pins.
As usual my lousy pics.
akasrick
Also has the dreaded mystery holes (plugged) on the top of a jaw, possibly someone tried to fit a Rapid Vise style of attachment in the wrong place then cut it off.
454ragtop
Carver, MA
Kevin, that Prentiss (points up) is a 513, as cast into the main body. The dynamic has both 513 and 523 cast into it as the dynamic could also be used in a swivel base or swivel jaw main body, one of which likely would be the 523. Have a Prentiss swivel base swivel jaw with the dual marked dynamic.
KMScott
Yes you are right 454, there is another Prentiss 523 cast into the Static on the spreadsheet with 523/513 on the Dynamic, both use the same replaceable jaws, I thought I should show both vises and assume the Static is the main vise number. Prentiss does this on other models too.
https://www.garagejournal.com/forum/showpost.php?p=1444891&postcount=1927
KMScott
Piramiit Clamp-on double swivel-er. 2" jaws opens to 1-3/4" and weights 3lbs.
KMScott
American Scale 524. 6" jaws that opens to ... and weights ... This is my working vise and it is missing the swivel base and has the same jaws as a A-Scale #25 jaws welded on.
KMScott
Chas Parker # 87 Combination Vise. 3-1/2" jaws that opens only 3"? Is this correct? Weights 47lbs.
454ragtop
Carver, MA
Kevin, funny you should ask this. I picked up an 87 last year, couple pics in this post https://www.garagejournal.com/forum/showthread.php?p=6474650&highlight=Parker#post6474650 Real nice shape other than missing the handle. A while later I came across another Parker for cheap, think it was a fixed base and not a combo, and figured I'd swap the screw since it had a handle. Well you can imagine my surprise when I saw how short the screw out of the 87 was. I inspected it closely expecting to find evidence of a break, nope. Installed the longer screw from the other vise, pat myself on the back for restoring the capacity of the vise. A few months later stumbled across a catalog page and was surprised to see the small opening. So now I'm in a quandary, swap the screw back to keep it original, or leave the longer screw because it actually makes more sense? I have a few catalog page pics from 1916-1925 showing this vise, most show 3-5/8" jaws that open to 4-3/4", but the 1922 page shows 3-1/2" jaws that open to 3". I didn't actually measure mine before I swapped the screw, but there was quite a bit of slide hanging out the back of the static jaw as the screw ran out.
chrisnazzy
Arizona
I have a Parker 433 1/2 that by all accounts seems to be the later model number of the 87. Catalog pages I have show both as 47 lbs. and 3 1/2" jaws that open 3". I have been confused by the max opening also because my screw is long enough to allow the vise to open normally. Measuring length of the protruding slide my 433 1/2 actually opens just over 4 1/2".f1c32fcd488df1bbb977776fa2c71ffb.jpg8bf6e2bf70f14e92e60c701398af7789.jpg
GSchmitty
Nassau County N.Y
Hello All , I'm new to G.J just wanted to say hello and ask if anyone knows where i might obtain a swivel base for my newly acquired C Parker GG vise. It's a monster and before i start trying to fabricate something i figure the original parts would be better.
chrisnazzy
Arizona
Welcome to GJ. Try posting your question and some pics of your vise over in this thread.
https://www.garagejournal.com/forum/showthread.php?t=88292
Or this thread.
https://www.garagejournal.com/forum/showthread.php?t=252830
Fierljeppen
Chas Parker # 52. Early Swivel Jaw. No spec:s on this vise and only one Picture.
Here's some details on the #51 and #52. Wow, that's the first one I've ever seen.
KMScott
Thanks 454, I will add a note to the #87 saying it can open more. There must be a reason for the short screw, maybe to much stress on the vise if opened more the 3" or a larger pipe is grabbed and tightened. Thanks for the catalog pages. Got to create time to add these catalog pages.
