BEFORE & AFTER....A Tool Polisher's Haven
Decline58
SoCal
Thanks JM, I did not know that!
Does that work on aluminum? I am trying to clean up the attached jointer guard, I am not sure I want to polish it, just clean it up. Actually it looks a little worse in person that in the picture (but that's the way things work on the internet......I have heard).
View media item 76194
J
JMLangford
Upstate SC
Does that work on aluminum. I am trying to clean up the attached jointer guard, I am not sure I want to polish it, just clean it up. Actually it looks a little worse in person that in the picture (but that's the way things work on the internet......I have heard).
You probably wouldn't want to use the pencil trick on your jointer cover.....I would just use soap and water......:dunno:
Depends on how shiney you want it to look....
1953mercury
Steamboat Springs CO
If your not concerned with shinny, I would just bead blast it. Quick and easy. Mike
Motorman55
South Jersey
Big difference in how an aluminum part will come out when polished depends on how coarse the casting is.
Perfect example is the early Harley BT 'Shovelhead' and Sportster 'Ironhead'
valve covers.
The amount of pitting after polishing could be so bad the only recourse to get them really smooth was to have them custom chromed using lots of copper/nickel base plating to get them smooth and shiny as a mirror.
Which of course would negate the whole point of polished aluminum.
I just live with the imperfect pitting. I like polished aluminum. I don't care too much for chrome.
Bears Fan
Indiana
JM
Interesting tip with the lead pencil :thumbup:
I'm just going to box up a pile of stuff from the barn and send it your way for polishing :lol_hitti
brianh
grahamsville NY
Some really nice restores on here, I have some old equipment I have got back to new running shape but not the appearance detail. Last one was a belsaw planer moulder that had been outside behind a shop for the last 5 years works great now.
Decline58
SoCal
View media item 80337
Thanks for the help guys.
Here's the cleaned version of the guard. I started using CLR with a toothbrush and it worked a little. Moved on to Simple Green, then 409 and finally powered, old fashioned Comet and a soft wire brush.
It somewhat looks too good for the rest of the restoration, Hmmmmm.
Thanks again for the help.
don long
southern california
I spent a little time this week finding some brass tools to polish and display
I'll start with these pliers.
2017-12-09 15.40.11 by don long, on Flickr
After grinding all the cast marks away and sanding the tool with several different grits it was ready to polish.
IMG_2625 by don long, on Flickr
Next I found these wrenches so I picked the big one to polish
2017-12-09 15.41.33 by don long, on Flickr
First I gave it a trip through bead blasting to set off the depressed lettering
IMG_2628 by don long, on Flickr
Next was the sanding process with my 3" pistol sander
IMG_2633 by don long, on Flickr
I also found a couple of adjustable wrenches so I picked the worst one to start on
2017-12-09 15.42.05 by don long, on Flickr
Again it went to bead blast for starters then on to the sanding process to polish the high spots on the handle and the head
2018-02-15 13.01.23 by don long, on Flickr
Here is a shot of the other tools we are cleaning up to put into display
2018-02-15 13.02.55 by don long, on Flickr
crerus75
This is primarily for Don Long. Don, your work is exceptional as always. I see that several of your tools are made by Berylco. These are made of beryllium copper alloy. Stephenw mentioned this earlier, but please be careful grinding or polishing these, as inhaled beryllium dust can cause all sorts of respiratory problems even after short exposures. The Berylco page lists some of the OSHA guidelines that regulate beryllium safety:
http://www.ngkmetals.com/index.cfm/m/95/
Sorry to put a damper on things, but I'd hate to see somebody develop berylliosis.
RD350
Canada
OK Gentlemen I am flabbergasted! You guys are professionals!
What are the tools & chemicals that I will require in order to get started?
I have a reasonably size work bench table at home and just a drill machine.
If someone could list the essential tools / parts that I need to buy would be much appreciated. Thank you kindly.
don long
southern california
I'll be happy to offer my help but first we need to know just what it is you want to do.
I use mostly my sand blaster and various grits of sand paper on my tools prior to hitting them on my polish wheel
RD350
Canada
Good evening Sir: thank you very much, kindly.
I have a bunch of old wrenches, two record vices, old artifacts, a small brass blow torch and I am also restoring a motorcycle from 1972, need to polish them nut bolts etc.
I would love to get most of this stuff polished to the same level as most of you have done and for this I will need guidance on the hand tools required and the procedure.
I can get the bigger stuff sand blasted at a shop, but the rest I would want to accomplish at home. Many thanks.
don long
southern california
If you have a bench grinder you are half way there.
Get a fine wire wheel and put on one side of the grinder and go out and buy a 6" polish/buffing pad and put on the other side. get some black rouge for buffing the steel nuts and bolts. I use red rouge for brass and white rouge for stainless. I don't use any chemicals but would suggest a coat of light oil on any polished steel. I spray a clear coat paint on my brass and do nothing on stainless. you can also sand the metals with graduating finer grits of sand paper to get a high shine or mirror look after buffing.
Hope that helps.
Show us your work as you get some things finished
Don
eric.holmslice
Here is a cool hand drill I bought for $5. I took it apart, added a new cord, regreased, and buffed it with my Craftsman block grinder. Pretty sure I have a new hobby now.
McFarmer
Man that drill is nice. I have one I did the same to, it's not variable speed so they are limited in their use.
I have a counter sink bit that stays in it, works good for that.
Did you ground the case ?
eric.holmslice
This hand held is variable speed which is nice. I used 220 grit then 320 grit to remove scratches and casting marks.
don long
southern california
Very nice job on the lil drill. Those old craftsman tools polish up very well
I have collected several that need the same attention.
And you are right it is infectious for sure.
Please let us see what else you put a shine on
Don
drivesitfar
ERIC: i love my old aluminum tools and if I could get them to look like that all the better. VERY WELL DONE with the little drill and hope you have more to do cause you have serious skills.
ALL: thank you all for sharing your methods, supplies, tools and your projects with us cause I know a lot of us love old tools that look even better than when they left the factories.
bonneyman
Desert SW
ShopCraft 3/8" drill - one of the Holy Grails! :drool::drool::drool:
eric.holmslice
Eric, nice job dude.
Bill
Thanks! It was my first ever attempt at this with the exception of small parts on my Atlas press or hand polishing wheels. Now that I have my block grinder converted to buffing I’ll be posting more projects.
sqznby
Coastal NC
Wow, nice job guys
eric.holmslice
I took another attempt at polishing up the hat on my Atlas press. I ended up having to sand the pitted chrome down to bare Aluminum. If you look close you can still see some imperfections.
rickhigginshtbr
Lower Bucks, PA
Slowly getting pieces cleaned up for my Craftsman 100 Drill Press restoration....
drivesitfar
Rick: nice work polishing up the pieces of your drill press. just curious how you (or anybody) takes off the badges. cut, drill or pry?
good luck
Eric: well i've looked at your top of your cool drill press and I can't see the imperfections. are you hand sanding or using what tool?
WELL DONE!!
rickhigginshtbr
Lower Bucks, PA
Most 40's-60's Craftsmans, the badges are held in with those rivets that you can hammer off with a punch from the backside. Rubbing compound / polishing compound / Mother's Mag got them 95% clean without having to use a tool and possibly lose color like I've done before.
eric.holmslice
Bought a cool Porter Cable. It had a lot of gouges, so I had to use a fairly aggressive clean up process. Should have a few pics assembled and running soon.
don long
southern california
Eric
That's a great shine
Did you remove the name plate before working on the piece?
What was your process from start to finish if you don't mind sharing.
Thanks
Don
eric.holmslice
I used 120 grit on the heavy pitted areas. Then 220,400,and 600. Followed by red compound and white. I left the emblem on, just placed tape over it.
I used a 2inch sanding disc on my drill for most of the sanding. Thanks for all the feedback. Hoping to get the wiring done tomorrow. I’m putting a new cord on. Also adding heat shrink insulation to some of the old wiring to the motor.
OCD
Edmonton, Ab. Canada
This was my Grandfathers old axe, My Dad found it in a shed at my Grandparents lake lot that my Mom inherited... He asked me if I could clean it up a bit, he wants to hang it over the fireplace there...
Challenge accepted with honor!!
Bead blasted to see what we are working with,
Can you tell Gramps was a farmer and not a woodsman,
I decided to leave all those hammer marks in the back and just clean up the blade for show,
Started with 24 grit on the air grinder,
Then worked up to 600 grit on an random orbital,
Switched to wet sanding by hand for 1000, 15000, and 2000 grit,
Then a quick polish,
Taped off the tip, and bead blasted the rest of it again, then primed,
Base coat,
Cleared!!
