Show us your welding projects
Hummelstown pa
Very sharp looking. Looks like you have a nice fabrication area and equipment as well. Would love to see more pictures of it.
Just noticed you are new to the forum. Welcome.[emoji481][emoji481]
Thanks , I'll have to get some on the truck . Really I just have a tool addiction and have to make stuff to justify it to the wife .haha
NUTTSGT
Northern Central Ohio
Did a quick little project today before coming back to work. Made some drawer pull handles. I had done the doors years ago but never finished with the drawers.
Firstram
Finally putting handrails on the back steps, 1x1 posts with 3/8 pencil rod. The 1/8 top cap will get covered wood. I'm not going to admit how many years ago I built the deck.
LXCam
That's cool Eric. What size are those?
That's certainly unique and very cool. Did you drill the posts for the pencil rod or weld each **** end? How are you going to form the wood? That's something I've never attempted but would like to some day.
Firstram
Thanks LX,
I drilled the posts from both sides and used a tapered ream to align them a little oversize. I don't have the equipment to drill an angled hole thru stainless tubing.
I will make the cap with 3 steam bent rips that will be bolted together with *** bolts. Unfortunately Cumaru can't be glued, it's too oily.
royce
fairbanks ak
Firstram,
That staircase and rail is great looking.
Those curved stair cases are a interesting study of layout, with the radius of the curve and the different pitches of the inner and outer rails.
Nicely done and look forward to seeing the caps.
Royce
Firstram
Thanks Royce,
I appreciate the complement, especially from the internet winning big vise builder. Curved rails are not hard, just time consuming. Small steel does not need to be bent on a helix, a simple radius will take the shape lust fine.
Ole Slewfoot
Freedom, CA
I welded a custom brace for the bottom of each stair. It could have been so simple... I nearly killed the volunteer cutting out stair treads when I found out he was not making them all the same:lol_hitti
27' double helix.
kkroger
OK Last bit on this one, as installed, their electrician had not roughed it in yet so it remains dark...
4 FN 27
Minnesnowta
In anticipation of a new Water Jet coming I made some weights from some Bar Stock I found laying on the floor under the Shear at the plant to hold the blanks down. Got 3 of 4 done and could not for the f'ing life of me find the 4th handle. Looked for an hour and a half...found it on the Vise on the Mill.
kkroger
Very nice work!!!
thanks! I should also mention that the Light panel I built to hold the LED "Fluorescent" tubes for the lighting, was not welded in or even welded in any way, I used solid aircraft rivets to assemble that part.
Sorry no pics of that.
mr_magicfingers
Devon, UK
27' double helix.
Took barely a fraction of a second to know where that was without ever having seen it before. It's been 11 years since I was last in the dust. I do miss the amazing things everyone builds out there. Nowhere else like it.
skipnay
PA
made some bed rails for my truck. The up-right bars behind the cab were there when I purchased the truck, I just made the rails on top of the bed sides.
Flat bar is 3/16", tubing is 1.75" .120 wall HREW
How did you make these? Use a hand held tubing bender?
Richard D
Texas City, between Houston and Galveston
They are garbage, yes. Just calling a spade a spade. Trailer i build i slot cut plate then double sheer a bolt for holders
That's what D.O.T. told us we needed when I upgraded the chains on all our custom built trailers, and NOT to weld the chains on. The two factory made trailers we recently got, have those little shaped bars as above. I found that a bit odd. They seem like they would be good for tie-downs as in the photo, however.
DocsMachine
I showed the stand I made for my 2 x 72" belt grinder back in Post # 5616:
I just added a rack, as planned, to the open bottom section to hold the extra tooling arms:
Came out nicely, and still holds them securely even when the cart is kicked forward to move it around like a hand truck. Plus the extra ballast down low adds some stability and makes it feel more "solid" in use.
Doc.
12husky
OK Last bit on this one, as installed, their electrician had not roughed it in yet so it remains dark....]
What lighting packages do you typically use for your indoor and outdoor signs?
kkroger
Various... This was U shaped LED flo tubes, T-8 type, which I use most often for exterior we also have used other LED light bars with various colors for exterior signs... and specialty high intensity light bars for some art walls 8'x5'x3' light boxes...
We call up the LED place in town and see what they have that we can use...
12husky
I am working on a project now and the customer is supplying lighting modules to go behind it. I haven’t done much with lighting myself.
kkroger
Nope I could never use something like that, I have strip LEDs that are just "OK" for small stuff, I have Bright White STRIP LED on a spool reel off what you need and stick it down, the adhesive is somewhat crappy... Soooo I use better stuff...
12husky
What would you use for this?
kkroger
This is about 9' long I think it was actually larger than that, the lettering has frosted 1/4" acrylic inside, the sign is about 2" tall ish.. and 1" Thick, the lighting is a "Flourescent" tube 8' long, just one lighting the entire thing (exterior sign just single white, On your example I would probably use Frosted Acrylic to catch the light and the place I use locally would probably have plenty of options the tubes I use are ballast free and just 120VAC input on one end, USUALLY though I do have some single pin tubes that have Hot on one end and Neutral on the other. if you use 120VAC stuff do be sure you ground the "Chassis" to earth.
