Woodworking 101--Tools and Tips
jar944
Northern VA
Working on a entry bench with some beaded inset cabinetry.
Coping and sticking some cabinet door rails and stiles. These are 1&5/32 thick vs the std 3/4 and are cut with an exterior door cutterhead for an extra deep profile.
Turned those parts into this bench
rlitman
Long Island
I got to see this beauty on Monday:
J
jimreed2160
Tallahassee FL
Jar--Nice bench. It's good to throw out a project every now and then to keep the family on your side.
Rman--Thanks for the pictures. That is an amazing set of tools.
dirt_dobber
Bee Cave, TX
I know "live edge" things have been done before but this is my first attempt to do any.
I brought a 48" long and 6" thick Walnut slab from a guy on craigslist and rather than using my draw knife to get rid of the bark I thought it would be fun to make use of it for a picture frame. I finished the frame with 3 coats of spray shellac to go into the crevices of the bark. The bark turned from grey to brown
once I applied the finish.
Those pictured are my son, daughter-in-law and my 6 year old triplet grandsons.
J
jimreed2160
Tallahassee FL
I just installed a new cabinet at the end of my bench and moved most of my user planes into it.
txlonghorn1989
Just wanted to say I discovered the WW'ing thread a week or so ago. I've been reading some everyday, keeping it open and making what progress I can. Enjoying the heck out of it. Only on page 8 so far, 50+ to go. Good good stuff. Wish I'd found this sooner but like discovering John Prine late in life...better late than never! :)
CRSINMICH
Southeastern Michigan
SENSITIVE LATERAL ADJUSTMENT​
I can't remember where I first saw this but it works well for me. I've been using some of my wooden planes and this is the standard method of making lateral adjustments to the cutting iron. It also works on metal planes. CAUTION: This is a 3 oz. ball pein. They are usually much heavier but even a 4 oz. seems too heavy for this use. TAP the side of the iron. It should make a soft "tink" . The adjustment can be much finer than with the lateral adjustment lever.
Bob Heine
Boca Raton, Florida
Here I was, minding my own business and you gave me another project. I need to fix my neglected plane iron hammer that I used for random projects. I have had this miniature ball pein hammer forever. I thought about replacing the handle with a straight one but decided I liked the curve (I also couldn't find a handle for this small a head).
The head came loose many years ago so I tightened it up with a finishing nail in the wedge slot (it worked so I hacked the nail off. Recently I destroyed the hammer's value by giving the head a little polish (the polished faces leave less noticeable marks). Today I pulled the piece of nail and removed the head. Once apart, I weighed it. It appears to be a 2 oz. Champion DeArgent of uncertain age.
Now that it's apart I decided to further degrade it's value by polishing the bottom of the head that is hard to reach before I re-assemble it.
I think I can make a small red oak wedge to fit. Then I can go back to my workbench/workshop repair. I will sleep better knowing I have a plane iron adjuster ready to go. Then I just have to remember to use it next time.
Seriously, CRSINMICH, thanks for the tip.
CRSINMICH
You're welcome, Bob: I wish I could take credit but it's pr0bably been done since craftsmen made the transition from wood to metal planes. BTW, I've heard that ball peins this small were used for making gaskets. Supposedly the gasket material was laid onto one side of the part where the gasket would go. The small pein was then used to tat-tap-tap around the edges and openings until the gasket was formed. I'm not sure about that but it's a good story.
p.s. My other small pein is a Bonney.
J
jimreed2160
Tallahassee FL
TX--Welcome to the thread. Feel free to post pictures of your ww projects.
CRS--Good tip. When I use woodies, I generally tap on them with a piece of scrap--1x1 hardwood works great. It works on the toe (to advance blade), the heel (to retract the blade), the wedge (to set the blade) and on the side of the blade for lateral adjustment. Of course, your method is more repeatable since I cannot seem to find the same stick.
Bob--Good for you. I think you should shine away on those rusty brown hammer heads. That's how they looked back in the day. I like your save on the handle. A brand new handle on a vintage head just does not look right to me.
Craptain
Tampa Bay FL
That method of gasket making definitely works. From being a mere youth I was taught that method by my father and used it often. Still do for that matter and not a youth anymore.
Sent from my SM-G930T using Tapatalk
Bob Heine
Boca Raton, Florida
I found a hunk of oak (from a pallet) and managed to cut a big wedge. Without measuring anything, I cut a smaller wedge from the big one.
I mistakenly cut the small wedge to fit the long dimension of the handle and had to split and fit the wedge to the smaller dimension. It's becoming a pretty small piece of wood.
A few taps with tack hammer and the wedge did its job. The head is nice and tight and it should be good for the rest of my life. I did burn the end of the handle and wedge when I buffed the head one last time.
Now that I'm old and have some spending money I buy ready-made gaskets but back in my poverty-stricken youth I used shirt cardboard (is that still a thing?) and a ball pein hammer to tap the holes and edges to fine-tune carburetor gaskets. I also re-used cylinder head gaskets. That required a little steel wool and a coat of axle bearing grease.
My first encounter with a ball pein hammer was in 1952. My mother was a Cub Scout den leader and she got a project from her pack leader. It was a square of copper sheet and a short section of two-or three-inch pipe. You held the copper sheet tight to the pipe and tapped on the copper sheet to form a bowl. Back then smoking cigarettes was good for you and the final result of the project was a shiny ash tray for dad.
Back then, especially during the Korean War, tobacco companies not only advertised everywhere, but had a controlling interest in TV shows. I especially remember Ralph Bellamy and Man Against Crime. Every episode featured a double-door made of Camel cigarette packs opening. It was either at the beginning of the show or the end. Got this from Wikipedia: "The R. J. Reynolds Tobacco Company (Camel cigarettes) sponsored the series, as well as holding a monetary share in the program and a copyright on the series. Mike Barnett was frequently shown smoking a cigarette (and occasionally flashing a pack at the camera), and at the conclusion of the program, Ralph Bellamy would put on reading glasses and read a list of veterans' hospitals and military bases to which "the makers of Camels" was donating cigarettes that week."
It's good they stopped advertising Old Gold cigarettes before I hit puberty. A pack of cigarettes with an apparently naked lady inside was Esquire-esque (
Memory is a funny thing -- can't be sure what I had for dinner last night but 1952 is clear as a bell.
56vette461
That is a true story. Gasket material came in square sheets of various thickness and you made what you needed
jar944
Northern VA
This oliver followed me home today.
1946 oliver hollow chisel mortiser
HenryAZ
MEMBER EMERITUS
South Congress AZ
4--you seem to be getting serious bout your mortises! That's quite a machine.
Your monster mortiser looks like quite a machine. Never saw a 5 head tenoner, as we only used two head single end tenoners.
In addition to several floor mounted hollow chisel mortisers, the shop where I worked had a chain mortiser. It had a chain bar in place of the hollow chisel, and the foot pedal raised the bed and door stile into the chain. We usually only set that up for larger orders of doors, but it sure made quick work of mortising.
J
jimreed2160
Tallahassee FL
Preston shave
Back in the day, Preston turned some of the nicest tools around. I found this spokeshave while I was cleaning up. It is a fine example of cast iron tool art from the Victorian era. My guess is 1880-pre WWI. This shave had nice bones which were covered in rust. My first thought was to give it an Evaporust spa treatment but closer inspection revealed only surface rust. So I got busy with my brushes, Scotchbrite pads, and Simple Green.
My goal is to make the tools look like they were just resting on granddaddy's shelf. Gentle cleaning is the way to go if you are after that result.
After a good cleaning and polishing, I coated all but the blade with paste wax.
J
jimreed2160
Tallahassee FL
Preston shave
After an hour of brushing and scrubbing, most of the rust had moved from the shave to my hands. The blade was in great shape and only needed a little honing to put it back to work.
My reward was pulling a nice shaving.
jar944
Northern VA
Jar--Nice score. We are anxiously awaiting pictures of the chips flying.
I'm also anxiously awaiting flying chips
The 5 head I have is a small tenoner as far as tenoners go.
5 head is a bit of a misnomer in that they have 4 heads (2 tenon and 2 cope) and a cutoff saw
This cute little thing only weighs around 800lbs the powermatic 2a was based largely off this design
HenryAZ
MEMBER EMERITUS
South Congress AZ
That's exactly like ours were. I wasn't counting the cope heads and the saw, just the tenon cutters. We hardly ever used the saw as the stock was rough cut to a length that didn't need further cut-off.
jrj3rd
Severna Park, Maryland
See you visited the NY Historical Society :) Couldn't figure a way to sneak the box out when I was there a couple weeks ago (wife is a Tiffany lamp fan)
Jolomite
Detroit, Michigan
Preston shave
Nice work, Jim! That's a nice turn of phrase about transferring the rust to your hands- ain't that the truth!
-Joe
jar944
Northern VA
Temporarily wired up to test.. and chips successfully made.
J
jimreed2160
Tallahassee FL
-Joe
Well, not all of the rust went on my hands. A substantial part of it was imbedded in the belly section of my tee shirt. When I get busy cleaning rust I often emerge from the shop looking like Charlie Brown's friend PigPen. :thumbup:
rlitman
Long Island
I'm a Tiffany Studios fan as well, though as great as that display is, years ago the Met had a temporary exhibit put together that was even more impressive. For me though, the structural glass staircase was one of the most interesting pieces in that room.
We actually went there to catch the end of the Harry Potter History of Magic exhibition. That was quite impressive.
slodat
Central-ish, WA
I bought this disc sander a few years ago. I put together the pile of parts and finally got it all completed today. 20” 3 phase disc sander with single phase input power, braking and full automated dust collection.
Video of it running. I’m getting zero dust out of it. Very happy!!
