Show us your welding projects
fstbusa
Very nice! Is the gap between the idler and cart tight enough to keep the chain from flopping over?
Not sure I understand what you mean but the tlxhain will not come loose unless you peel the chain off the sprocket or release the sprocket to spin. I've been thinking about putting some foam in it to give it additional backpressure and keep the chain tighter
sqznby
Coastal NC
fstbusa
I like it. But, how is it spring loaded? LOL
I welded a small 1/2” long section of threaded rod in between the standard rod lengths. I put a nut and spring on the inside of the support tube before I welded the cap on. There isn’t much threaded rod there so you don’t really see it when it moves up and down.
jalexl
Los Angeles, CA
fstbusa..I don't understand your description, if possible can you ad pictures.?
thanks
MrSurly
East Texas
The chainstay is awesome. The question I have may be already posed, but I’m trying to understand if the chain itself it spring-loaded around the bottle? I get that the release knob is spring-loaded, but is the chain itself under tension? (No need for it to be, just curiosity) I’m thinking of “stealing” your idea and combining with an over-center latch. Great design, way cool!
TTMotorsports
Lucerne Valley, CA
Finished up my part of 4 link on a ranger. Sway bar and bumpstops.bc63af4922a014a505fa15b24c41784a.jpge3c2149637d5c7cd99d00485af8befea.jpg40746c8eb6bbc76b99c2878c0a9bd87d.jpg
Sent from my SM-G965U1 using Tapatalk
fstbusa
No the chain isn’t under tension currently. I was thinking about adding some foam on the front side of the tank to give it a bit of tension so hold it on the sprocket better rather than creating a chain guide
javajaws
toomanytoyzz
Malvern, PA
Here's a small project I did for my girlfriend's birthday. I am not too keen on the color choices. They looked much different on the cap, so I might change that later. I also sanded it down to expose the underlying green. I might strip it 80% and put some other color on top to give it a harsh patina'd look.
I used some sections of tin ceiling tile I had gotten from an architectural salvage place I go to from time to time for obscure building materials. You can't beat the prices and the 1 1/2 drive is worth it because there is a BBQ place local with some AMAZING ribs.
PCO6
Newmarket, Ontario
That stand for the spot welder is nice. Would like to see/hear more about it and the timer.
Thanks. I built the stand, shown here prior to painting, around a basic spot welder and made it so I can easily remove it (6 bolts) so I can take it to something I'm working on if I want to. When it's on the stand and foot operated it's great to have an extra hand. The pedal is spring loaded and clamps down on the work pieces nicely. It's on wheels so I can move it around and store it easily.
I take NO CREDIT for the timer ... other than mounting it to stand. One of my Brothers is a retired Millwright and has a lot of experience with plant machinery. He built it from old bits he had laying around. The "guts" are shown in the pic below. The large gray box is the contactor, the black piece is the transformer and timer itself is the piece with the dial. Apart from fitting everything into the electrical box on the back bottom of the stand the only thing we added was a hand held remote switch. The green button switch was mounted to the box so there are 2 options to trigger the welder.
The timer has an incredible range of options. It can automatically trigger for a set time anywhere from something like a tenth of a second to once a year! I trigger it manually to a set time of about 1 to 3 seconds for a weld. After a bit of trial and error, one and a half seconds seems to be about right for the 19g metal I used for the drawer shown below.
I have another spot welder that is generally for body work. It works great except that it was designed without a timer (later ones of this type had one). Adding a timer is our next project!
View media item 36768
View media item 37680
View media item 37679
View media item 90412
View media item 90413
Rigging65
NorCal
This is a powder coating station I built. The blaster cabinet sits on top, and the fold out table allows for a pop up spray tent to sit on top. There’s slide out storage for powder bottles and a top tray for the gun and other ‘stuff’. Under the slide out tray is storage for the spray tent, a box fan and filter insert for the spray tent. I wired the whole thing for electricity so there’s just a 220v and a 110v extension to plug in that runs all the lights, fans, oven, spray gun etc. I ran an airline manifold with valves to supply the blaster cabinet and the spray gun, as well as a spare air nozzle for clean up. It was a fun project!
Muggzy
Orange Co., NY
I love your compact use of space! Awesome planning [emoji106]
Sent from my Pixel XL using Tapatalk
TTMotorsports
Lucerne Valley, CA
Few more trailing arms shipping out today.
3496af5658e00a416d5f41b7d2f6ba2d.jpgadf5cb74d8a7c6a30dfc752251129058.jpg77a3cbf15bb2412a4426bfb6e24f6d58.jpg
MrSurly
East Texas
